-   Plumbing (https://www.contractortalk.com/f9/)
-   -   Sump Pump Back-up (https://www.contractortalk.com/f9/sump-pump-back-up-19506/)
SHORTGUN 03-12-2007 08:14 AM
Sump Pump Back-up
I would like to know what is the best Back-Up Sump Pump System out there on the market?
And if you could gave me the average cost of what they run?
plumber1 03-20-2007 02:14 PM
this will depend on what type of back up pump you are looking for. if you have city water ,a guardian water driven pump is the way to go.that way unless you loose water pressure there is no way for the pump to fail.i dont know who makes a better battery back up pump! cost for water driven installed is about 1200 to 1500$
Toby Collins 03-31-2007 11:54 AM
back Up sump pump
I would suggest you look at the Stevens battery back up. Compare the pumps based on the GPM.
stevenspump(dot)com
Have a great day
747 03-31-2007 05:38 PM
It one that uses water pressure to pump. Its better then battery backup because those are only good for 8 hours. I don't know to much about them but i will find the info later when i get a chance.
747 04-01-2007 12:00 AM
Here is the information.
Guardian backup sump pump (model #747H20)
Manufacturer: A.Y. McDonald Mfg. Co.
4800 Chavenelle Rd
Dubuque, IA 52002
800-292-2737
www.aymcdonald.com
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
