Tankless Water Heater As Pool Heater - Plumbing - Contractor Talk
Old 04-17-2019, 05:54 AM   #1
pjdenterprises's Avatar
Trade: General Contracting
Rewards Points: 26
I have an NG fired tankless water heater in the back left corner of my cabana which is used to heat up a bar sink, bathroom sink and bathroom shower.
I am installing a pool this week that is literally 7í off of the back left corner of my cabana.
How could I integrate this tankless heater to heat my pool system ? Has anybody done this before. Again it is not a tankless Boiler it is a tankless hot water heater. Is there anyway to install an aqua stat to this? Can I loop it from the return from the pool?
Please advise. Thank you.
pjdenterprises is offline
Old 04-17-2019, 06:56 AM   #2
justinramani's Avatar
Trade: Flips
Rewards Points: 8
Re: Tankless Water Heater As Pool Heater
How would that work? Pool pumps recycle pool water. Your tankless would be feeding fresh water into your pool causing it to overflow. You also don't want to circulate pool water though your tankless.
Sent from my BND-L34 using Tapatalk
justinramani is offline
Old 04-17-2019, 07:33 AM   #3
diplomat
Golden view's Avatar
Rewards Points: 674
It could be done with a plate heat exchanger set up and two pumps.
Golden view is offline
Old 04-17-2019, 09:48 AM   #4
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,760
You could do it (who knows how long it would last), but you would have to remove potable water from the system.
jhark123 is offline
Old 04-17-2019, 11:06 AM   #5
Rewards Points: 26
@goldenview
Plate heat exchanger and two pumps. Please explain.
I understand the issue of running pool water through tankless heater is no good, however I have heard this setup is possible.
I just donít know where to start. Any ideas on how to do this with some sort of bypass and relay would be appreciated.
Old 04-17-2019, 05:24 PM   #6
diplomat
Rewards Points: 674
One pump to push pool water through the plate heat exchanger. One to push potable water through the exchanger and water heater. The plate heat exchanger keeps the water from crossing over.
Old 04-17-2019, 09:47 PM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 976
Pretty easy to set up. Don't know if it would heat the pool, as I don't know what size pool, and what size tankless heater you have.
Pumping potable water into the pool and overflowing it is not an issue.
You set it up just like a re-circ system in a house, minus the inlet. Thermostatically controlled pump.
Keep in mind, many, if not most older tankless units do not recommend doing a re-circ system. Some would even void the warranty if you did.
My understanding is that the units couldn't handle high inlet water temperatures.
I also have know idea how pool chemicals, especially chlorine, would react with the internal components of a tankless unit, but it's something to keep in mind.
Old 05-13-2019, 11:20 AM   #8
nesc39's Avatar
Trade: general
Rewards Points: 290
Your cabana tankless is not even close to btu to heat your pool. If you wanna try it then just plumb a tee into off your pool filter to go through the tankless in back into the pool. Don’t ask me if chlorine will destroy your heat exchanger
nesc39 is offline
Old 05-13-2019, 09:01 PM   #9
diplomat
Rewards Points: 674
Originally Posted by nesc39 View Post
Your cabana tankless is not even close to btu to heat your pool. If you wanna try it then just plumb a tee into off your pool filter to go through the tankless in back into the pool. Donít ask me if chlorine will destroy your heat exchanger
Most tankless water heaters I install are 199,000 BTU/hour. Similar to many pool heaters.
Old 11-18-2019, 02:50 PM   #10
Ale_Brewer's Avatar
Trade: Industrial Water Treatment
Rewards Points: 14
The heat exchanger that is inside your tankless water heater is meant to work with softened water. The level of hardness in your pool is way more than what's in domestic cold water. This would work with a simple recirc pump but the heat exchanger wouldn't last long.
Ale_Brewer is offline
Tankless water heater freezing Mitch M Plumbing 26 02-27-2018 07:49 PM
trouble shooting water heater Tom M Plumbing 9 02-14-2016 10:12 AM
Question on compacting soil around a pool BCConstruction Masonry 14 09-26-2012 05:38 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
