Sump Pump's - Plumbing - Contractor Talk
Sump Pump's
Old 02-28-2015, 07:53 PM   #1
disenchantedsub's Avatar
Trade: carpentry
Rewards Points: 14
Sump Pump's
Hey guys. Been doing carpentry for over 10 years, but never had to install a new sump pump! . Told the customer I would take care of it, fairly straight forward. My question is has anyone ever tied the discharge into existing drains. There's a nice 2 inch sink drain that I could tie into, and would make life easy. I know that's probably a code violation , but would be a lot easier based on the situation. Its septic, in a condo association. Also is there a minimum length of straight discharge out of the pump before you can turn a 90?
disenchantedsub is offline
Old 02-28-2015, 08:17 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 272
Re: Sump Pump's
You're right, it's a violation. Stop right there.
No minimum straight discharge that I'm aware of.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
disenchantedsub (03-01-2015), greg24k (02-28-2015), mikeswoods (03-02-2015)
Old 02-28-2015, 08:37 PM   #3
General Contractor
greg24k's Avatar
Rewards Points: 8,478
Re: Sump Pump's
What he said, its illegal here also...
greg24k is offline
Old 02-28-2015, 08:44 PM   #4
hdavis's Avatar
Rewards Points: 1,554
Re: Sump Pump's
Originally Posted by tinstaafl View Post
you're right, it's a violation. Stop right there.
No minimum straight discharge that i'm aware of.
x2.
hdavis is online now
Old 02-28-2015, 08:47 PM   #5
Frank Castle's Avatar
Rewards Points: 258
Re: Sump Pump's
Originally Posted by greg24k View Post
what he said, its illegal here also...
x2.
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following User Says Thank You to Frank Castle For This Useful Post:
Old 02-28-2015, 08:55 PM   #6
GettingBy's Avatar
Rewards Points: 6,486
Re: Sump Pump's
Turns out it's not.
The sump may refill at between 1 and 20 GPM and you don't want short-cycling.
Pipe flow resistance for straight pipe or elbows strongly depends on the flow rate and pipe material, this is a very messy calculation.
Will using a flexible hose make it easier?
BTW, "I never lost a cent on the jobs I didn't get!"
"loss aversion refers to people's tendency to strongly prefer avoiding losses to acquiring gains."
GettingBy is offline
The Following User Says Thank You to GettingBy For This Useful Post:
Old 02-28-2015, 08:57 PM   #7
rselectric1's Avatar
Rewards Points: 876
Re: Sump Pump's
I don't think that's legal anywhere. Plus you have to "think like water" sometimes.
The gravity fed drain you were thinking of using relies on gravity for a natural draining function. Blasting pump fed pressure into that scenario would not be a pretty picture.
Picture sump pump water squirting out of the drains. Not to mention blowing trap seals, etc.
rselectric1 is offline
The Following User Says Thank You to rselectric1 For This Useful Post:
Old 02-28-2015, 09:03 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,990
Re: Sump Pump's
Most sumps in the city of Chicago are piped into the sanitary sewer, the city has combined storm and sanitary, it all goes to Stickney.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
The Following 2 Users Say Thank You to KillerToiletSpider For This Useful Post:
disenchantedsub (03-01-2015), hdavis (02-28-2015)
Old 02-28-2015, 09:09 PM   #9
Rewards Points: 876
Re: Sump Pump's
I know that used to be OK and they can't make everyone in those old buildings change.
The OP is going into septic and it's a new install.
Old 02-28-2015, 09:26 PM   #10
Renaissance Man
superseal's Avatar
Rewards Points: 5,836
Re: Sump Pump's
Aside being illegal, it's never a good idea to discharge to a septic.
Chicago must pay dearly treating all that storm water...residents that is.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 02-28-2015, 09:27 PM   #11
The Grand Wazoo
Re: Sump Pump's
It's still OK, where else are they going to put all that water? It's not like these houses have yards to discharge the sump to.
The Following 3 Users Say Thank You to KillerToiletSpider For This Useful Post:
disenchantedsub (03-01-2015), hdavis (02-28-2015), rselectric1 (02-28-2015)
Old 02-28-2015, 09:34 PM   #12
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Re: Sump Pump's
Can't do it here in Naperville. Against code. Doesn't stop a lot of people though.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 02-28-2015, 09:45 PM   #13
The Grand Wazoo
Re: Sump Pump's
The MWRD is mostly funded by fines levied against businesses illegally disposing chemicals and other unwanted things into the sewers.
Old 03-01-2015, 08:12 PM   #14
Trade: carpentry
Rewards Points: 14
Re: Sump Pump's
well looks like ill be spending tomo in the 3ft crawl space, thank you for all the reply's! don't like the flex...
The Following User Says Thank You to disenchantedsub For This Useful Post:
hdavis (03-01-2015)
sump pump change-out cleveman General Discussion 7 07-10-2014 08:10 AM
3" PVC pipe dumpig water into sump pump - what is it? ggsubs Plumbing 9 06-06-2013 07:17 PM
Sump Pump output mpt1123 Plumbing 6 01-19-2010 06:25 AM
GFI for Sump pumps nywoodwizard Electrical 25 12-03-2007 09:11 PM
