Tub Spout Sealing - Plumbing - Contractor Talk
Tub Spout Sealing
Old 09-23-2018, 05:47 PM   #1
PootyTang's Avatar
Trade: house painting
Rewards Points: 54
Tub Spout Sealing
Rather than silicone around a tub spout, or shower head outlet escutcheon, is there anything wrong with filling in the gap between the stub out pipe and the tile hole with silicone? If it's filled in completely, it seems that no water would get into the wall, maybe some behind the spout or shower head escutcheon, but it runs out the bottom anyhow. It saves from the eyesore and hassle of caulking on the outside of those parts. Thanks a lot.
PootyTang is offline
Old 09-23-2018, 09:47 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,551
Re: Tub Spout Sealing
Fill it with plumbers putty.
MarkJames is offline
Old 09-23-2018, 10:13 PM   #3
PootyTang's Avatar
Rewards Points: 54
That's a good idea. Will the putty harden and shrink and leak over time? If I did go with silicone, is that a good or bad idea? Thanks.
Old 09-23-2018, 10:24 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,599
I'm hoping Mark was being sarcastic. Silicone is fine. Though if you need it around the showerhead, something is seriously wrong.
Tinstaafl is offline
Old 09-23-2018, 10:45 PM   #5
PootyTang's Avatar
Rewards Points: 54
Probably don't really need it around the shower head, you're right. But around the tub spout would be necessary. I think the only problem with plumber's putty is that if it hardened and started to leak you wouldn't know until it's too late. The problem with silicone I was thinking is that it would be damn tough to remove it later, but it probably would seal good. Was also wondering if the silicone would corrode the copper pipe. I HATE ugly silicone around chrome and ceramic tile, which is why I was wondering about this whole thing.
Old 09-24-2018, 12:22 AM   #6
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,422
Various modern waterproofing systems seal the pipes behind the tile.
Golden view is online now
Old 09-24-2018, 05:55 AM   #7
Tom M's Avatar
Rewards Points: 4,320
Many of the tub spouts have a foam gasket. Perhaps dress the gasket if worn
Tom M is offline
Old 09-24-2018, 11:46 AM   #8
MarkJames's Avatar
Behind the spout? I've packed that hole with putty on many occasion. Same goes for some valves behind the escutcheons. Who wants to deal with silicone on any future service?
SmallTownGuy (09-24-2018)
Old 09-27-2018, 08:59 PM   #9
PootyTang's Avatar
Rewards Points: 54
OP here. Thanks for the tips everyone. Tom above suggested that some spouts have a foam gasket. Well, I ended finding a 3 1/2 inch trim plate with included gasket that will fit behind the spout. I have not installed it yet but will report back.
https://www.faucetdepot.com/prod/Las...ome-154239.asp
The Following User Says Thank You to PootyTang For This Useful Post:
Tom M (09-27-2018)
Old 09-27-2018, 09:32 PM   #10
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
There shouldnt be any water getting behind the shower head cover all the water is heading down.
As for the mixer valve, on occasion when we have been called in to fix a leak we do a horse shoe of silicone behind the escutchceon.
No plumbers putty
Anderson is offline
Old 09-27-2018, 09:33 PM   #11
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,096
what a weird thread.
SmallTownGuy is offline
Old 09-27-2018, 09:33 PM   #12
MarkJames's Avatar
Is there a gap between spout and wall? If you happen to have a single handle shower valve, maybe your trim plate screws are too tight which will push the spout pipe out of the wall. If so, loosen them up.
Old 09-27-2018, 10:18 PM   #13
PootyTang's Avatar
Rewards Points: 54
OP here. Just to be clear. I am talking here about a tub spout here. Just to remind everyone why I posted, I would like to avoid the ugly mess of siliconing around the tub spout where it meets the tiled wall. I know there are lots of experts that say just run a bead of silicone, and more power to them. The gasketed trim plate link that I showed above simply seals to the tile with a built in gasket, then the spout installs as usual outboard of that. It works like the built in gasket behind many single handle faucet trim rings.
Old 10-05-2018, 08:21 PM   #14
PootyTang's Avatar
Rewards Points: 54
Okay, I finally tried the gasketed plate. Unfortunately, the pipe was too short to allow the extra half inch or so that the plate took up. Still looks like a good idea. Will bite the bullet and silicone like everyone else. Will try to do it as neatly as I can, although silicone gets everywhere when I'm around it. And the more I play with it, the worse it gets...
Old 10-05-2018, 09:48 PM   #15
John the Builder
No, not everyone uses silicone.
Old 10-06-2018, 06:23 AM   #16
Tom M's Avatar
If the stub out is not sweated on you can get a shorter brass nipple to bring the spout tighter to the wall.
Tom M is offline
Sealing Stamped Concrete Bill Butler Masonry 1 06-02-2013 04:51 PM
Sealing all sides of hardwood decking DeckPros Decks & Fencing 56 02-16-2013 01:27 PM
2 showerheads and one tub spout oquela Plumbing 8 12-23-2012 12:06 AM
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
Sealing tile and or stone? nailkiller1 Tiling 7 02-07-2011 11:32 PM
