Weird Water Heater Tank Connection?... - Plumbing - Contractor Talk
Old 06-30-2012, 12:35 AM   #1
California Contractor
BuenaHomes's Avatar
Rewards Points: 75
can anyone tell me if you ever seen a water heater gas line to be connected to the hole where the pressure valve was, and then from the place where the pressure valve its supposed to be another flex gas line comes out to feed the ingnitor?
I never seen this way for a water heater to be connected. A friend of mine told me that's the way it used to be?
The place where the pressure valve its supposed to be, has this "T" connection where the inlet and outlet gas lines are connected, and they both are hot to the touch due to the fact that they are in close contact to hot water.
Ventura, California, BUILDER
BuenaHomes is offline
The Following User Says Thank You to BuenaHomes For This Useful Post:
MASTERPLUMB (07-14-2012)
Old 06-30-2012, 04:43 AM   #2
Trick1's Avatar
Trade: Plumbing/Hydronic and Steam Heating Contractor
Re: Weird Water Heater Tank Connection?...
A picture would help immensely.
Trick1 is offline
The Following User Says Thank You to Trick1 For This Useful Post:
BuenaHomes (07-14-2012)
Old 06-30-2012, 07:51 AM   #3
txgencon's Avatar
Rewards Points: 448
The way I understand your situation...
With water at 50+ psi and gas at a maximum of 2 psi, seems like water would be forced into the gas line all the way back to the regulator and perhaps beyond.
And I bet all the gas pipe connections would leak like crazy with that pressure.
That can't be right.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 06-30-2012, 12:30 PM   #4
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Question
Originally Posted by BuenaHomes View Post
can anyone tell me if you ever seen a water heater gas line to be connected to the hole where the pressure valve was, and then from the place where the pressure valve its suposed to be another flex gas line comes out to feed the ingnitor?
The place where the pressure valve its suposed to be, has this "T" connection where the inlet and outlet gas lines are connected, and they both are hot to the touch due to the fact that they are in close contact to hot water.
This is a joke, right?
skyhook is offline
Old 07-01-2012, 07:56 AM   #5
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
Sure, that's the gas pre-heater for cold climate applications.
Nah, Im kidding. Sounds like Handyman Harry got in there with a Home Depot 1-2-3 book...
Splinter is offline
Old 07-03-2012, 09:23 PM   #6
paul100's Avatar
Rewards Points: 56
I am not a plumber but i think I know what you are talking about. My sister had this old copper core water heater (37yo heater and still working) in a house she bought and instead of your standard pressure relief valve it used a valve that shut the gas supply off if the temp got to high. The valve was where the current heaters and the pressure relief valve. I figured if the gas shuts off the water stops heating and expanding so the pressure goes down. Here is a link to one. http://www.westsidewholesale.com/aut...215_a_7c575034
paul100 is offline
The Following 2 Users Say Thank You to paul100 For This Useful Post:
Rio (10-02-2012), skyhook (07-03-2012)
Old 07-03-2012, 09:49 PM   #7
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 762
how about helping emursely?
sunkist is offline
Old 07-14-2012, 11:07 AM   #8
MASTERPLUMB's Avatar
Trade: GEN. PLUMBING, ELEC, FIRE SPRINKLER
Exclamation
Thats called a Watts 210-5 safety valve in case of high water temperature
it shuts off the gas supply to the heater there by preventing it from
blowing up
They are used in place of a regular t & p valve for a house on slap
when there is no way to run a proper drain pipe from the t & p
MASTERPLUMB is offline
The Following 2 Users Say Thank You to MASTERPLUMB For This Useful Post:
protechplumbing (09-20-2012), Rio (10-02-2012)
Old 07-14-2012, 12:10 PM   #9
King of Caulk
asbestos's Avatar
Trade: Rot warrior
Rewards Points: 170
How can there not be a way to run the drain for a T&P? Here the WH is often in the garage and the T&P goes out the wall.
I am the Sultan, The Sultan of sealants
asbestos is offline
Old 07-14-2012, 12:28 PM   #10
Talking
Yes but we don't all live in the same parts of the country !
while many houses in SO. CA. have their water heaters in a garage or
on the outside of the house,
Many also have in the center of the house,
Or like here in Houston, Texas many are in the attics so you can Imagine
what it must be like when they flood out !
Old 07-14-2012, 03:31 PM   #11
BuenaHomes's Avatar
Rewards Points: 75
Thank you.
Old 07-14-2012, 03:33 PM   #12
BuenaHomes's Avatar
Rewards Points: 75
I figured out thanks to MASTERPLUMB member, he had the right answer, this guy MASTERPLUMB is a walking plumbing encyclopedia he really knows a lot.
MASTERPLUMB (07-24-2012)
Old 07-14-2012, 03:34 PM   #13
BuenaHomes's Avatar
Rewards Points: 75
you are quite right. exactly like that. thank you
Old 07-14-2012, 03:39 PM   #14
BuenaHomes's Avatar
Rewards Points: 75
I found that this way (that I described in the original post) it's not allowed in SANTA BARBARA constructions or plumbing installations. Somehow that's the way it's, but how safe it's..?- I do not know that.
I have only 10 years working as a general contractor in California, and this is something new to me, I still need to learn a lot more, always something new to learn.
Old 09-12-2012, 07:01 PM   #15
BuenaHomes's Avatar
Rewards Points: 75
I'm sorry...the next post its the correct one, I could not figure out how to post the video earlier.
Old 09-12-2012, 07:06 PM   #16
BuenaHomes's Avatar
Rewards Points: 75
This is the same house, as you can see in the video, the water is very bad. We figured that somehow the gas leaked into the tap water supply lines thus causing the water to poison.
Also, I tested the water for lead with one of those Home Depot's Lead test kits and it did shown contaminated water.
+ YouTube Video
Old 09-19-2012, 09:13 PM   #17
Da Grump
plummen's Avatar
Trade: retired plumbing/electrical/hvac
Rewards Points: 298
So what happens when that california dream doesnt shut the heater down and it launhes itself through a wall or the roof like an unguided missile?
plummen is offline
Old 09-19-2012, 09:38 PM   #18
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
go to 1:40 for the good part.
+ YouTube Video
-Dennis
WarriorWithWood is offline
Old 09-19-2012, 09:45 PM   #19
Da Grump
plummen's Avatar
Rewards Points: 298
We blew one up back when I was still teaching to show the apprentices what happens when one goes off,ours had no problem clearing the tree line!
plummen is offline
Old 09-19-2012, 09:57 PM   #20
Tech Geek
I was amazed at how easily it went through the floor joists, ceiling joists, and rafters.
-Dennis
Water Heater Confusion... NeuconRemodel Plumbing 7 01-28-2012 07:33 PM
Overthinking a Hot Water Tank By-Pass bob_cntrctr Plumbing 16 08-19-2010 05:00 PM
Second floor water heater drip pan and T&P drains bob_cntrctr Plumbing 7 08-01-2009 09:58 PM
Water heater right size. flashheatingand Plumbing 0 01-11-2009 03:02 PM
