Wirsbo Connection Question - Plumbing - Contractor Talk
Old 08-23-2018, 10:52 PM   #1
PeterB's Avatar
Trade: General
Rewards Points: 38
Hi guys,
I don't normally frequent the plumbing section so this might be a dumb question.
Can one use a non pro-pex fitting like an elbow or tee with Wirsbo expansion fittings?
Thanks,
Peter
PeterB is offline
Old 08-24-2018, 08:50 AM   #2
duburban's Avatar
Trade: building
Rewards Points: 1,650
Re: Wirsbo Connection Question
I'm not a plumber. BUT I think you asked a good, nuanced question.
I believe it comes down to this:
https://www.uponor-usa.com/residenti...wner/faqs.aspx
and the real question is, does your non uponor fitting have a rating for Pex type A.
But even if they allow it, seems like intermixing systems is a little whacky.
duburban is online now
The Following User Says Thank You to duburban For This Useful Post:
PeterB (08-24-2018)
Old 08-24-2018, 10:03 AM   #3
PeterB's Avatar
Trade: General
Rewards Points: 38
Thanks Dudurban,
I agree that intermixing systems doesn't make a lot of sense.
I guess I just became interested if it was a normal practice for the plumbers out there? ProPex fittings can be harder to find sometimes when other Pex crimp fittings can be found at any big box store.
PeterB is offline
Old 08-24-2018, 05:29 PM   #4
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,146
I see lots and lots of uponor with crimp fittings. The plumbers here like it in the cold, since the propex might not shrink down when it's time to turn the water back on.
Golden view is offline
Old 08-24-2018, 10:36 PM   #5
PeterB's Avatar
Trade: General
Rewards Points: 38
Hi Golden, thanks for the reply! I always enjoy reading your posts as we are in the same town. Congrats on the new place!
Interesting that you see uponor with crimp connections as I knew you can do that but never see that. The only real crimp connections I ever see are DIY jobs, 95% of what I see is expansion connections.
I guess the question about which type of fittings is still up in the air?
Thanks,
Peter
PeterB is offline
The Following User Says Thank You to PeterB For This Useful Post:
Golden view (08-25-2018)
Old 08-25-2018, 10:42 AM   #6
edward trowelhands
Trade: Diplomat
Thanks,
Peter
As far as I know, the major supply houses only sell uponor. It seems to be preferred by pros. They also sell propex fittings and crimp fittings. The stainless steel type are what I see.
edit: I guess what I'm referring to is a clamp fitting.
Old 08-25-2018, 04:58 PM   #7
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,276
Call them cinch here. My old plumber used them. My new plumber couldn’t believe it when I told him. I guess they have a lot of failures.
Big Johnson is online now
Old 08-25-2018, 09:31 PM   #8
PeterB's Avatar
Trade: General
Rewards Points: 38
Thanks for all the replies everyone!
Not trying to beat a dead horse here, but my original question is whether these two different fittings could be used on either type of connection?
Pro-Pex fitting
Crimp fitting
PeterB is offline
Old 08-25-2018, 09:37 PM   #9
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 302
A Wirsbo fitting won’t fit in the pipe with out expanding. So I would say no.
I can't compete with hacks.
donerightwyo is offline
The Following User Says Thank You to donerightwyo For This Useful Post:
Old 08-25-2018, 10:17 PM   #10
edward trowelhands
Trade: Diplomat
Right, didn't understand the question. The propex fittings do not work with any other crimp, cinch, or clamp ring.
Big Johnson (08-26-2018)
Old 08-25-2018, 10:39 PM   #11
PeterB's Avatar
Trade: General
Rewards Points: 38
Well that was easy! I guess I just needed to work on my writing skills.
I guess I could have gotten both and tried it out.
Thanks guys!
PeterB is offline
Question for those of you who have been injured on the job tyb525 General Discussion 15 08-07-2013 12:54 PM
Survey Question: Would you rent your equipment out to others? TheAgent11 Business 17 05-23-2013 03:44 AM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Pex Connection question txgencon Plumbing 9 06-15-2011 05:08 PM
CAT3 for high speed credit card connection KennMacMoragh Low Voltage 13 06-03-2011 12:19 PM
