Has Anyone Ever Seen Concrete Disintegrate Like This? - Masonry Picture Post - Contractor Talk
Old 07-01-2017, 10:53 AM   #1
Shaffer's Avatar
The mudslab in this picture had the following characteristics:
-3 inch mudslab
-no reinforcement
-Poured in West Michigan in the summer time.
-Placed on subgrade that had passed a test from an independent agency. It was reported, however, that the subgrade was somehwat dry.
-Allowed to cure for about six days.
-Forklifts were driving on it during steel erection.
-80% cement mix
Here is the tricky part. I know a myriad of the reasons I listed could have contributed to issues. The mudslab was supposed to crack, we just wanted it as a base for the actual slab. However, nothing listed would be a legitimate reason for it to totally disintegrate the way it did. I know running forklifts with steel will crack it and I know a dry subgrade will pull the moisture from the mudslab, but we have done this exact same pour tons of times with great results. Does anyone know what this could be?
Shaffer is offline
Old 07-01-2017, 11:22 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Has Anyone Ever Seen Concrete Disintegrate Like This?
Without having witnessed the placement of the concrete,it would be conjecture on my end to throw out a cause,many variables . What was the slump,was water added on site,was bleed water present,was it floated or troweled into slab,why was the sub base not dampened,how was it cured,compound,periodic wetting and drying etc.etc.?
fjn is offline
Old 07-01-2017, 11:42 AM   #3
Shaffer's Avatar
It was watered on site. I was not on site either but it seems that the slump was not enough originally and they poured too much water, sending it upward of 6". This was also corrected very quickly from the report. I believed it was actually laser screeded. The big thing about this is it wasn't meant to be a big deal. It was just supposed to be a base instead of pouring the slab on top of the subgrade. We expected deformaties and cracks, but I can't figure out what would cause such disintegration. I was literally picking up chunks and pulling out the river rock (aggregate) as if there wasn't any adhesion whatsoever. I don't think there was a cure.
Shaffer is offline
Old 07-01-2017, 12:43 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,112
Could also be a bad mix. Not enough cement.
Also too much water and dried out too quick.
griz is online now
Calidecks (07-01-2017)
Old 07-01-2017, 01:06 PM   #5
Tscarborough's Avatar
Rewards Points: 1,460
There really are no conditions under which properly batched and dispatched concrete will disintegrate like that. Tear it out and try again.
Tscarborough is offline
The Following 3 Users Say Thank You to Tscarborough For This Useful Post:
Calidecks (07-01-2017), Joasis (07-02-2017), parkers5150 (07-05-2017)
Old 07-01-2017, 10:21 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,354
I'll see less concrete in my life than some of you guys will see in a period of 5 years I'm sure. But that looks like a bad mix. Ive never seen anything like that.
Morning Wood is offline
Old 07-01-2017, 10:42 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 6,630
Maybe finished too early without allowing proper bleeding? Where the water is suppose to come to the surface. If it's finished too early it can trap water.
Mike.
_________
Calidecks is online now
Old 07-02-2017, 10:50 AM   #8
fjn's Avatar
Trade: mason
Not too be a wise guy after the fact but this is exactly the reason it is always a good idea to fill a test cylinder of every batch delivered. You don't have to send them off for testing unless you encounter a problem such as this.
fjn is offline
kirkdc (07-02-2017)
Old 07-02-2017, 11:11 AM   #9
Joasis's Avatar
Rewards Points: 1,444
Either cheated on cement, or...poured with a lot of water.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1862 02-15-2020 02:59 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Concrete Floor, no vapor barrier ericomerico Specialty Coatings 6 06-17-2014 08:27 AM
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
