Tankless The Way To Go? - Plumbing - Contractor Talk
Old 01-14-2011, 08:45 PM   #1
Lenny Ambrosino
MasterBuilt's Avatar
Trade: General Building, Maintenance & Repair
Rewards Points: 75
Trying to solve a plumbing problem and as usual getting conflicting information from my pool of plumbers that I use.
Commercial kitchen with a Hobart conveyor style dishwashing machine that uses 8-10 gallons per minute. It has its own dedicated 40 gallon HWH which is not keeping up with the near constant use of the dishwasher.
The closet the HWH is in is not big enough for anything larger than a 50 gallon HWH so I am thinking we need to go tankless. The gas line is 1" feeding from a 3" line about 25' away. One plumber says we need a 250,000 BTU Noritz but we need a bigger gas line, another plumber says no larger gas line needed, and yet another is proposing 2 rinnai tankless units with a bigger gas line. All are in agreement that the double 4" wall vent will have to be replaced.
The HWH would need to bring the water from 60 degrees to 135 degrees so the rinse cycle of the Dishwasher can reach at least 180 degrees.
Any imput on what the best solutiuon would be?
Thanks in advance.
Lenny Ambrosino
Master Built Construction
MasterBuilt is offline
Old 01-14-2011, 08:53 PM   #2
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
Re: Tankless The Way To Go?
How big is the current gasline?
rbsremodeling is offline
Old 01-14-2011, 08:55 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Tankless is a good solution to this problem, but I would get a rep from Noritz or Takagi involved to handle the sizing aspect.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 01-14-2011, 10:09 PM   #4
Lenny Ambrosino
Rewards Points: 75
1" fed from a 3" about 25' above
Thats sounds like a good idea
Lenny Ambrosino
Rinnai tankless water heater RLKMarble Plumbing 18 01-25-2010 01:17 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
trinity Ti 100 tankless coolmen Plumbing 1 10-03-2009 05:25 AM
Tankless hot water systems Custom Renos HVAC 9 02-07-2009 02:41 PM
problems with Rheem tankless hot water heater configuration? KesslerDweller Plumbing 22 05-13-2008 11:35 PM
