The Building Of A Fire Box. I Think This Is Unique. - Page 2 - Masonry Picture Post - Contractor Talk
Old 10-20-2017, 06:31 PM   #21
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: The Building Of A Fire Box. I Think This Is Unique.
Sorry,forgot the connection.
http://www.pyromasse.ca/articles/htc_e.html
fjn is offline
Stilla (10-20-2017)
Old 10-20-2017, 06:51 PM   #22
Stilla's Avatar
Trade: Finish carpentry
Rewards Points: 598
[quote=fjn;6410265]
Originally Posted by Stilla View Post
I am pretty sure it's not fire clay, the mortar I have seen them use is sand mix. But with that said I am unaware of what fire clay is. Goggle may give me that answer.
I also am unaware of what raked means to a mason, and I am sure goggle doesn't have that answer.
This will help you understand the nuances of laying fire brick. Please not the extremely tight joints,one could barely place a playing card between them.The tight joints and 'special" mortar lends itself to many years of service life.
Also,a raked joint is when the mortar is recessed beyond the face of the brick. Unless my eyes deceive me,that is what the masons did on the subject firebox. Not really the preferred method by most trade standards.
Thanks for the info. These guys made a slurry mortar after the slab was assembled on the floor. They did flush out the mortar with the face of the bricks, with the watered down mortar
I guess there was shrinking of the mortar? That sounds logical to me.
I would like to hear from you, just love learning.
Stilla is offline
Old 10-20-2017, 06:56 PM   #23
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
The most efficient way of doing it the way they did it is to grout bag the joints, unfortunately you can’t get a code compliant mortar using that method.
Looks good, A plus for execution, but I’d rather have a lip here or there with a 2000 degree rated mortar.
Things to be aware of before you start doing the bowing thing to the masons...
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
fjn (10-20-2017)
Old 10-20-2017, 06:59 PM   #24
JBM's Avatar
Trade: Masonry
Not only that but if you don’t have ties in your piers you have a pile of sheot. Hopefully they thought that part through somehow, but it doesn’t look like it.
JBM is offline
Kniggit (10-20-2017)
Old 10-20-2017, 07:03 PM   #25
fjn's Avatar
Trade: mason
Originally Posted by JBM View Post
The most efficient way of doing it the way they did it is to grout bag the joints, unfortunately you canít get a code compliant mortar using that method.
Looks good, A plus for execution, but Iíd rather have a lip here or there with a 2000 degree rated mortar.
Yes,besides not having 2,000 degree mortar,in order for mortar to properly bond with masonry units,it needs to be in compression,as in full shoved joints.That is why in re pointing,it needs to be placed in lifts and compressed with slicker / backfiller and tooled
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
dbrons (10-20-2017), JBM (10-20-2017)
Old 10-20-2017, 07:08 PM   #26
JBM's Avatar
Trade: Masonry
Good point!
JBM is offline
Old 10-20-2017, 07:13 PM   #27
JBM's Avatar
Trade: Masonry
If you guys would join the Facebook group there is a very good mason who builds his back wall plumb, I think with cardboard under where it transitions to a slant, anyways , it’s built plumb the next day he leans it back, puts heat stop under it and in the slants and leans it in. Comes out perfect. 30 years of masonry no doubt helps!
I have a couple of 4’ orton boxes coming up and may try his method.
JBM is offline
Advanced Fire Solutions, Inc. Advanced Fire New Member Introductions 1 12-30-2014 11:21 PM
Building in Sri Lanka Cutonce Construction 20 08-18-2013 08:37 PM
Plenum Insulation Fire Rating ASMCHICO HVAC 3 06-22-2012 09:01 PM
backfill in a building suggestions? Below grade trench's jadleybray Commercial Construction 11 05-31-2012 02:55 PM
Nobody Wants to bid Deutsche Bank Building Now Wolf Demolition 2 08-26-2007 02:37 PM
