Steel Pipe Compression Fitting - Plumbing - Contractor Talk
Old 11-20-2014, 10:05 PM   #1
plazaman's Avatar
Rewards Points: 1,262
Owners recently had Splits systems installed and the existing heaters has been removed and capped. However , some of the pipe is sticking a bit and we cannot remove the pipe and retread. Is there a way we can cut down shorter and install some type of compression fitting ?
plazaman is offline
Old 11-20-2014, 10:19 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 24
Re: Steel Pipe Compression Fitting
Betcha the other end of that pipe is threaded too. Why can't you unscrew it and replace it with a shorter stub (or a plug)?
Tinstaafl is online now
jlsconstruction (11-20-2014)
Old 11-20-2014, 11:31 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,038
That makes way too much sense.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 11-21-2014, 07:53 PM   #4
rrk's Avatar
Rewards Points: 62
If its in NYC it may be in someone else's apt. or China
rrk is online now
Old 11-21-2014, 08:35 PM   #5
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,204
Just convert it into a stylish olde world gas lamp, or if it's a water line - a drinking fountain
dielectricunion is offline
Compression T Fitting vs. Re-Threadding Galvanized Water Main mtbmac Plumbing 49 11-19-2012 11:14 PM
custom bookcases vs. radiator pipe. Rich D. Construction 2 12-13-2011 10:21 AM
Using a compression fitting Willie 2 Plumbing 12 08-16-2010 12:44 PM
Chimney pipe help bsp General Discussion 8 10-23-2009 12:20 PM
