Section At Smoke Chamber - Masonry Picture Post - Contractor Talk
Old 02-16-2012, 01:12 PM   #1
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 662
I thought some might be interested in this. Plywood template at top is the second floor fireplace layout. I have a bunch of these to build at this job, so I'll keep it updated.
artisanstone is offline
The Following 3 Users Say Thank You to artisanstone For This Useful Post:
AmeliaP (03-08-2012), Captainsls (02-21-2012), lukachuki (02-16-2012)
Old 02-16-2012, 06:43 PM   #2
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
Re: Section At Smoke Chamber
Looks like fun.
bytor is offline
Old 02-16-2012, 08:32 PM   #3
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
It took me a while to see that you guys were on scaffold. i had no idea what I was looking at hahahaha.
When you say you have a bunch to build, how many fireplaces total?
dom-mas is offline
Old 02-16-2012, 11:36 PM   #4
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,498
Sunny and shirt sleeves.
Can't wait!
Looks like a lot of fill ahead.
Keep up the good work,
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 02-17-2012, 05:14 AM   #5
Trade: Stonemasonry
Rewards Points: 662
8 fireplaces, in seven chimneys. This one is the tallest at about 50' from the basement floor. There are 6 at 60" one at 54" and one 48" box. All Rumford.
Old 02-17-2012, 08:02 AM   #6
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Wow, I guess some people still have money. Sounds like you have some work to go. What will the facing be?
dom-mas is offline
Old 02-17-2012, 04:35 PM   #7
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
It looks like you've used a combination of firebrick and.... sections of flue tile (?) to create the smoke chamber. Is that right?
bytor is offline
Old 02-17-2012, 05:10 PM   #8
Trade: Stonemasonry
Rewards Points: 662
Correct, I got the idea after using the Superior Clay smoke chamber which is just cut down flue liners. The first few I did just like that, but there's a lot of waste chopping up flue liners for every panel. Split firebrick are almost the exact thickness, which works for the infill, and then I back it up with 4" of solid masonry.
The Following User Says Thank You to artisanstone For This Useful Post:
bytor (02-17-2012)
Old 02-17-2012, 07:38 PM   #9
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Wow
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 02-17-2012, 08:57 PM   #10
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
I was checking that out as well. Never liked the split fire brick, and now to combine them with cut flue liners? I am going to have to mull that one over a while to decide if it meets safety margin. I like the 4" solid backup. I shoot for 8" when ever possible.
It also looks like the second fireplace is positioned directly above the first one. Is that correct or just the picture angle?
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 02-18-2012, 05:19 AM   #11
Trade: Stonemasonry
Rewards Points: 662
This is just my opinion, of course. I've built smoke chambers every possible way. I always disliked the corbeled brick, parged smooth approach. One, I don't like the actual work, and two, a bunch of little triangular parge sections hanging upside down, never seemed that durable to me.
I think this way gives the smoothest result with the fewest joints to catch creosote. It's basically just a bell-shaped flue liner. With 1/16 joints and heat stop 50, I have no doubt you could pick up the whole assembly and it would act like one piece.
Old 02-18-2012, 06:32 AM   #12
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
dakzaag, it sounds like you have concerns about this approach (?).
bytor is offline
Old 02-26-2012, 11:03 AM   #13
Trade: Stonemasonry
Rewards Points: 662
More from this job. These pics are about a week old. We start the main floor fireplaces this week, following behind the framers.
Hard to see, but there are four bases in a row, with one to the right and another to the left.
This is the same fireplace as the first photo. It's the only one in the basement level.
P.S. I know I am not much of a photographer. I try to make it up with my masonry.
Old 02-26-2012, 01:38 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Interesting colour of mortar. Typical masonry type N/S mix or is there a secrect sauce in there?
dom-mas is offline
Old 02-26-2012, 02:30 PM   #15
Trade: Stonemasonry
Rewards Points: 662
It's just type S. Perhaps your sand is a different color, our's is red/gold.
Old 02-26-2012, 03:04 PM   #16
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Artisanstone addressed the concerns with the 1/8" joints and 4" backup, so not really. Just observing something new to me.
Still trying to determine if the boxes are in fact on top of each other.
Work looks neat and tight.
D K & Sons
dakzaag is offline
Old 02-26-2012, 03:08 PM   #17
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Sand i use is often red more often gold/brown sugar colour. When the joints are fresh they're dark grey, when cured a lighter grey. Your joints looks beige
dom-mas is offline
Old 02-26-2012, 03:48 PM   #18
Trade: Stonemasonry
Rewards Points: 662
Fireboxes are directly on top of each other. 60" wide x 54" tall Rumford boxes.
Old 02-26-2012, 03:51 PM   #19
Trade: Stonemasonry
Rewards Points: 662
It may be partially the camera and partially that this particular brand of cement is lighter in color than others. Mix is slightly richer than 3:1
Old 02-26-2012, 03:54 PM   #20
skillman's Avatar
Rewards Points: 1,968
Its going to be a nice and toasty home when its done there.
skillman is offline
Section 8 Window requirements???? Kevin75 Windows, Siding and Doors 11 02-20-2013 03:45 PM
How to Interconnect Smoke Alarms Between Dwellings for Secondary Suite backyardauto Electrical 17 11-05-2011 01:37 PM
What section benefits you the most? CrpntrFrk General Discussion 20 10-07-2011 10:09 PM
Replacing Floor Joists/Sill Plate Section WilsonRMDL Framing 3 12-15-2009 09:52 AM
thorat and smoke chamber building mason22 Masonry 7 04-03-2008 04:52 AM
