This Could Take A While.... (Yet Another Wood-fired Oven Thread...) - Page 3 - Masonry Picture Post - Contractor Talk
Old 09-18-2012, 06:02 PM   #41
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Re: This Could Take A While.... (Yet Another Wood-fired Oven Thread...)
That's almost looks too good to veneer............
I'm impressed with how clean the entire thing looks, you've obviously thought this through fro some time, and certainly a true artisan..........
From my limited experience with clay bake ovens, I think you may want to add a tad more insulating castable over the top yet........
jomama is offline
The Following User Says Thank You to jomama For This Useful Post:
bytor (09-19-2012)
Old 09-19-2012, 03:56 AM   #42
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
We had a lull in our schedule, so I had the guys help me out for a bit at home...
We added two layers of 2" ceramic blanket over the whole oven, added four inch block and then two layers of 3.5" roxul over the top.
The area at the front was complicated a little by having to work around the steel harness, but we managed to get it pretty well stuffed full of ceramic and roxul.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_3002.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_3005.jpg
bytor is offline
Old 09-19-2012, 03:58 AM   #43
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
Once the insulation was substantially completed, the front face was closed in with a piece of metal.
Time for a beer and a fire.
A little bit of stone started as well...
This Could Take a While.... (Yet another wood-fired oven thread...)-img_3016.jpg
bytor is offline
The Following 2 Users Say Thank You to bytor For This Useful Post:
DavidC (09-19-2012), lukachuki (10-25-2012)
Old 09-19-2012, 07:08 PM   #44
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Very cool Bytor! You'll wonder how you ever went without one!
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 09-21-2012, 05:20 AM   #45
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Wow, nice. Industrial grade.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 09-29-2012, 07:02 AM   #46
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
Well... this is where it's at, and where it may stay for a while... time to pay attention to a few other household 'chores' before winter.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_3051.jpg
bytor is offline
The Following 3 Users Say Thank You to bytor For This Useful Post:
DavidC (09-29-2012), lukachuki (10-25-2012), superseal (09-29-2012)
Old 09-29-2012, 07:07 AM   #47
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
The roof in the picture above is 'temporary'. I had some scrap lumber and metal roofing lying around and wanted to at least keep the elements out of the oven so we could continue using it until we get a chance to finish the exterior. I'm hoping to have a local metal guy fabricate a steel roof made out of 1/4" sheet steel which will be rolled into a curve/wave... with no visible 'rafters' etc... i.e. going for something a little 'lighter' looking.
Like this.... kinda... sorta...
bytor is offline
Old 09-29-2012, 10:40 PM   #48
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Truly a work of art
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
bytor (10-18-2012)
Old 09-30-2012, 01:00 PM   #49
Tscarborough's Avatar
Rewards Points: 1,460
Yep, pure art.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
bytor (10-18-2012)
Old 09-30-2012, 01:04 PM   #50
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Your work looks too perfect to be real, once I win the 649 I'l have you build one at my house.
Inner10 is offline
bytor (10-18-2012)
Old 09-30-2012, 03:48 PM   #51
denver 2's Avatar
Trade: masonry
Rewards Points: 75
Bytor,
Beautiful work as always, and a nice design that I might just use latter this fall. Instead of a steel harness do you think a couple 8" masonry buttresses on the arch sides would be sufficient to hold things together without causing too much mass?
denver 2 is offline
Old 09-30-2012, 04:01 PM   #52
It would be too much mass, except for a commercial bread oven. Personally, I do not think the steel was required, in the same instance, I would have done a 1/2" of fiber reinforced parging and called it good. That said, I like suspenders and a belt.
bytor (10-18-2012)
Old 09-30-2012, 04:51 PM   #53
denver 2's Avatar
Trade: masonry
Rewards Points: 75
Tscarborough,
I'm not familair with fiber reinforced cement. Is this a readily available product and who sells it. Thanks.
Denver
denver 2 is offline
Old 09-30-2012, 05:22 PM   #54
Read the thread below this one.
Old 10-18-2012, 03:53 AM   #55
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
It seems that this summer/fall has been the season of 'delays' on our jobs. The latest delay did allow for a bit more work to be done at home.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_0959.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_0960.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_0961.jpg
bytor is offline
DavidC (10-18-2012), lukachuki (10-25-2012), Tom M (10-18-2012)
Old 10-18-2012, 03:57 AM   #56
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
A lot of rainy weather lately.... built a rather hasty shelter to keep the pizza dry one evening. I will definitely try to incorporate a retractable awning of sorts into the final roof design.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_3103.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_3100.jpg
bytor is offline
The Following User Says Thank You to bytor For This Useful Post:
DavidC (10-18-2012)
Old 10-18-2012, 04:14 AM   #57
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 640
Performance report:
As you may recall, 4 1/2" hearth over 6" rigid insulation, 4 1/2" walls and 5 1/2 -6" thick vault with 4" ceramic blanket plus an additional 7" roxul over vault.
Typically takes 75-90 minutes to heat to 7-800* hearth for pizza (Cocktails anyone?) If we plug the door immediately after pizza, we will have around 450* the next morning and typically drops around 100* per day.
If however, we have a good long burn, i.e. another couple of hours after cooking, we still have a 550-600* hearth the next day and oven seems to cool more slowly... around 75-80* per day.
This past weekend, did pizza Saturday eve., a three hour burn in total. Baked bread around noon on Sunday on a 525* hearth, roasted a chicken and veg. Sunday eve., Reheated leftovers on Monday eve, and left a pot of baked beans in for the day on Wednesday.
Success.
bytor is offline
The Following 7 Users Say Thank You to bytor For This Useful Post:
brickhook (12-25-2014), DavidC (10-18-2012), dom-mas (02-18-2016), Fundi (10-21-2012), lukachuki (10-25-2012), stonecutter (10-18-2012), superseal (10-18-2012)
Old 10-18-2012, 07:51 AM   #58
Trade: Stonemasonry
Glad to hear it and welcome to the oven builders club! I really like the buttress like base you have going on and the stonework looks great!
The Following User Says Thank You to stonecutter For This Useful Post:
bytor (10-18-2012)
Old 10-18-2012, 07:59 AM   #59
Inner10's Avatar
The stone work is unreal.
Inner10 is offline
bytor (10-18-2012)
Old 10-18-2012, 09:05 AM   #60
It looks great. The performance will get better as it dries out more, although using blankets there isn't that much moisture to start.
bytor (10-18-2012)
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
wood blasting ratherberacin Sandblasting 8 10-15-2012 05:48 PM
going over existing wood shakes davinci Windows, Siding and Doors 33 07-08-2012 07:09 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
