Tired From Cutting And Nailing Through Copper Pipes And Paying For Damage - Page 2 - Plumbing - Contractor Talk
Old 10-25-2014, 11:48 PM   #21
jb4211's Avatar
Rewards Points: 2,306
Re: Tired From Cutting And Nailing Through Copper Pipes And Paying For Damage
I'm not sure how or why it keeps happening to you.
But, just my unsolicited two cents, I've seen it before during the demo phase. I think a lot of people think of demo as just removing the old to make way for the new. But, there's really a skill involved so you don't make additional work by piercing water lines or cutting wires, etc.
To this day I learned one of my most valuable lessons reading these threads. The thread was about an HVAC contractor who pierced a water line installing base molding. The pipe didn't leak for two months. But it was a commercial apartment building. When it leaked, it flooded the lobby, ruined computers, etc. His insurance didn't cover the damage because it was not related to HVAC. He was phucked.
I'm sorry your going through a tough time. But, experience is the best teacher.
Jon
jb4211 is offline
The Following 2 Users Say Thank You to jb4211 For This Useful Post:
flashheatingand (10-26-2014), tenon0774 (10-26-2014)
Old 03-26-2015, 06:48 PM   #22
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,741
Well at last I didn't set a couple buildings at fire and some buildings collapsed. Once I read - in construction job if you do mistake it can be disaster or catastrophe. In computer job if you do wrong you press esc button and start again. Again they are better paid then us.
tipitop is offline
Old 03-26-2015, 07:05 PM   #23
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
What building collapsed?
Do you have any pictures?
NKLHD
knucklehead is offline
Old 03-26-2015, 09:47 PM   #24
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
Originally Posted by tipitop View Post
Well at least I didn't set a couple buildings at fire and some buildings collapsed.
He may be referring to lower Manhattan today.
Splinter is offline
Old 03-26-2015, 09:50 PM   #25
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,237
They said it was a gas explosion yet no one smelled gas or reported smelling gas.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 03-27-2015, 12:03 AM   #26
tipitop's Avatar
Trade: carpenter
Just that. Evidently some poor plumber did something wrong. Now they will take him apart.
tipitop is offline
Old 03-27-2015, 06:21 AM   #27
rrk's Avatar
Rewards Points: 1,642
Gas Co. was there an hour before the blast. New gas line in building failed inspection, they were told to fix it. Boom
Not ConEds gas line, private contractor
http://nypost.com/2015/03/26/nyc-building-collapse/
rrk is online now
Old 03-27-2015, 06:23 AM   #28
rrk's Avatar
poor plumber? It's a bit bigger problem
rrk is online now
Old 03-27-2015, 06:55 AM   #29
GO Remodeling's Avatar
Rewards Points: 96
here some tips:
Stop with the sawzall! use a hammer to punch across the drywall. The sawzall can be used for cleaning up the edges when you know what's in the wall.
Or, set your cordless circular saw to 1/2" and cut the drywall.
Before you close a wall, take a picture and mark all pipes on the floor with marker or tape.
Nail plates are code probably everywhere. Use them or make sure the plumber does.
Shorter nails and glue the trim in areas with pipes.
GO Remodeling is offline
Old 03-27-2015, 07:53 AM   #30
mako1's Avatar
Rewards Points: 1,094
In 40 years in the business I've never run into this problem.As was mentioned ,you may need to bid your jobs a little higher so you can slow down a little and not have these issues.
I did tear a wall out one time and found a nail thru a waterline that had probably been here for years.Not leaking a bit until I pulled the nail to repair the line.
mako1 is offline
Old 04-01-2015, 08:34 AM   #31
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,348
Having torn off drywall and seen both water and electric notched into the surface of the framing instead of through the center of the studs, I have some empathy for people who have this happen. In some situations you can do everything right and just happen to win the crappy lottery.
I had the opposite happen on a siding job I was on. Somewhere in the last 100 years an electrician had run a line between the studs and the old sheathing. Our nailing depth was exactly what it should have been for the siding patch we were doing, but there's no accounting for a line where it shouldn't be.
I feel for you, OP.
Ethan had the most important post in this thread though. Electric and water mains should be located as the first thing you do on pretty much any job. Walking around the basement looking for a water shut off might seem like a waste of a perfectly good 5 minutes on a basic trim installation, but it's what I was taught to do and it has served me well. Having the water shut off in seconds as opposed to minutes can save you some serious coin!
Easy Gibson is offline
The Following 3 Users Say Thank You to Easy Gibson For This Useful Post:
flashheatingand (04-01-2015), rrk (04-01-2015), Tom Struble (04-07-2015)
Old 04-07-2015, 08:24 AM   #32
madmax718's Avatar
Trade: General
Rewards Points: 3,272
notching off the surface is not uncommon for electrical retrofits.
Demo work can be a lot like archaeology. You think its supposed to be 20 feet down, but that doesn't mean you start work with a back hoe.
madmax718 is offline
Old 04-07-2015, 09:03 AM   #33
hdavis's Avatar
Rewards Points: 3,002
Originally Posted by olzo55 View Post
here some tips:
This is pretty much it. If it's really iffy, use a hand tool to finish your cut.
hdavis is offline
