Why Would You Do This? - Plumbing - Contractor Talk
Old 01-21-2015, 11:03 AM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 19,294
Two bathrooms sharing a wall. Use one sink, fill the other. Nice.
There's so much crap in the way of turning it that I don't even know what to do. Waiting for the plumber now. Bored.
Easy Gibson is offline
Old 01-21-2015, 11:08 AM   #2
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Why Would You Do This?
See that on a lot of houses here.
www.bcconstructionllc.com
BCConstruction is offline
Old 01-21-2015, 11:17 AM   #3
That's so stupid.
Here's the whole thing.
If you just turn that stupid tee 90 south you're golden. Each sink would drain independently without me having to keep a spackle bucket under it until the new vanity is in.
Can I just sick a fernco cap on the stub for the time being?
Old 01-21-2015, 11:26 AM   #4
Trade: Construction
I have stuck caps on them before. I normally modify them at the hub and put new pvc in.
Old 01-21-2015, 11:31 AM   #5
Talking Head
EthanB's Avatar
Rewards Points: 438
Fernco or even a test plug but you want to make sure that baby is TIGHT. I'd leave a bucket under it at night to feel safe.
Planer.....
EthanB is offline
Old 01-21-2015, 11:46 AM   #6
The Following 3 Users Say Thank You to Easy Gibson For This Useful Post:
BCConstruction (01-21-2015), mikeswoods (02-08-2015), Warren (01-21-2015)
Old 01-21-2015, 08:12 PM   #7
rrk's Avatar
Rewards Points: 5,434
You are new at this aren't you? If the other bath is still being used what good would turning the tee do? Most likely that pipe has only a 1/2" opening at 60 years old and probably needs to be replaced.
There are thousands of those around here, if the drain is clear the water will not go in the other sink.
Just remove the adapter and put a plug in.
If those are brass supply lines, don't go anywhere near them without a plumber nearby. They have a tendency to snap just past the fittings.
rrk is offline
illbuildit.dd (01-22-2015)
Old 01-21-2015, 08:18 PM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 458
That is sig line worthy right there!
Warren is online now
The Following 7 Users Say Thank You to Warren For This Useful Post:
Anderson (01-23-2015), asevereid (01-21-2015), donerightwyo (01-21-2015), mikeswoods (01-21-2015), rselectric1 (01-23-2015), sycamorebob (02-21-2015), TimNJ (01-23-2015)
Old 01-21-2015, 09:41 PM   #9
Newish I guess. I've never seen a shared tee that was horizontal. That makes zero sense to me. Why wouldn't you install it vertically then pipe it over to the stack with a90? That way the one drain isn't beholden to the other.
I must be missing something.
Warren, the struggle is real.
Old 01-22-2015, 10:23 PM   #10
Remodeler
mike d.'s Avatar
Trade: Professional Remodeler
Rewards Points: 306
Iam no plumber but here goes. Cut the old close to the stack. Then a no hub,1 1/2 pvc and a wye. The rest would be 90's and 45's. Thats gotta be better than whats there now.
mike d. is offline
Old 01-23-2015, 09:35 AM   #11
Plumber came by and agreed with all of you that this is very common for the time period. He then agreed with me that it's stupid and assured me that it's against code to do new work like that.
I feel better.
Old 01-23-2015, 09:55 AM   #12
MarkJames's Avatar
Rewards Points: 19,531
I feel better.
Easy,
Next time leave the tailpiece attached to the trap (or put a new one there for the time being.) Water will not come out of the top if the open end is higher.
Another thing to do, while you're actually putting it back together is to go to the other bathroom and put a piece of blue tape over the faucet. That says "hands-off" for now.
Edit: my other suggestion would be to wrap a piece of tape over those open angle stops (or put 3/8 compression caps) to keep debris out of them. That will save a lot of aggravation on these jobs. If you forget, just turn them on briefly to clear them, but less messy to cover them.
MarkJames is offline
Easy Gibson (01-23-2015)
Old 01-23-2015, 02:26 PM   #13
I tried leaving the old trap on, but the other sink must be a bit higher. Still leaked when you used the other one. The spackle bucket solution worked fine until I put a cap on it.
I like the thoroughness of covering the valves. I always stuff towels in traps and drains but never thought to cover the little guys. If it makes you feel any better they're getting nipped off and replaced with copper stubs for a clean vanity install. It makes me feel better at least.
Old 02-08-2015, 08:27 AM   #14
maninthesea's Avatar
Trade: High Pressure Air
Rewards Points: 30
I know it's a done deal now, but I think you could have rotated the trap 180 degrees so the bend goes up then back down. It would give you a couple inches.
Temporarily
maninthesea is offline
Old 02-09-2015, 05:15 PM   #15
Too risky.
Fernco cap took care of it real good.
After I put the rock up the homeowner came to look and said, "Why does the wall say 'REPLACE CAP' in giant letters?"
Sometimes I leave notes for future me on drywall.
The Following User Says Thank You to Easy Gibson For This Useful Post:
maninthesea (02-09-2015)
Old 02-21-2015, 01:20 AM   #16
Ron
PerfectCntng's Avatar
Trade: Builder and contractor
Rewards Points: 78
Man, can somebody find the genius who did this job (the first time). No worries I'm sure he's out of work already !! Lol.
PerfectCntng is offline
