Sudden Drop In Water Pressure - Plumbing - Contractor Talk
Old 07-08-2019, 05:48 AM   #1
292261's Avatar
Trade: Assistant Back End Super.
16 unit apartment complex
1 bath 1 Kitchen 1 dishwasher each. replaced this water heater on this building and now the whole hot water system is lower and it seems like the cold is too.
The systems dropped by anywhere from 10-15-20 lbs.
Im currently at 70 lbs with all the irrigation going we've lost anywhere from 20 - 30 lbs of pressure.
It'll be pressurized pushing around 85-80 and then get a gradual drop by 10- 15 lbs after I starting using the shower hot water.
I cant see the hot water heater but im assuming its around 80-100 gal 18,000 btu gas water heater.
I've checked all the basics.
All valves are fully open, all aerators and mixing valves are clean.
Doesnt look like any piping has been downsized on inlet or outlets.
I'm not sure if they purged the system for air but assume they did & I did a kitchen sink purge myself but I dont think its effective because everybody else in the building would have to have everything closed and off for the sink purge to be effective.
According to water heater manufacturers the volume isnt restricted in water heaters so even if the water heater didnt have the capacity and btu to supply the building the volume of water wouldnt be restricted and not cause lower pressure just the water wouldnt get hot enough.
They added an inline pump but it did hardly anything at all.
I saw something that looked like a check valve that looked like it might be restricting the flow. it looked like a double sided bell fitting but it was one entire piece and i cant indentify the fitting so im assuming its a check valve even though it doesnt quite look like its tapered on each side and narrow in the middle.
I didnt see any expansion tank on this system though to test it.
Im assuming the prv is still good since its been only installed a month ago.
Any thoughts on the culprit and the resolution?
Im assuming it's that fitting I cant indentify cause it wasnt me who installed this.
Thanks
292261 is offline
Old 07-08-2019, 01:59 PM   #2
VinylHanger's Avatar
Rewards Points: 11,536
Re: Sudden Drop In Water Pressure
I'm not a plumber, but you are assuming a lot of things.
Are you a plumber?
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
cedarboarder (07-08-2019)
Old 07-08-2019, 02:10 PM   #3
292261's Avatar
Yes. Im plumber too. Im just looking for answers not attitudes. thanks for trying.
292261 is offline
Old 07-08-2019, 03:01 PM   #4
90%-er
onmywayup's Avatar
Rewards Points: 2,224
Annnddd that's where you most likely lost everyone else that was gonna contribute.
Vinyl had a legitimate question, no matter how it came off to you . I hope you didn't put all your eggs in one basket asking on this forum only
onmywayup is offline
The Following User Says Thank You to onmywayup For This Useful Post:
Old 07-08-2019, 03:04 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 438
Do you call yourself a plumber because you do some minor repairs or are you a bonafide journeyman?
griz is offline
cedarboarder (07-09-2019)
Old 07-08-2019, 03:06 PM   #6
292261's Avatar
Moving along...
292261 is offline
Old 07-08-2019, 03:10 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 438
Who's arguing?
You have been asked legitimate questions that you do not answer.
griz is offline
Old 07-08-2019, 03:52 PM   #8
292261's Avatar
This is how contractors get a bad reputation, someone asks a question. " And who are you? " What does that matter? The resolution is what matters. Please dont represent a contractor or plumber if you have nothing positive to contribute its about working together not against eachother. The attitude gets you terminated from the jobs and your contract cancelled and another tradesman makes the construction industry look like adult children. Thank you.
The only thing I havent checked is a dip tube & Im thinking thats it.
Thanks for demonstrating that we gotta alota work in a business like aspect and not a personal like aspect.
292261 is offline
Old 07-08-2019, 04:05 PM   #9
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,987
Thanks
I'm assuming. I'm assuming. the mother of all f ups is from assumptions.
your hesitations to answer if you are a real plumper is red flag on this forum.
check the prv pressure! your a plumber hey?
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 07-08-2019, 04:05 PM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 438
we ask questions to help us determine the problem and to ascertain your skill level in resolving the issue.
you list your trade as an "assistant back end super".
i have no idea what that title means nor does it give us any insight as to your knowledge/skill/abilities.
in your op you make several broad assumptions that a real plumber would not make.
you come across posing like you are a plumbing pro, however, when your statements or methods are questioned you become irritated.
there is a tremendous amount of experience & knowledge on this forum held by contractors and bonafide tradesmen.
one thing we as a whole are very adept at is sniffing out posters who are neither a contractor or tradesman.
griz is offline
The Following 5 Users Say Thank You to griz For This Useful Post:
A&E Exteriors (07-09-2019), BlueRidgeGreen (07-08-2019), cedarboarder (07-08-2019), onmywayup (07-08-2019), rselectric1 (07-08-2019)
Old 07-08-2019, 06:10 PM   #11
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,002
Sounds like a problem with the Knudson valve.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
The Following 5 Users Say Thank You to KillerToiletSpider For This Useful Post:
A&E Exteriors (07-09-2019), cedarboarder (07-10-2019), Fouthgeneration (07-08-2019), Inner10 (07-10-2019), SmallTownGuy (07-08-2019)
Old 07-08-2019, 06:12 PM   #12
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Dammit Dad !
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
cedarboarder (07-09-2019), Fouthgeneration (07-08-2019)
Old 07-08-2019, 09:24 PM   #13
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,347
I was getting a little chubby, waiting to post, now coitus interuptus...
Check the one way energy saving check balls if used above the new Water heater.
most likely solder lumps on a valve face by over soldering by amateurs...
Divide and conquer, open the line up, install an accurate high flow regulator, measure the gallon per minute in a bunch of 5 gallon buckets or read the meter....over a set time period.
Did you check with the water department for a change in service pressure????
Serviced the various screens and filters as needed?????
Pex loops that collapse/kink up under partial pressure ??????
Foreign matter in the supply lines.....
80 gallons of hot water for 16 units = over priced Flop House IMHO.
You sir are slum superintendent.....
Fouthgeneration is offline
The Following 2 Users Say Thank You to Fouthgeneration For This Useful Post:
A&E Exteriors (07-09-2019), cedarboarder (07-09-2019)
Old 07-09-2019, 10:06 AM   #14
No, he's an assistant back end super...
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
cedarboarder (07-09-2019), Fouthgeneration (07-09-2019)
Old 07-09-2019, 09:09 PM   #15
Trade: Masonry
I'd love to find out what stumped the "back End Superintendent"
Please post the answer.
My next employee that wants a raise, get the title of "Back End super"
And a tee shirt with the title printed on it....
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Old 07-09-2019, 10:59 PM   #16
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,560
Thanks
you blew it right there. it's a "water heater" not a "hot water heater"
sounds stupid because you don't heat water that's already hot
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site.
Irishslave is online now
The Following User Says Thank You to Irishslave For This Useful Post:
Old 07-09-2019, 11:36 PM   #17
test
Trade: General
Good find. I got two 50 gallon tanks in my 6 bedroom house .
We turn on the 2nd tank when we have friends and family stay over.
Old 07-10-2019, 12:19 PM   #18
John the Builder
re the OP post:Couple times in the distant past have had an issue where shutoff valve did not reopen fully.
Old 07-10-2019, 04:24 PM   #19
rselectric1's Avatar
Rewards Points: 884
Don't they sell those at the same place you buy soft water softeners?
rselectric1 is offline
The Following 2 Users Say Thank You to rselectric1 For This Useful Post:
cedarboarder (07-10-2019), griz (07-10-2019)
Old 07-10-2019, 04:30 PM   #20
Fire up the BBQ
griz's Avatar
Rewards Points: 438
Near the post holes...
Often close to the gronesteel valves...
griz is offline
