Clamp Kiln Vault And Chimney - Masonry Picture Post - Contractor Talk
Old 04-05-2016, 11:52 PM   #1
Knows less all the time
Fundi's Avatar
Trade: Brick Contractor, Manufacturer
Rewards Points: 582
Some new stuff for me, and some design to work out. took us awhile and we still have some finishing up but yesterday the chimney worked.
the span was 5.5 meters. this was when middle part not finished
the kiln is 8m long and anything inside gets coroded, so I made buttresses. Try to find information on masonry butresses. the poles are temporary.
Fundi is offline
The Following 6 Users Say Thank You to Fundi For This Useful Post:
bytor (04-15-2016), CarpenterSFO (04-07-2016), dom-mas (04-06-2016), Gordon Forsyth (04-14-2016), Rio (04-06-2016), superseal (04-06-2016)
Old 04-05-2016, 11:59 PM   #2
Fundi's Avatar
Rewards Points: 582
Re: Clamp Kiln Vault And Chimney
Fundi is offline
The Following User Says Thank You to Fundi For This Useful Post:
bytor (04-15-2016)
Old 04-06-2016, 12:03 AM   #3
Fundi's Avatar
Rewards Points: 582
Fundi is offline
bytor (04-15-2016)
Old 04-06-2016, 05:21 AM   #4
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
cool looking job how long you been working on it.
pappagor is offline
Old 04-06-2016, 06:10 AM   #5
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
This is really interesting....thanks for sharing the photos!
brickhook is offline
Old 04-06-2016, 07:28 AM   #6
Tscarborough's Avatar
Rewards Points: 1,460
My understanding of a clamp was that there was no permanent structure, the brick of the clamp were part of the firing. Here are some pics of a Mexican clamp. Eventually, all of the brick except for the side walls will be cycled though the center of the kiln.
http://brokebrick.com/brickyard.htm
Tscarborough is offline
The Following 5 Users Say Thank You to Tscarborough For This Useful Post:
bytor (04-15-2016), Eaglei (04-06-2016), fjn (04-06-2016), Rio (04-06-2016), superseal (04-06-2016)
Old 04-06-2016, 09:10 AM   #7
fjn's Avatar
Trade: mason
Rewards Points: 11,202
I had a hunch you were up to something cool,not hearing from you in awhile,this is the reason.
Thank you for sharing,I find that kind of stuff real interesting.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
bytor (04-15-2016), dom-mas (04-06-2016)
Old 04-06-2016, 10:40 AM   #8
Fundi's Avatar
Rewards Points: 582
I thought kiln without permanent walls was scove kiln. Even the pics in your link , those are permanent walls.
But what do i know. ;-) and i figure i know less every year.
http://www.britannica.com/technology...rial#ref609111
" The clamp kiln is an improvement over the scove kiln in that the exterior walls are permanent, with openings at the bottom to permit firing of the tunnels. "
Fundi is offline
Old 04-06-2016, 10:47 AM   #9
You could be right, that was just what they called them. In the last pic, that is an abandoned brickyard and the walls are clearly still standing.
Old 04-06-2016, 10:58 AM   #10
fjn's Avatar
Trade: mason
Here is an interesting book,it sorta weighs in on the topic.
http://collections.infocollections.o...2385e/9.3.html
Click on kiln design
fjn is offline
Fundi (04-06-2016)
Old 04-06-2016, 04:56 PM   #11
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
I stare at your pictures more than any other on CT...you are truly unique and in a class of your own.
I still want to work with you some day
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 04-06-2016, 05:17 PM   #12
fjn's Avatar
Trade: mason
Hey Fundi; here is another book you may like,I own both I have listed and feel you would enjoy / benefit from them. They were actually written regarding projects in your continent.
Enjoy !
http://www.abebooks.com/978352802051...3528020512/plp
fjn is offline
Fundi (04-07-2016)
Old 04-06-2016, 05:47 PM   #13
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Love it! Absolutely love it. Beautiful and industrial...the best of all worlds
www.dominionmasonry.ca
dom-mas is offline
Old 04-06-2016, 06:27 PM   #14
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,234
Even though I'm clueless about masonry, I love these masonry threads. That just looks bad a$$!
Thanks for posting
Philament is offline
Old 04-07-2016, 03:25 AM   #15
Fundi's Avatar
Rewards Points: 582
FJN-
there is one more project almost finished that you in particular will appreciate.
Fundi is offline
fjn (04-07-2016)
Old 04-07-2016, 06:51 PM   #16
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
What a tease
dom-mas is offline
Old 04-08-2016, 04:27 AM   #17
Fundi's Avatar
Rewards Points: 582
Last year I opened a thread asking advise about this chimney. I was hoping you would say something. Would like your comments on this chimney. what would you need to know. I am wondering about going another 100cm higher.
I am wondering about a cap or not.
Fundi is offline
Old 04-08-2016, 05:14 PM   #18
fjn's Avatar
Trade: mason
If you are looking to increase the draw,Not only would I go higher,I would taper the chimney also. Contrary to logic,reducing the dimension of the flue has a very positive effect,it works exactly like a venturi in a carburetor.
fjn is offline
Old 04-10-2016, 12:19 AM   #19
Fundi's Avatar
Rewards Points: 582
Exciting times at the Brick Kiln.
I think i know more about what not to do then I know what to do!
I built the vault under the old existing roof that was rails for rafters and wood for purlins. then TnG then asphalt composite . The asphalt paper never lasts long so it is three layers. In places the purlins touched the outside of vault. In fact it prevented putting the second layer of bricks on the vault in places.
I planned to remove the wood roof after this firing and put something waterproof over the vault.
Lo and behold with the vault closed the heat was incredible (well duh) and started a purlin on fire. The tng and roofing sheets inhibited the fire so mostly the fire followed the purlins, but to put it out we destroyed parts of the roof. Luckily it was noticed and it was put out. so the wood roof only covers half of the vault now.
Now how to make the top of vault water resistant on a brick that can get too hot to touch. Originally i was goin to lay some old 5mm thick plastic (big sheets that are hollow for heating water for swimmng pools), but now i find it could melt.
So I know a bit about what not to do but am not sure the solution. I am leaning towards sand/clay/ lime plaster.
Fundi is offline
Old 04-10-2016, 09:18 AM   #20
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
a plaster sounds like a good idea
dom-mas is offline
Industrial Chimney designs? Fundi Masonry 17 04-10-2016 11:45 PM
