Concrete Walkway - Masonry Picture Post - Contractor Talk
Concrete Walkway
Old 01-25-2016, 07:03 PM   #1
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
Concrete Walkway
Seen this a job I am bidding on, it's a concrete walkway cut and stained to give a wood appearance.
Pretty cool.
Concrete walkway-imageuploadedbycontractortalk1453766655.487398.jpgConcrete walkway-imageuploadedbycontractortalk1453766678.230455.jpg
S.U.M is offline
The Following 8 Users Say Thank You to S.U.M For This Useful Post:
asevereid (01-26-2016), brickhook (01-26-2016), fjn (01-26-2016), Fundi (01-27-2016), going_commando (01-26-2016), Golden view (01-25-2016), jhark123 (01-26-2016), Philament (01-25-2016)
Old 01-25-2016, 07:10 PM   #2
Walraven's Avatar
Trade: carpenter/joiner
Rewards Points: 372
Re: Concrete Walkway
That is freaking cool looking.
Walraven is offline
Old 01-25-2016, 07:16 PM   #3
carp.addict's Avatar
Rewards Points: 392
Wow, I wouldn't even know where to begin, that's a work of art.
carp.addict is offline
Old 01-25-2016, 08:03 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Looks like pavers vs stamped/poured in place to me
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 01-25-2016, 08:07 PM   #5
S.U.M's Avatar
That's what I was thinking when I first seen it super seal, the joints are too uneven to be saw cuts, the homeowner says it was poured and cut but also done before he moved in, Either way its cool.
S.U.M is offline
The Following User Says Thank You to S.U.M For This Useful Post:
superseal (01-25-2016)
Old 01-25-2016, 08:09 PM   #6
Renaissance Man
superseal's Avatar
Here's what I'm thinking...
The Following 2 Users Say Thank You to superseal For This Useful Post:
brickhook (01-26-2016), Chopsaw Chick (01-25-2016)
Old 01-25-2016, 09:02 PM   #7
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
that is cool it does show there are still a few talented guys left out there.
pappagor is offline
Old 01-25-2016, 09:06 PM   #8
tgeb's Avatar
Rewards Points: 1,056
So what are you bidding on, replacing some rotted "boards"?
www.gebcon.com
tgeb is offline
Old 01-26-2016, 08:38 AM   #9
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
I agree with SS that this looks more like a paver vs concrete. Some guys around here does the wood plank stamped concrete, and in no way does it look this good.
But either way, the walks that SUM and SS posted are both beautiful.
brickhook is offline
The Following User Says Thank You to brickhook For This Useful Post:
fjn (01-26-2016)
Old 01-26-2016, 11:33 AM   #10
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Looks really neat. I wonder how they cut it without over cuts ? The stop points are perfect !
fjn is offline
Old 01-26-2016, 03:00 PM   #11
Renaissance Man
superseal's Avatar
That's because they're pavers
fjn (01-26-2016)
Old 01-26-2016, 04:42 PM   #12
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
They do not fit the definition of "pavers" and they look like plant cast uniform width slabs using molds for the surface pattern and a pigmented iron oxide spray before casting (face down). They could be cast in variable lengths (1/3 or 1/5 lengths commonly) or cut to random lengths in the plant - A common European approach.
Pavers are usually set in place and then vibrated into the setting bed to create a uniformly even surface.
Dick
concretemasonry is offline
Old 01-26-2016, 05:36 PM   #13
going_commando's Avatar
Trade: Electrician
Rewards Points: 256
That looks really cool. I didn't know that wood plank looking pavers existed. Definitely making a mental note for those.
going_commando is offline
Old 01-26-2016, 05:52 PM   #14
Renaissance Man
superseal's Avatar
Chepo calls them pavers...http://www.homedepot.com/p/75-sq-ft-...LANK/206503343
Silver Creek calls them landscape tiles....http://www.silvercreeksw.com/barn-plank.htm
They still crack as evidenced by that 1st pic would suggest however.
Old 01-26-2016, 06:35 PM   #15
fjn's Avatar
Trade: mason
One cracking here or there would not concern me much. Just R&R them when needed. My concern,like all concrete pavers,eventually the cement paste wears off and the aggregate becomes pronounced.
fjn is offline
J&L CUSTOM CONCRETE Palm Springs, CA | Custom Concrete Contracting Jack Harris Help Wanted or Looking For Work 0 01-06-2015 03:14 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
Uneven Concrete Meets Subfloor Handy Hero Flooring 6 09-30-2012 04:59 PM
Raised concrete deck Bearded Wonder Construction 10 12-07-2011 02:09 PM
