Sloan Toilet Valve Leaking From Vacuum Breaker - Plumbing - Contractor Talk
Old 07-29-2016, 10:34 PM   #1
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 352
I removed a toilet in order to replace the flooring and when I put it back in and flushed it water came out of the sloan valve at the vacuum breaker vent. This building has sat empty for a couple of years and I didn't try flushing it before I removed it so don't know if it was bad to begin with or if taking it apart messed something up.
Just wondering what might be the issue when the flush valve leaks out the vacuum vents? Is there some simple things to try before I call my plumber to change out the valve? I've removed and replaced a bunch of these sloan valves when taking toilets out for flooring and never seen an issue like this before. But like I said it may have been bad to begin with. I see they sell a vacuum breaker kit with a new diaphragm. Is that what I need to fix this?
platinumLLC is offline
Old 07-30-2016, 05:17 PM   #2
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Re: Sloan Toilet Valve Leaking From Vacuum Breaker
Yes, the new diaphragm will fix that--simple to install also.
mikeswoods is offline
A question for Sparkies Oberon Electrical 13 06-23-2015 12:39 PM
Circuit breaker panel in cabinet. Davejss Electrical 7 12-10-2012 09:53 PM
water dripping in breaker box, condensation?? nwksremodeler Electrical 23 03-07-2012 08:24 AM
Toilet leaking... Panzer5 Plumbing 3 06-28-2010 05:20 PM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
