Things Are Smelly Since Hwt Changed - Plumbing - Contractor Talk
Old 03-22-2010, 09:37 PM   #1
Willie 2's Avatar
Trade: Architectural Hardware Installer
Location: Southern Manitoba Canada/ Retiring to British Columbia 2011
Rewards Points: 150
Hi to all, recently I changed our 50 gallon gas HWT to electric. Nothing else has been altered but now we get smelly hot water every 25 days or so. It is only 7 months old now. I have changed out the anode rod just in case but it makes no difference. I've raised and / or lowered the water temp, the heaters are both operating as per the manual as I clipped on a couple of test lites to monitor them over a 24 hour period. The only temporary cure is to drain the tank down at least 1/2 way and refill. Good for about another 25 days or so. Only the wife and I live here. Looking for an answer or an explanation. Thanks
Willie 2 is offline
Old 03-23-2010, 07:28 AM   #2
Willie 2's Avatar
Rewards Points: 150
Re: Things Are Smelly Since Hwt Changed
Anyone care to comment ???
Willie 2 is offline
Old 03-24-2010, 12:00 AM   #3
leoacrh's Avatar
Trade: HVAC
It's called hydrogen sulfide gas, try draining the waterheater completely and add a little bleach solution to disinfect the bacteria in the tank and turn the thermostat up to 160 for a few hours to kill the bacteria, flush the tank real good and see if that works for you
leoacrh is offline
The Following User Says Thank You to leoacrh For This Useful Post:
Willie 2 (03-24-2010)
Old 03-24-2010, 08:51 AM   #4
Willie 2's Avatar
Rewards Points: 150
Can this bacteria growth happen within three months of new ?? Is it possible that because I bought a cheaper priced tank I am paying for it now or could it be my water ( comes from a well, no treatment besides a water softner ) reacting with the electric elements vs the old gas burner.
Willie 2 is offline
Old 03-24-2010, 09:04 AM   #5
leoacrh's Avatar
Trade: HVAC
yes it's most common in well water
leoacrh is offline
Old 03-24-2010, 12:48 PM   #6
Willie 2's Avatar
Rewards Points: 150
Meaning that the well water is reacting to the electric heating elements as compared to a below the water gas heating element ? We've lived here for 22 years, no smelly water until we changed over to electric so I just want to sorta confirm that it is the heating medium that is causing the smell. BTW the cold water has no smell if that helps to pin point the cause.
Willie 2 is offline
Old 03-24-2010, 04:22 PM   #7
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Yep bacteria in the water.
do as another poster suggested and run the temps up high for a day ( be careful)
remove the anode rod or replace with an aluminum one if one is made for your tank. These really bring out the rotten egg smell.
Finally replace the tank with a Vaughn stone lined tank that does ot require an anode rod and does not have one installed.
BTW the vaughn's are about 4-5 times as much as the ones in HD or Lowes. but they will last about 4 times longer depending on how aggressive your water is.
naptown CR is offline
The Following User Says Thank You to naptown CR For This Useful Post:
What do you do different, let's here the little things that you do that set you apart Mike Finley General Discussion 63 06-14-2010 01:43 PM
The most important things Pug General Discussion 32 12-25-2009 08:55 PM
what are your hobbies? things you do for fun? freemason21 Off Topic (Non Trade) 32 12-09-2009 02:56 AM
things i miss Higgs General Discussion 1 09-13-2008 01:07 PM
