Help. My First Side Job. - Masonry Picture Post - Contractor Talk
Old 01-17-2017, 08:04 PM   #1
Adam318's Avatar
Trade: Masonry
After 3 years of laboring and 1 year of apprenticing I've got my first side job this weekend. A friend of a friend's mailbox was ran into and needs to be fixed. I told her I could do it this Sunday. I was thinking about using a chipping hammer to take down the top 5 courses, replacing the metal box, the laying the brick back ( I'm going to talk to the local brick supplier tomorrow to see if he has the right brick I need to replace the couple that are broken and to buy the mortar). Any constructive criticism would be appreciated ( such as is that how you would do it).
P.s. I've been on this website a lot in the past year and really enjoy looking at the pictures y'all post.
Help. My first side job.-img_0072_1484701354160.jpg   Help. My first side job.-img_0073_1484701385404.jpg   Help. My first side job.-img_0074_1484701412117.jpg
Adam318 is offline
Old 01-17-2017, 09:46 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
Re: Help. My First Side Job.
do your client a favor.....
take it all the way down.....
have the mail box fabricated out of 1/2' plate.....
mount it to a 6x6x1/2 sq tube 4' in the ground.....
then add the brick.....
griz is online now
NJGC (01-18-2017)
Old 01-18-2017, 12:26 AM   #3
avenge's Avatar
Rewards Points: 302
And while you're at it move it over, it looks haphazardly placed being partially on the driveway as if the bricks were just placed around the existing mailbox..
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
CharlieDelta (01-18-2017)
Old 01-18-2017, 12:37 AM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,170
Just more surface area for bird ****.
Calidecks is offline
Old 01-18-2017, 07:34 AM   #5
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,798
Looks like it is sitting on the curb, was it built that way or did it get bumped?
Windycity is online now
Old 01-18-2017, 02:28 PM   #6
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
Matching those "builders Crap" sized brick will be tough, were they used on the house? there 'might' be one or two laying around.....
No hammer, use a large saw, cut off the mortar and relay. worst case use the ringer in rear, and stain them.
Don't forget the colored mortar...
A totally new one with a news paper hole (legal for the daily paper/adverts) would only be a few hundred more....
You can build these in your heated garage during layoffs and set them like a stone on a frost footing.....
Brick coping NOT RECOMMENDED...
Fouthgeneration is offline
Old 01-18-2017, 04:48 PM   #7
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
I usually take stuff like that apart with a cold chisel. Takes 30 minutes.
JBM is offline
Old 01-18-2017, 07:42 PM   #8
Adam318's Avatar
Trade: Masonry
The mailbox was moved when it was hit.. I went over to her house when I got off and beat the box out so it would open and close until I can fix the whole thing Sunday. the homeowner said she found 6 bricks in the garage but they don't look the same? Your right fourth generation I'm going to try and talk my boss into letting me borrow the quickie saw over the weekend and take it down that way. The brick and mortar are really dirty, I'm pretty sure it's just regular grey mortar. I just left the hardware store with her new mailbox I'm putting in.
Adam318 is offline
Old 01-18-2017, 08:19 PM   #9
avenge's Avatar
Rewards Points: 302
So the mailbox was moved when hit onto the driveway but yet there was green grass under it?
avenge is offline
Old 01-18-2017, 08:27 PM   #10
Trade: Masonry
On second thought I'd take it apart as little as possible relay just the damaged joints. and whip some brick colored patch mud for the one missing piece, or just saw a tile brick face piece that is close in color and texture.
WHERE IS THE INSURANCE MONEY, unless the homeowner hit it or the Mailperson?
Old 01-18-2017, 09:05 PM   #11
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Look at picture #2, the mailbox is not on the edge of a driveway, it's on the edge of a sidewalk leading to the front door.
P42003 is offline
Old 01-18-2017, 09:21 PM   #12
avenge's Avatar
Rewards Points: 302
Either way doesn't matter if it's a driveway or sidewalk.
avenge is offline
Old 01-21-2017, 04:29 PM   #13
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
1. You're not going to find those brick anywhere, you might find something close but not those exact brick.
2. Your chances of tearing the existing brick out and cleaning them enough to be relaid are slim and none unless you cut them out with a saw/grinder and grind the mud off each brick individually. You might get lucky and they filled the inside with the same brick and just stacked them in there dry, might be able to get enough to relay the top of the mailbox.
3. Looks like faded black mud to me.
Kniggit is offline
The Following 2 Users Say Thank You to Kniggit For This Useful Post:
brickhook (01-21-2017), Fouthgeneration (01-21-2017)
Old 01-22-2017, 03:43 AM   #14
Windycity's Avatar
Trade: Masonry
I agree, for a the hassle of trying to match bricks you are better off tearing it down and rebuilding it anyway. But looking at the pictures i would guess the bricks clean easily. It doesn't look like there are any damaged bricks
If bricks are damaged you can take the top bricks off, clean them and install a limestone cap in place of the bricks..
Personally I would tear it down and replace it with something more appealing because its ugly
Old 01-22-2017, 10:15 AM   #15
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
...good time to buy your own saw so you can start building your own tools..this way you can claim it on your taxes
Tom Struble is offline
Old 01-22-2017, 01:14 PM   #16
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
The problem is they're 5 hole brick, hard fired, next to impossible to get them out without them breaking, especially with just a hammer and chisel.
Kniggit is offline
Old 01-22-2017, 02:30 PM   #17
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Whats with the corner detail on the top course ?.
sunkist is offline
Old 01-22-2017, 04:23 PM   #18
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
Hiding the holes in the brick
Kniggit is offline
Screw gun keeps tearing paper on tapered side??? Spencer Drywall 13 02-20-2013 10:11 AM
question on pricing a side job contacts General Discussion 5 01-29-2013 07:12 AM
Thinking of going out on my own, but on the side jegolopolli General Discussion 1 09-17-2010 03:30 PM
steep hill on side of building, safety issue? camoner Painting & Finish Work 22 04-24-2009 06:43 AM
exterior Concrete side walk enforcement maghazadeh Concrete & Paving 4 08-30-2008 07:58 PM
