Stuck Hose - Plumbing - Contractor Talk
Stuck Hose
Old 01-15-2020, 01:46 PM   #1
Tom M's Avatar
Rewards Points: 7,878
Stuck Hose
What are my options sure of hacksaw showing the hose off the spigot?
I tried soaking it with variety of penetrating stuff but it will not come off.
Tom M is online now
Old 01-15-2020, 02:34 PM   #2
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 748
Re: Stuck Hose
Have you tried heating it up with it a torch ?
Molon Labe —— King Leonidas of Sparta
Freedom of choice is what you got
Freedom from choice is what you want—— Devo
Idothat is online now
Old 01-15-2020, 03:37 PM   #3
Tom M's Avatar
Re: Stuck Hose
Yes I did but never bothered. When I remember I hit it with PB blaster to penetrate it but no help
Tom M is online now
Old 01-15-2020, 05:48 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 388
Re: Stuck Hose
I've never had one [yet] that I couldn't get off with channel locks or vice-grips, maybe with another wrench to stabilize the spigot so you don't bust/bend the pipe.
How long has that thing been in place?
Tinstaafl is offline
Old 01-15-2020, 06:08 PM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,348
Re: Stuck Hose
Make a couple of relief cuts on the side of the fitting, perp to the threads with a mini hack saw. Carefully chisel, peel away.
Steve
We Fix Houses is online now
The Following User Says Thank You to We Fix Houses For This Useful Post:
Tinstaafl (01-15-2020)
Old 01-15-2020, 06:23 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 388
Re: Stuck Hose
Yep. I've done that on inside pipe threads. Never needed to on a hose bib.
We Fix Houses (01-15-2020)
Old 01-15-2020, 06:28 PM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,381
Re: Stuck Hose
Hot water, or a light bulb heat for a few minutes then remove........
Towel + hot water...... wear gloves.
Fouthgeneration is offline
Old 01-15-2020, 10:27 PM   #8
Tom M's Avatar
Re: Stuck Hose
Wow just saw Google jumbled my words.....sorry
I will try heat otherwise I'll cut it.
Its been a few years on there.
The spigot is proud of the wall by an inch because I stripped and resided but never got around to reseated/sweating tight to the wall.
I may take the opportunity to install a Frost proof sillcock.
Tom M is online now
Old 01-20-2020, 12:32 PM   #9
Anti-wingnut's Avatar
Rewards Points: 3,426
Re: Stuck Hose
Pipe wrench.
You will win
Anti-wingnut is offline
