My Kitchen Remodel, Concrete Counters - Masonry Picture Post - Contractor Talk
Old 02-25-2013, 07:16 PM   #1
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,558
Mama had me working on the house this last week, first project was to get rid of our sweet 1970's kitchen and update it a bit. Tiled the floor, put in concrete counter tops and I am currently tiling the backsplash.
All I lack is the registers and putting the trim back on.
It was really nice having someone to actually take pictures, I need to remember to do that more often.
I used Z-counterform snap off forms and their undermount sink form, really they were a breeze to use, the corners mitered great and they were super strong to screed on, they snapped right off the next day with little issue and left fantastic sharp edges all around.
I will be using that system again, now that I learned a few things about installation I intend to advertise for them.
NYCB is offline
The Following 8 Users Say Thank You to NYCB For This Useful Post:
AmeliaP (02-26-2013), brickhook (02-25-2013), dkillianjr (02-26-2013), dom-mas (02-25-2013), lukachuki (02-26-2013), oldfrt (02-25-2013), skillman (02-27-2013), superseal (02-25-2013)
Old 02-25-2013, 07:16 PM   #2
NYCB's Avatar
Re: My Kitchen Remodel, Concrete Counters
NYCB is offline
Old 02-25-2013, 07:40 PM   #3
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
You're doing a great job.....looks great!
brickhook is offline
Old 02-25-2013, 07:44 PM   #4
NYCB's Avatar
The whole project reminded me of why I dislike inside work, the mess is out of control.
NYCB is offline
Old 02-25-2013, 07:44 PM   #5
brickhook's Avatar
Trade: masonry
what kind of forms are using on the counter tops?
Old 02-25-2013, 07:46 PM   #6
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
He said Z-counterform snap off forms.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 02-25-2013, 07:47 PM   #7
brickhook's Avatar
Trade: masonry
oh yeah, but just think....'Happy Wife ....Happy Life!'.....worth the mess!
The Following User Says Thank You to brickhook For This Useful Post:
Old 02-25-2013, 07:50 PM   #8
brickhook's Avatar
Trade: masonry
I know he said Z counterform, but I've never heard of Z counterform. So I was asking him what Z counterforms were.
Old 02-25-2013, 07:51 PM   #9
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Looks great!
JBM is offline
Old 02-25-2013, 07:53 PM   #10
NYCB's Avatar
These ones, they are PVC and the front and bottom snap right off the next day.
http://concretecountertopsolutions.c...edge-profiles/
I used the single fancy.
NYCB is offline
The Following 2 Users Say Thank You to NYCB For This Useful Post:
brickhook (02-25-2013), kambrooks (02-25-2013)
Old 02-25-2013, 07:57 PM   #11
QCCI's Avatar
Trade: General Contractors/Specialty Contractors
Rewards Points: 952
Nice work!! I'm going to have to check those out, looks like a real time saver. Corners turned out real good!
QCCI is offline
Old 02-25-2013, 08:00 PM   #12
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
Very nice,
What are you sealing the 'crete with?
-Scott
-Scott
tenon0774 is offline
Old 02-25-2013, 08:02 PM   #13
brickhook's Avatar
Trade: masonry
Thank you for the information. The reason I was asking, was I'd never seen these before. Really interesting.
And I think your kitchen's turning out real well!
Old 02-25-2013, 08:17 PM   #14
NYCB's Avatar
They were really slick, with a fine tooth saw blade they miter perfect, I spent more time just doing the holes and form for the sink than I did putting the whole rest of the forms in, including chipping back the laminate, you can fly with them.
NYCB is offline
Old 02-25-2013, 08:19 PM   #15
NYCB's Avatar
Originally Posted by tenon0774 View Post
Very nice,
-Scott
I used Silacryl available from the same company, it was OK, but I think in the future I will experiment with just waxing, I feel like it won't wear the greatest in high use areas.
Waxing is a pain, but at least it can be layered up and redone as needed.
NYCB is offline
Old 02-25-2013, 08:25 PM   #16
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Did you rip up the old floor and thinset your CB down? What about the sink-cut out - how'd you form it? Did you place your mud over the partially torn off formica substrate? reinforcement? what mix you use?
gonna polish?
so many questions,...so little time I likey, likey
supersealconstruction.com
superseal is offline
Old 02-25-2013, 08:53 PM   #17
Decorative Asphalt Guy
oktex56's Avatar
Trade: Decorative Asphalt/Concrete restoration/Carpentry
Rewards Points: 326
I love the form system! Someone really thought that out well.
Nice job on your kitchen too!
oktex56 is offline
Old 02-25-2013, 08:58 PM   #18
NYCB's Avatar
gonna polish?
Well, I cheated a little since its my own house, that laminate flooring refused to come up, it wasn't linolieum, it was pretty much was was on the counter tops, solid stuff.
I scraped up what I could and used PL under my Durock instead of thinset, I put about 50 screws in each sheet.
I just screeded my tile bed like concrete to make up the small dips and dives.
For the counters I just chipped off the edges, same story, that stuff was pulling up chunks of plywood with it so I left it right in the middle the way it was unless it was loose, I figured it would prevent water from weeping through.
Sink cut out was 1/4 Durock over the old hole, then I dropped in the new undermount, crawled underneath and make frame for it from regular 2x4's notched to fit perfect and screwed right up through the 3/4 ply, then those nifty faucet knockouts set to height. The sink form had a peel back sticky tape and honestly it was a pain right in the balls to get perfect, it was pretty hard to measure and notch it out then set it to height while sticking it, I didn't have any help for that part though.
I used bagged 5000 lb mix from Lowes (block yard was closed) and I added 2.5 lbs of type 1 portland per bag. To that I added .5 lbs of buff and one coffee scooper of red, I mixed them up in two bag batches in large tubs with the mixing drill, my mixer is at a jobsite and I didn't feel like driving to get it, probably for the best, the drill worked great, only 13 bags for the whole thing.
I did learn that I should be using water reducer with it, my first two I put in at 2pm and shined up at 9:30 pm, the bigger one I put in around 3pm but my helper put in too much water and I woke up at 1:30 in the morning to shine up.
That mix was fantastic though, super creamy and when I was burning it with the steel and old spit shine it didn't tear once.
I used regular duty wire mesh cut back to edge of the plywood, and put some corner reinforcement by the sink, left it right near the bottom as I filled them, no ghosting.
I'm not going to polish it since they are super smooth already, I don't like the exposed aggregate look, I wanted it to look like concrete, my biggest concern was making sure there was no chatter marks and spit shining it gave me some really neat color variations all over it.
NYCB is offline
The Following 3 Users Say Thank You to NYCB For This Useful Post:
brickhook (02-25-2013), dkillianjr (02-26-2013), superseal (02-25-2013)
Old 02-25-2013, 09:04 PM   #19
NYCB's Avatar
Best part, he shipped it same day I ordered, I got half my order the next morning and the rest the following day.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
oktex56 (02-25-2013)
Old 02-25-2013, 09:21 PM   #20
Renaissance Man
superseal's Avatar
That floor sure looks like old school linoleum...hard as a rock and probably asbestos backed - I've seen it many times in the 70's kitchens so it's probably better that you left it. I probably would have still full spread thinset under the cb in fear of deflection, but you might get lucky with the adhesive and plentiful screws.
Helluva job your doing there - hopefully the wifey is footing the take out bill for all that hard work you doing
Kitchen remodel time frame jhcontracting Kitchens & Baths 56 06-26-2017 06:24 AM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Need recommendations to fix newly but poorly finished concrete floor MikeGC Concrete & Paving 20 03-08-2014 07:11 PM
remodel in kitchen issues chad collins Remodeling 7 11-11-2012 11:16 PM
Kitchen Remodel MAD Renovations Remodeling 22 01-11-2009 03:31 PM
