ICF Vs CMU - Page 2 - Green Building - Contractor Talk
ICF Vs CMU
Old 10-09-2013, 04:49 PM   #21
rpm150's Avatar
Trade: Residential Construction Management
Rewards Points: 25
Re: ICF Vs CMU
robcon,
I've done several papers on ICF Homes for my major and really believe they're the way to go. The numbers I've found for ICF homes as far as price comparison are .5-25% increase but you have to keep in mind, especially with the geothermal system that you mentioned you're going to recoup your losses much faster. As I've said I've never been on a build with one but I do know that after all the research I've done I plan to go into the ICF Home building business. Especially if you live in an area where High winds are an issue.
Google image search "ICF house post katrina" That should be an excellent example of just how durable these homes are.
Here's a link for some thermal images, Just scroll down some....
http://www.buildingtips.net/ez_vol5isu9.htm
From the research that I've done, its indicated that ICF homes also produce a self extinguising fire, meaning that if (God forbid) there ever was a fire, that the fire would end up smothering itself due to lack of materials to burn, now this s clearly only after its burned out all the interior walls and other combustible materials, but what I've come upon shows that you can rebuild relatively easily after a fire.
As far as the floor systems go, theres a bunch of different options, they make brackets that you place inside before you do the pour that you then nail through to secure the joists. I liked the concept of that system over some of the others, but theres so many that Its tough to say one of them is shades above the others.
Just figured I'd share some of what I've picked up but like I said, I'm no pro I just did a good bit of research on them for my papers, and eventually my thesis paper for my bachelors I think.
Hope that helped. Glad you chose ICF though!!!!
Ryan.
Edit: Don't forget that this can be used for a Passive house If you wanted to look into some of those building techniques.
Ryan.
rpm150 is offline
Old 10-09-2013, 09:22 PM   #22
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
Re: ICF Vs CMU
Ryan.[/QUOTE]
Bachelors = Cornerstone
Masters = thesis
Doctorate = Dissertation
mrcharles is offline
Old 11-04-2013, 07:19 PM   #23
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: ICF Vs CMU
ICF,s vs C.MU
My take,neither,this would be my choice. http://summitbrick.com/index.php/vie...ctural%20Brick
Here are some of the reasons I think a structural brick has the others beat. ICF systems still need some type of exterior finish,with the brick you get the finish built in.You can design the rebar to address any load criteria like an ICF however,you can easily place insulation to suit any climate zone. Having done several structural buildings I can say quite assuredly they are more cost effective than an ICF veneered building.
fjn is offline
Old 11-04-2013, 08:48 PM   #24
wazez's Avatar
Trade: masonry
Rewards Points: 784
Re: ICF Vs CMU
Originally Posted by fjn View Post
ICF,s vs C.MU
Did you use insulation in the cores or line the inside with foam?
wazez is offline
Old 11-08-2013, 09:47 PM   #25
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
There are truly almost an endless number of ways to insulate. All the insulation is on the interior,the cores do not provide adequate space for insulation + there would be a lot of thermal bridging even if you could.
I have placed continuous rigid foam on walls,then attached hatch channels to hold it in place and allow a substrate to affix electric boxes drywall etc. Your imagination is the only limit on what can be done.
At one time Summit Brick had a "pamphlet " showing various methods of insulating.
It is my humble opinion that if one truly understood the nuances of structural brick wall assemblies ICF,s would be a non issue.
fjn is offline
Old 11-08-2013, 09:55 PM   #26
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
Hello WAZEZ;
Here is an article that depicts a structural brick home the guys from my local masonry group did in the 80' s. Hope this helps explain the process better. I was indirectly involved with this one,but deeply involved since.http://www.masonrytech.com/reinforcedbrickarticle.pdf
If you have any questions PM me.
fjn is offline
Old 11-08-2013, 10:08 PM   #27
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
RPM150; Did you shoot your neighbors' German Shepherd dog lol !
Just kidding !
fjn is offline
Old 11-09-2013, 07:44 AM   #28
Joasis's Avatar
Rewards Points: 1,948
Re: ICF Vs CMU
Hello WAZEZ;
I would bet the structural brick is what? 5 times more labor intensive? And the cost?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
Old 11-09-2013, 06:47 PM   #29
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
You would loose the bet !
fjn is offline
Old 11-09-2013, 08:27 PM   #30
duburban's Avatar
Trade: building
Rewards Points: 1,800
Re: ICF Vs CMU
icf for foundation. double stud wall, dense pack to r40+, air seal at the sheathing plane and run a HRV on the inside, say hello to sweet sweet comfort.
duburban is offline
Old 11-10-2013, 08:24 AM   #31
Joasis's Avatar
Re: ICF Vs CMU
Really? How so?
I would build every project with ICF, but it is not cost effective in many cases, and I would guess labor on the walls to be much lower in time then what you do....brick on the outside of ICF is the same as on frame.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Old 11-10-2013, 12:20 PM   #32
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
Really? How so?
Stop and think of this for a minute.No matter how you slice it there is a certain amount of redundancy in the use of ICF,s . The ICF provides the structure and insulation (though to enhance it is a further step).One then needs to add the exterior and interior finishes,be it wood,stucco,plastic,masonry etc.
With a structural brick you get the structure and exterior finish all in one. The choice of and / or prescriptive R rating is then applied.
One other aside,according to a survey by the National Assoc. of Home builders 85% of home buyers would prefer a brick home. Why not give it to them as a structure and finish rolled into one and eliminate the redundancy ?
Last but not least,you missed the picture. I was not advocating adding a structural brick to the exterior of an ICF, The structural brick is the wall,unlike adding brick veneer to an ICF or wood framed walls !
fjn is offline
wazez (11-10-2013)
Old 11-10-2013, 12:26 PM   #33
Joasis's Avatar
Re: ICF Vs CMU
No, I did not miss the point. You could contend that by doing conventional brick exterior, that would count in your favor, but.....and this is where I was leading, at what cost?
We can do ICF's for $6 a sq/ft (area of the wall) and the exterior brick will cost about $4 a sq/ft, in this area.
So tell me about structural brick please. Include the total cost per sq/ft of wall, as I gave you above.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Old 11-10-2013, 12:52 PM   #34
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
Approx. $14.00 sq.ft. in my area (N.W. In.) . Before you get to excited,unlike an ICF.wall with brick veneer,the structural brick will need only a 8" foundation to accommodate it. Some of those cost savings need be applied.
So the 5 times cost you suggested is not even close to reality. Also,why the heck do we, one of the wealthiest countries in the world constantly attempt to measure the worth of our buildings by how cheap we can build them vs aesthetics and posterity ????
I'm truly not interested in seeing how low I can go on price point.
fjn is offline
brunothedog (11-10-2013)
Old 11-10-2013, 01:11 PM   #35
wazez's Avatar
Trade: masonry
Rewards Points: 784
Re: ICF Vs CMU
Since were debating icf versus block here's my house. 6" block with brick veneer.
wazez is offline
Old 11-10-2013, 01:22 PM   #36
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
Attachment 102844
Attachment 102845
Looks good ! I too am a fan of composite walls vs. A wood framed building disguised to look like a masonry building.As author Steve Mouzon wood say "brick wallpaper applied to give the illusion that the building is built of a more prestigious material than mere wood ".
fjn is offline
wazez (11-10-2013)
Old 11-10-2013, 02:17 PM   #37
wazez's Avatar
Trade: masonry
Rewards Points: 784
Re: ICF Vs CMU
Thanks....made sense to me. Of course im a mason. A wood framed structure just seems inferior to me.
wazez is offline
The Following User Says Thank You to wazez For This Useful Post:
fjn (11-10-2013)
Old 11-10-2013, 09:57 PM   #38
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: ICF Vs CMU
Oh boy oh boy,
This has been all i have talked about working the trade show for the past 2 days. I will elaborate on this at some point in the near future.
TBA
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 11-11-2013, 07:46 AM   #39
Joasis's Avatar
Re: ICF Vs CMU
I was simply guessing at 5 times, but, you say why based on price?
Because, if I can build with ICF's, and get it down to a close margin over framing, then obviously, I will have more work....and yes, profitable work. You can price yourself out of the market.....high end? Sure...and after that?
I have never even heard of structural brick around here.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Old 11-11-2013, 12:20 PM   #40
fjn's Avatar
Trade: mason
Re: ICF Vs CMU
I'm somewhat surprised,the Western States Clay Products Assoc.(which operates in the States W. of Mississippi river) has a strong presence. Beyond that,your neighboring state Colorado is home to Summit brick,a producer of such brick.
You may find this video informative .....or the companion one on fire testing https://www.youtube.com/watch?v=60nffXn9VjI
fjn is offline
