Brick Dome - Masonry Picture Post - Contractor Talk
Brick Dome
Old 01-19-2012, 03:11 AM   #1
Knows less all the time
Fundi's Avatar
Trade: Brick Contractor, Manufacturer
Rewards Points: 582
Brick Dome
I was looking for another picture in my files and found this.
Brick dome used as rain water tank. Inside is plastered with waterproof cement. This one holds about 50,000 liters. It catches rain off the kiln and drying shed roofs. although a pure round dome is not good structurally this is back filled and so the pressure from above allows it to work.
I tried dome roofs for residential but they have too much reverberation and echo, and that is how i got into vaults.
Fundi is offline
The Following 10 Users Say Thank You to Fundi For This Useful Post:
Joasis (01-19-2012), jomama (01-19-2012), lukachuki (01-20-2012), Resta (01-20-2012), shanekw1 (01-20-2012), stonecutter (01-20-2012), stuart45 (01-19-2012), superseal (01-20-2012), Tom Struble (01-19-2012), WildWill (01-19-2012)
Old 01-19-2012, 08:13 AM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Brick Dome
Gotta love that access plank.
Why don't you get a 2 X 4 and stand it on edge so the workers have to concentrate on the way to the site.
I just love the dome and vaults, going to find a way to build one someday.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 01-19-2012, 09:39 AM   #3
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Re: Brick Dome
Thats really cool Fundi....and you just gave me a way to top-out the last few courses of my pizza oven domes without a form.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 01-19-2012, 01:15 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Brick Dome
How the heck do you build that?
JBM is offline
Old 01-19-2012, 01:41 PM   #5
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
Re: Brick Dome
You build it with skilled traditional craftsmen.
Dick
concretemasonry is offline
Old 01-19-2012, 02:29 PM   #6
Fundi's Avatar
Rewards Points: 582
Re: Brick Dome
Always wondered why you guys are using forms for pizza ovens. I posted pizza oven made same way, but smaller.
Fundi is offline
Old 01-19-2012, 03:11 PM   #7
Fundi's Avatar
Rewards Points: 582
Re: Brick Dome
I would have to write for hours.
Fundi is offline
Old 01-19-2012, 03:45 PM   #8
JBM's Avatar
Trade: Masonry
Re: Brick Dome
Is it more complicated then 1 on top of 2
JBM is offline
Old 01-19-2012, 03:46 PM   #9
JBM's Avatar
Trade: Masonry
Re: Brick Dome
I guess I shouldnt complain the next time the back wall of a 44" firebox is giving me trouble lol.
JBM is offline
Old 01-19-2012, 04:45 PM   #10
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Re: Brick Dome
I like the strings to hold the brick in place while the mortar sets.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 01-19-2012, 06:23 PM   #11
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Brick Dome
Good luck with that...let me know how it works out for you.
D K & Sons
dakzaag is offline
Old 01-19-2012, 06:27 PM   #12
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Brick Dome
can't ya just buy a big plastic one?
Tom Struble is offline
Old 01-19-2012, 06:33 PM   #13
Trade: Stonemasonry
Re: Brick Dome
Fundi, this is what I used. It is two pieces of rigid foam insulation cut so I can take it out when I closed up the dome.
This is around the time I started using the form.
I am guessing the firebrick over here is harder and heavier than the brick you are using for your dome. You can build a pizza oven dome without a form but it speeds things up because you dont need to hold the brick in place until it sets. Some people use a sand form but I dont because you can keep the brick nice and clean as you build...to each his own. I really like that wire idea!
The Following User Says Thank You to stonecutter For This Useful Post:
Fundi (01-20-2012)
Old 01-20-2012, 12:23 AM   #14
Fundi's Avatar
Rewards Points: 582
Re: Brick Dome
stonecutter how long before you can move the foam?
the wire hooks are nice because you use on any sized dome. If you look carefully the "hook" have Y at the bottom and bent out for loading 3 bricks. Only on the top flatter part do they then use strings to get more tension. The 2x2 is the gauge and sometimes they have a bolt on that to hold the brick but that slows things down.
Hmm foam. You got me thinking as I am building a timbrel arch and foam might be best / cheapest for first row.
Plastic? Last time i checked 50,000 litres plastic was more expensive for me here.
Fundi is offline
Old 01-20-2012, 12:31 AM   #15
Fundi's Avatar
Rewards Points: 582
Re: Brick Dome
Fundi is offline
Old 01-20-2012, 12:32 AM   #16
Trade: siding
Rewards Points: 20
Re: Brick Dome
you masons are a tough crowd
Old 01-20-2012, 12:39 AM   #17
Fundi's Avatar
Rewards Points: 582
Re: Brick Dome
I write slow and i lean towards lazy. should i make a try?
Fundi is offline
Old 01-20-2012, 12:57 AM   #18
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: Brick Dome
Pure genius at work there Fundi - your posts always tickles the imagination that for sure.
That tank should probably be on display at one of the finer art museums
in the world
superseal is offline
Old 01-20-2012, 07:51 AM   #19
Fundi's Avatar
Rewards Points: 582
Re: Brick Dome
We agree the genius is the technology. I imitate proven technology. The only innovation we did is the cutting of the groin pieces.
In my area I would guess there are 500 underground domes, most for making bio-gas so it is a bit ho-hum. Groined vault is another story.
I am glad if it tickles someone's imagination. It also tickles mine. I enjoy looking at interesting work, beautiful work, such as yours.
Fundi is offline
The Following User Says Thank You to Fundi For This Useful Post:
Old 01-20-2012, 08:14 AM   #20
Trade: Stonemasonry
Re: Brick Dome
Fundi, I would say around 15-30 seconds. The foam would hold two bricks so I made faster progress instead of waiting for the mortar to grab. Not that I needed to go fast,this one was at my house..it was a case of impatience. I wanted to fire that oven up!
I am going to try the wire hold with the next dome for sure. I'm thinking if I make 5 wire holds that would be plenty...now its just a matter of finding time to build.
Brickman59 (08-23-2017)
Pref fab brick panel questions charlie lazor General Discussion 8 04-23-2015 09:22 AM
Fix brick outdoor BBQ chance220 Masonry 2 10-11-2010 05:45 AM
The Guy who needs fifty brick Tscarborough Masonry 22 06-08-2010 09:19 PM
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 07:19 PM
