Lakeside Contemporary - Masonry Picture Post - Contractor Talk
Old 07-29-2017, 07:11 AM   #1
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
A lakeside gem we finished up last week.
This project began a bit over a year ago and we've been bouncing in and out as time and weather allowed. This project was going on at the same time as the massive project on display in the 'Photo Overload' thread... as you might imagine, we were stretched a little thin trying to keep everyone happy.
A couple of 'firsts' for us on this project; All the fireplace fireboxes were built using Soapstone firebrick; all the fireplaces had cast in place concrete hearths and mantels, a couple with generous cantilevers.
The two main fireplaces were stacked over one another... the lower fireplace was in an outdoor 'room' below the glassed in 'Sunroom' and in fact played a substantial role in supporting the partially cantilevered room above.
Once the concrete support wall was poured and the steel structure above was erected, we formed and cast the hearth for the lower fireplace. After partially stripping the forms, the soapstone firebox was constructed;
bytor is offline
The Following 2 Users Say Thank You to bytor For This Useful Post:
Calidecks (01-29-2019), Dominion Mas (08-01-2017)
Old 07-29-2017, 07:17 AM   #2
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
Re: Lakeside Contemporary
The completed rough-in with cast concrete mantel and hearth. The final photo gives an idea of the 'space' the fireplace occupies... the large staircase in the background will ultimately be clad with granite slabs.
Lakeside Contemporary-c.jpg   Lakeside Contemporary-d.jpg   Lakeside Contemporary-e.jpg
bytor is offline
The Following User Says Thank You to bytor For This Useful Post:
Old 07-29-2017, 07:20 AM   #3
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
The rough-in continues upwards into the Sunroom above. The upper fireplace is a similar design to the one below but with more generous cantilevers on the hearth and mantel.
Lakeside Contemporary-f.jpg   Lakeside Contemporary-h.jpg   Lakeside Contemporary-i.jpg
bytor is offline
Old 07-29-2017, 07:21 AM   #4
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
Sunroom rough-in complete;
bytor is offline
superseal (07-29-2017), Tscarborough (07-29-2017)
Old 07-29-2017, 07:27 AM   #5
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
We then returned to the lower level and began to install stone. 'Full' bed granite ledge-rock in 3,4 and 7" heights. The stone was laid to match the board-formed concrete foundation... the arris lines jogged in and out somewhat. Laid with a tinted thin-set mortar and backed up with type 's' as needed. A poured concrete chimney cap and metal rain hood topped things off.
Lakeside Contemporary-k.jpg   Lakeside Contemporary-l.jpg   Lakeside Contemporary-m.jpg
bytor is offline
The Following 9 Users Say Thank You to bytor For This Useful Post:
B.Johnson (07-29-2017), Calidecks (01-29-2019), Dominion Mas (08-01-2017), JBM (07-29-2017), jhark123 (01-23-2019), overanalyze (07-30-2017), Philament (08-06-2017), SmallTownGuy (07-29-2017), Tscarborough (07-29-2017)
Old 07-29-2017, 08:10 AM   #6
hdavis's Avatar
Rewards Points: 1,258
Beautiful work!
hdavis is online now
bytor (07-30-2017)
Old 07-30-2017, 07:42 AM   #7
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
The finished outdoor fireplace... the granite ledge-rock forms two columns flanking the fireplace, a flamed slab of black granite was installed over the mantel and below the hearth, an oiled slab of soapstone was installed beside the firebox which is also built with soapstone. It's always nice to be able to see these places after the furniture has been placed... really helps to put things in perspective...
Lakeside Contemporary-n.jpg   Lakeside Contemporary-o.jpg   Lakeside Contemporary-p.jpg
bytor is offline
The Following 5 Users Say Thank You to bytor For This Useful Post:
asevereid (07-30-2017), griz (08-06-2017), KAP (01-13-2019), superseal (07-30-2017), Tscarborough (07-30-2017)
Old 07-30-2017, 07:45 AM   #8
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
...and the finished Sun Room fireplace... similar details as the outdoor fireplace; flamed granite slab above mantel and below hearth; soapstone slab beside firebox; concrete hearth and mantel
Lakeside Contemporary-q.jpg   Lakeside Contemporary-r.jpg   Lakeside Contemporary-s.jpg
bytor is offline
The Following 8 Users Say Thank You to bytor For This Useful Post:
asevereid (07-30-2017), griz (08-06-2017), hdavis (07-30-2017), overanalyze (07-30-2017), Philament (08-06-2017), Rock Headed (08-05-2017), superseal (07-30-2017), Tscarborough (07-30-2017)
Old 07-30-2017, 08:23 AM   #9
hdavis's Avatar
That looks amazing!
bytor (08-05-2017)
Old 07-30-2017, 06:19 PM   #10
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Bravo...spectacular!
Love the soapstone.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
bytor (08-05-2017)
Old 07-30-2017, 06:41 PM   #11
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,500
Simply gorgeous!
overanalyze is online now
bytor (08-05-2017)
Old 08-01-2017, 06:12 PM   #12
Dominion Mas's Avatar
Trade: Masonry
Rewards Points: 44
On other projects I remember that you treated outdoor masonry a little differently than you did indoor...namely "jointless"work inside became "tight joints but still joints" outside. This one looks like it's "jointless" outdoors as well. Because of the thinset or???
Dominion Mas is offline
Old 08-05-2017, 09:37 AM   #13
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
There is actually a very small (1/8") joint, the thinset is tinted almost black so the joints look like shadow lines. Because it was hard to 'tool' such a small joint, we went a little heavy on the sealer application.
bytor is offline
Old 08-05-2017, 09:40 AM   #14
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
We also installed an Isokern unit in the Living Room at this project. Similar to the other fireplaces, there are cast concrete mantel and hearth. No granite on this one though... slate to left of firebox, soapstone to the right.
bytor is offline
griz (08-06-2017)
Old 08-05-2017, 09:45 AM   #15
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
An exterior shot to lend a little perspective to the building...
bytor is offline
asevereid (08-05-2017), griz (08-06-2017), hdavis (08-05-2017), Philament (08-06-2017), superseal (08-05-2017)
Old 08-05-2017, 05:29 PM   #16
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 662
What is your take on Isokerns?
I've never been real impressed.
artisanstone is offline
Old 08-06-2017, 05:46 AM   #17
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
This is the first one we've ever installed. The only redeeming quality in my opinion, is the speed of installation. The unit was incredibly expensive, and I know I can hand-build a better performing firebox for the equivalent (or less) money.
The Architects had their way on this one.
bytor is offline
Old 08-06-2017, 09:53 AM   #18
KAP's Avatar
Trade: Custom
Rewards Points: 39,816
Beautiful work...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
bytor (08-13-2017)
Old 01-13-2019, 10:50 AM   #19
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
A few nice photos of this project which appeared in a magazine article;
Lakeside Contemporary-1.png   Lakeside Contemporary-2.png   Lakeside Contemporary-3-2.png
bytor is offline
B.Johnson (01-23-2019), Calidecks (01-29-2019), Fouthgeneration (01-23-2019), hdavis (01-23-2019), JBM (01-22-2019), KAP (01-13-2019), pizalm (01-22-2019), SmallTownGuy (01-13-2019), TheConstruct (06-15-2019)
Old 01-22-2019, 10:34 PM   #20
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Do those soapstone bricks float around much? Looks great!
JBM is offline
Lakeside Shanty bytor Masonry Picture Post 61 07-15-2014 04:08 PM
Remodeling Show October 17-18 Lakeside Center at Mc Cormick Place, Chicago CompleteW&D General Discussion 23 10-20-2013 08:57 AM
