Lakeside Shanty - Masonry Picture Post - Contractor Talk
Lakeside Shanty
Old 06-12-2013, 04:25 AM   #1
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Lakeside Shanty
We'll be starting at this site soon. Just a modest 10,000 sq. ft. weekend getaway... lots of steel and glass, with a little stonework thrown in for good measure.
Lakeside Shanty-img_0755.jpg   Lakeside Shanty-rivpan1.jpg   Lakeside Shanty-rivpan2.jpg
bytor is offline
Old 06-12-2013, 04:54 AM   #2
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
Be sure to notice the name of the concrete pumping company...
bytor is offline
Old 06-12-2013, 07:49 AM   #3
TLHWindows's Avatar
Trade: Windows Doors Siding Hurricane Shutters
Rewards Points: 734
Re: Lakeside Shanty
A little small for a weekend get away don't ya think? I mean, need to stretch my legs out after a hard week of.... rich.
Cool, lets put some fabric over a window and let a hurricane throw some stuff at it. I'm sure it will protect you and your windows.
http://www.gulfbreezewindows.com
TLHWindows is offline
The Following 2 Users Say Thank You to TLHWindows For This Useful Post:
Big Shoe (06-14-2013), bytor (06-13-2013)
Old 06-12-2013, 08:58 AM   #4
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Re: Lakeside Shanty
That kind of money boggles my mind.....but its great to have customers like that.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 06-12-2013, 05:13 PM   #5
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lakeside Shanty
I can't see the name on the pumper
www.dominionmasonry.ca
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
mikeswoods (07-05-2014)
Old 06-12-2013, 05:17 PM   #6
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lakeside Shanty
Is that 2 fireplaces I see? How does that work with the ICF, no ash dump?
dom-mas is offline
Old 06-13-2013, 05:44 PM   #7
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
Agreed... on both counts. I'm not sure I could survive without the 0.1%.
bytor is offline
Old 06-13-2013, 05:48 PM   #8
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
Yes there are two fireplaces, but 4 chimneys... a couple of the chimneys are for ventilation, furnace stacks, HVAC, range hood exhaust etc. There will be a minimum of "walls' in this place... a LOT of glass.
No ash dumps, although I suppose if we were to do them, we'd have to line the inside of the ICF with some masonry and an air-space.
bytor is offline
Old 06-13-2013, 06:20 PM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lakeside Shanty
Do they jam rebar out of the foundation so you can pour a hearth? Or does that entire area get filled with...fill? and the hearth poured on that?
dom-mas is offline
Old 06-13-2013, 06:27 PM   #10
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
We would typically lay block on the interior, up to the height of the ICF, to complete the rectangular base for the fireplace, cap the rectangle with patio slabs and then pour a re-enforced slab over the whole thing, ending up flush with the sub floor. There will be re-bar to tie the slab to the ICF and our block-work.
bytor is offline
Old 06-13-2013, 06:47 PM   #11
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lakeside Shanty
Huh, patio slabs. Good idea. I've been trying to figure out the best way to pour the slab. i don't do a lot of fireplaces but what I've done is to use a piece of plywood supported by 2x4. Where the ash door is I build a bond beam across and leave 2 or 3 blocks out. Then after the pad is poured I lean in to the ash dump and cut out the 2x4's and then go up and smash the plywood down through the ash dump hole. Slow and dumb. But I never built an FP with someone else, just in school. That taught me the code and ho to do a firebox and smoke chamber etc... but not really the practicalities. Patio slabs could be left in pace where wood couldn't. I guess so could cement board but I don't know if it could take the weight
I like doing them and am always wanting to know the best/better way of doing them. So far you, artisanstone, JBM and a few others have been a real wealth.
Thanks to all of you
dom-mas is offline
Old 06-13-2013, 07:08 PM   #12
JBM's Avatar
Trade: Masonry
Rewards Points: 10,854
Re: Lakeside Shanty
I use cementboard under the firebox. Support it on all 4 sides and it supports 10" of porty.
I cant wait to see what this project turns into
JBM is offline
Old 06-13-2013, 07:10 PM   #13
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lakeside Shanty
10" of concrete, more than enough
dom-mas is offline
Old 06-13-2013, 10:37 PM   #14
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,058
Re: Lakeside Shanty
Then there's always corrugated steel roofing panels for larger spans.
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 06-14-2013, 02:47 AM   #15
CJKarl's Avatar
Trade: Masonry
Re: Lakeside Shanty
I typically use rebar to span the opening and lay a sheet or two of wire lath over it. Bigger openings get scrap steel decking or roofing.
CJKarl is offline
Old 07-05-2014, 07:21 AM   #16
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
And we're back...
We've been working at this site on and off for the past year... mostly through the worst winter I can remember which has sure stretched out the time frame... Wrapped thing up about a month ago and am now trying to wade through the many photos I have amassed.
I'll try and share in a logical sequence if i can...
The building in general;
Lakeside Shanty-img_0837.jpg   Lakeside Shanty-img_1100.jpg   Lakeside Shanty-img_1236.jpg
bytor is offline
Old 07-05-2014, 07:24 AM   #17
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
roof trusses...
Lakeside Shanty-img_1238.jpg   Lakeside Shanty-img_1241.jpg   Lakeside Shanty-img_1246.jpg
bytor is offline
Old 07-05-2014, 07:26 AM   #18
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
winter into spring;
Lakeside Shanty-img_2141.jpg   Lakeside Shanty-img_1822.jpg   Lakeside Shanty-img_2347.jpg
bytor is offline
Old 07-05-2014, 07:45 AM   #19
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Lakeside Shanty
a few from the air;
Lakeside Shanty-photo-1.jpg   Lakeside Shanty-photo-2.jpg   Lakeside Shanty-photo-3.jpg
bytor is offline
The Following 4 Users Say Thank You to bytor For This Useful Post:
JBM (07-05-2014), mikeswoods (07-05-2014), Railman (07-05-2014), Resta (07-06-2014)
Old 07-05-2014, 10:07 AM   #20
slowsol's Avatar
Rewards Points: 2,248
Re: Lakeside Shanty
Awesome house!
-John
slowsol is offline
