This Could Take A While.... (Yet Another Wood-fired Oven Thread...) - Page 2 - Masonry Picture Post - Contractor Talk
Old 08-09-2012, 04:48 PM   #21
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: This Could Take A While.... (Yet Another Wood-fired Oven Thread...)
Nice, finally someone bonded the arch bricks together. Every time I've seen a barrel vault done people have done single arches in series so they could reuse the centre. Can't stand it.
www.dominionmasonry.ca
dom-mas is offline
Old 08-09-2012, 08:41 PM   #22
duburban's Avatar
Trade: building
Rewards Points: 1,622
looks really good. these must be good clients.
i was a helper on one of these when i was about 18. the innards were precast from italy, base and 4 dome sections. vermiculate insulation and brick on the outside.
i'd like to try to precast one out of that refractory cement but it looks tough to work with. a glass blower showed me how to mix the cement blocks that went into his kilns, it was insanely dry and i doubt i could get it to flow in a mold.
duburban is offline
Old 08-09-2012, 09:07 PM   #23
Tscarborough's Avatar
Rewards Points: 1,430
To me, the difference between a cast oven and a brick oven are the same as for a concrete driveway and a paver driveway: Both will crack (i.e. move), but with the paver driveway all the cracks are pre-engineered and make no difference in appearance or performance.
Plus the material is expensive and requires an expensive and time consuming mold. Just say No! to cast refractory ovens.
Tscarborough is offline
Old 08-14-2012, 04:23 AM   #24
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
It was a rainy weekend...
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2920.jpg
bytor is offline
Old 08-14-2012, 12:59 PM   #25
raskolnikov's Avatar
Trade: masonry
Rewards Points: 258
bytor,
Between you and C.J. I'm a stones throw from digging a hole. I like your approach and the detail, I'll try and pony up and do all the stuff the BIG T. has shared with all of us and make it pretty and workable. I'm really slow to get going on anything at my own hacienda simply 'cause I wan't it better than what's out there, at least in a four state radius. It's just me and Denise has been chiding me for years about it.
D.
raskolnikov is offline
Old 08-14-2012, 06:49 PM   #26
Bytor, how expensive is that foam glass, that looks to be the ideal material.
Old 08-15-2012, 05:41 PM   #27
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
Tscarborough... I paid 5.25/sq. ft for the 3" material (It is also available in 2 and 4"). I wonder if it would be less expensive for you as it is made in the U.S.... It comes in 18" by 24" blocks and cuts like butter with a handsaw.
http://www.glasscellisofab.com/sheet...&%20Blocks.pdf
bytor is offline
Old 08-21-2012, 03:52 AM   #28
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
Apparently I've had these firebrick kicking around in the yard for a while... looking a little 'tumbled' judging by the joints...
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2954.jpg
bytor is offline
The Following User Says Thank You to bytor For This Useful Post:
lukachuki (08-24-2012)
Old 08-21-2012, 03:53 AM   #29
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
The entry...
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2960.jpg
bytor is offline
Old 08-21-2012, 03:56 AM   #30
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
I think I might have created a little too much 'heat sucking' mass around the entry. I plan on cutting a fair amount away and replacing with insulation.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2963.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_2972.jpg
bytor is offline
The Following 2 Users Say Thank You to bytor For This Useful Post:
DavidC (08-21-2012), lukachuki (08-24-2012)
Old 08-21-2012, 03:58 AM   #31
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
Say there friendly moderator... is it possible to move this thread to the masonry picture forum?
bytor is offline
Old 08-21-2012, 07:08 AM   #32
Looks great, so clean.
The Following User Says Thank You to Tscarborough For This Useful Post:
bytor (08-22-2012)
Old 08-21-2012, 04:40 PM   #33
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Did you pour between the opening and the oven itself as well? I've never liked the idea of cutting brick to fit by guess and by gosh. Using refractory seems like a really good idea
dom-mas is offline
Old 08-21-2012, 10:35 PM   #34
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,352
You will be cooking in that before you know it!
www.thewoodfiredenthusiast.com
stonecutter is offline
The Following User Says Thank You to stonecutter For This Useful Post:
bytor (08-22-2012)
Old 08-22-2012, 04:57 AM   #35
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
Yes I did end up pouring right over to the oven.
I had a bunch of Whitacre-Greer firebrick which I used for the oven walls (4.5" by 9") so I had built the side walls to 36" (4 full bricks). I later picked up my arch bricks which are made by Alsey and are in fact only 8 3/4-7/8" long. As a consequence, my vault ended up roughly 3/4" short of reaching the front wall of the oven chamber. I had toyed around with cutting arch bricks to make up the extra length while still keeping a good bond and just couldn't make it work with the number of bricks I had.
So...
I got to this stage and started creating the vent area;
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2920.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_2945.jpg
bytor is offline
Old 08-22-2012, 05:02 AM   #36
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
In this side view you can see the difference in the vault vs. the front wall of the oven.
I played around with trying to figure out a way to bridge the gap with firebrick, but wasn't satisfied that the end result would be very pleasing. In the end, I opted to sculpt a piece of SM to form a plug from the inside and fill the gap with refractory.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2947.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_2946.jpg
bytor is offline
brickhook (12-25-2014)
Old 08-22-2012, 05:05 AM   #37
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
I missed a couple of photos in the sequence, but here you can see the results of the pour from inside and out;
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2952.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_2951.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_2950.jpg
bytor is offline
Old 08-22-2012, 05:13 AM   #38
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
I added a few brick on top to narrow down to my flue size.
I was planning on an 8x8 flue. but may play around with that a little before I close things in. I could easily alter things to suit an 8 x 12 if it provides a better draw. A couple of the small kindling fires I've had have been a little iffy, with some smoke rolling out the front. Of course they've been none too hot and there was always some pretty 'swirly' wind going on...
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2967.jpg
bytor is offline
Old 09-18-2012, 10:28 AM   #39
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
Time flies...
I covered the dome in a double layer of heavy duty foil to provide a bond break before adding a 1.5" layer of castable refractory to beef up the mass of the vault.
In the next pic you can see the refractory layer as well as the harness I had made to counteract the spread of the vault during firing.
I did end up increasing the flue to an 8 x 12... much better
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2985.jpg   This Could Take a While.... (Yet another wood-fired oven thread...)-img_2987.jpg
bytor is offline
Old 09-18-2012, 10:33 AM   #40
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 614
I like this shot... shows the bare bones oven structure... foundation, cast arch, hearth insulation, vault, entry, harness, vent, etc. etc.
Looks 'Industrial'.
This Could Take a While.... (Yet another wood-fired oven thread...)-img_2997.jpg
bytor is offline
The Following 3 Users Say Thank You to bytor For This Useful Post:
DavidC (09-19-2012), stonecutter (09-19-2012), superseal (09-29-2012)
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
wood blasting ratherberacin Sandblasting 8 10-15-2012 05:48 PM
going over existing wood shakes davinci Windows, Siding and Doors 33 07-08-2012 07:09 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
