Steam Shower Units And Anti Scald Faucets - Plumbing - Contractor Talk
Old 06-07-2007, 05:15 PM   #1
barehunt's Avatar
Question
I just installed a Steam Showers Inc. shower in a clients home. Model WMK SS-A10. When I had my inspection, I was informed that is does not have an anti scald faucet, which meant that it would not pass inspection. Has anyone ever run into this? What can be done? Is there a way to fix the unit?
Thanks for your help.
barehunt is offline
Old 06-07-2007, 05:48 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Re: Steam Shower Units And Anti Scald Faucets
Did this shower come with a mixing valve installed on it from the factory?
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 06-07-2007, 06:18 PM   #3
Ishmael's Avatar
Rewards Points: 25
According to the specs, that particular model comes with a thermostatic mixer...should be easy to set the temp to whatever the local code requires. I guess I'm confused.
http://www.steamshowersinc.com/WMK_S...r_Unit_87.html
Ishmael is offline
Old 06-07-2007, 08:56 PM   #4
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Who informed you? The inspector?
I don't see how the inspector informed you. Do you mean he asked you for proof it is a pressure balanced valve and you couldn't? If that's the case call the manufacturer and ask them if it is pressure balanced and ask them to fax you something that says it is.
Mike Finley is offline
Old 02-18-2008, 01:30 PM   #5
Remodeling GC
kevjob's Avatar
Rewards Points: 412
thermostatic and pressure balance are 2 different things
kevjob is offline
