Little Counter Flashing - Masonry Picture Post - Contractor Talk
Old 09-20-2018, 08:31 PM   #1
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,554
I don't do a bunch of masonry work. Here is a stone chimney I installed the counter flashing on. My mason left the mortar back for the flashing. I make little spring clips out of scrap aluminum to help hold the flashing in place until tuckpointing is complete. Works well especially if the mortar joint is bigger.
overanalyze is offline
The Following 11 Users Say Thank You to overanalyze For This Useful Post:
A&E Exteriors (09-26-2018), hammer7896 (09-20-2018), heavy_d (09-20-2018), META (09-21-2018), mrcat (09-20-2018), Peter_C (09-20-2018), Randy Bush (09-20-2018), Rio (09-21-2018), Robie (09-20-2018), SmallTownGuy (09-22-2018), Xtrememtnbiker (09-20-2018)
Old 09-21-2018, 02:56 PM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
Re: Little Counter Flashing
For over a thousand years soft lead plugs were/are used to hold metal flashing in raked out joints that are later filled...
Where is the flashing parts that service the rain screen behind the stone that otherwise drain into the house attic/ exterior wall???
I can't tell if its faux stone or not, but the issue still exists..
Fouthgeneration is offline
Old 09-21-2018, 04:33 PM   #3
Always Learning
It is a full masonry, real stone, fireplace and chimney....all outdoors. It all drains...well everywhere. They do have mesh installed in the first course to let moisture wick between the block and stone.
Old 09-21-2018, 11:22 PM   #4
Trade: Masonry
Covering the masonry firebox lengthens its lifetime by decades in frost country.
But internal moisture = frost damage, especially any fire clay/brick.
A tin chimney cap with drip edge over the masonry cap reduces the water intake to just the leaky, or porous joints and stones.
Nice work.
I'll put that in the idea catalog for customers if you don't mind?
All that needs is a wet sink with frost drains and 2" drain plumbed to the basement for the bartender...
The Following User Says Thank You to Fouthgeneration For This Useful Post:
overanalyze (09-25-2018)
Old 09-24-2018, 07:21 PM   #5
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Looks tight, how'd ya get the 2"'s underneath the next piece of lead? (errr tin should I say)
JBM is offline
Old 09-25-2018, 05:48 PM   #6
Always Learning
Not sure what you mean by 2'''s ??
Old 09-25-2018, 06:09 PM   #7
JBM's Avatar
Trade: Masonry
Where the flashing overlaps the last piece, was wondering how you got mortar in it, it doesn't look to flexible
JBM is offline
Old 09-25-2018, 06:48 PM   #8
Always Learning
Oh, gotcha. I used my trowel and tuck point tool to force it back in there first then filled the rest of the joint. It is solid under the tin.
JBM (10-01-2018)
Old 09-26-2018, 11:27 PM   #9
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Siding, & Additions
Rewards Points: 15,374
Looks nice. I like the clips.
Clean work
A&E Exteriors is offline
The Following User Says Thank You to A&E Exteriors For This Useful Post:
overanalyze (09-27-2018)
whats your ledger board flashing detail? Rich D. Decks & Fencing 77 10-24-2012 07:08 PM
Best Caulk For Chimney Counter Flashing? WNYcarpenter Roofing 16 03-22-2012 07:30 AM
Counter flashing chimney ? enforcer Roofing 22 11-09-2011 02:55 AM
Chimney Counter Flashing... Mason or Roofer? NormW Roofing 38 10-14-2009 08:15 AM
question regarding counter flashing bmaurice Roofing 16 10-10-2009 05:52 PM
