-   Masonry Picture Post (https://www.contractortalk.com/f90/)
-   -   Another Basement Project... (https://www.contractortalk.com/f90/another-basement-project-329562/)
brickhook 03-05-2017 12:26 AM
3 Attachment(s)
We got this basement finished up Friday...
brickhook 03-05-2017 12:32 AM
2 Attachment(s)
This basement took a few days....glad it's done :thumbsup:
greg24k 03-05-2017 02:00 AM
Nice and clean masonry work :thumbsup:
superseal 03-05-2017 08:27 AM
Firebox laid right...is that refractory mud?
brickhook 03-05-2017 08:57 AM
No, it's 'S' type....inspectors are good with everybody using 'S' type here, still. You cant buy refractory mortar at any of the block yards around here
Tscarborough 03-05-2017 01:30 PM
-You should at least make the joints as thin as possible, 1/4 or so.
griz 03-05-2017 01:48 PM
clean looking block work...:thumbsup:
nice to see someone still knows how to build a masonry fireplace...:thumbsup:
brickhook 03-05-2017 02:46 PM
I understand what you're saying and you can lay them tight with refractory mortar, but you cant lay a solid firebrick that tight with regular mortar. You would have to shake your regular mud so thin it wouldnt be any good and couldnt get a good looking job that way.
The joints on this box is 3/8" and I know I build fire boxes differently than our friends up north but this style of box works great and I never had any trouble of box burning out.
Warren 03-05-2017 04:00 PM
I have seen a lot of block foundations, but have never seen one with the firebox laid up that early. We are always under roof before they come back and lay that up.
brickhook 03-05-2017 04:06 PM
In this case, I have two intersecting walls with a tri-angle chimney base and a thimble and flu on the back side. Just make since to get the fireplace and chimney base done before they start framing.
brickhook 03-05-2017 04:50 PM
3 Attachment(s)
I like building our chimneys and getting out before the carpenters start framing or before they set trusses.
brickhook 03-05-2017 07:23 PM
1 Attachment(s)
I dont like the hearth on this one but this had to match the other chimneys in the house
