Slab Leak - Plumbing - Contractor Talk
Slab Leak
Old 08-11-2014, 07:12 AM   #1
New York City
eastend's Avatar
Trade: historic woodwork restorations
Rewards Points: 396
Slab Leak
I was hoping to get some advice.
Came home last night to a slab leak- domestic hot water- under the tiles in my kitchen.
Trying to schedule plumbers to come today.
Any advice or tips I should be aware of? Would a PEX reroute make any sense?
Are there any alternatives to ripping up the floor?
Thanks for your help.
eastend is offline
Old 08-11-2014, 07:47 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 76
Re: Slab Leak
Hard to say with no idea of how the place is built. How much havoc would have to be wreaked upon the walls, ceilings, cabinets to do that compared to fixing the problem in situ and re-tiling?
Re-doing the floor would probably get you back to full functionality considerably sooner.
Tinstaafl is offline
CarpenterSFO (08-11-2014)
Old 08-11-2014, 11:30 AM   #3
New York City
eastend's Avatar
Rewards Points: 396
Re: Slab Leak
Thanks for your comment.
It does seem easier to bust the floor, fix the pipe, and re-tile- and less expensive as well.
My one concern was about the likelihood of the pipe failing in another spot.
House is a two story colonial, 35 years old, two baths up one down, plus kitchen and laundry on first floor.
eastend is offline
Old 08-11-2014, 12:17 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 76
Re: Slab Leak
Yeah, that's always a possibility. However, unless you have nasty water that eats pipes, it could well be just a poorly done connection that failed. No way to tell of course, without digging it up.
Old 08-11-2014, 01:01 PM   #5
TimberlineMD's Avatar
Rewards Points: 738
Re: Slab Leak
Your going to have other leaks. As soon as you fix one, another will appear. Been there, done that.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
Old 08-11-2014, 02:35 PM   #6
New York City
eastend's Avatar
Rewards Points: 396
Re: Slab Leak
so, then plumber that stopped by says I have 3/4" and he can run PEX through it; which will eliminate the problem, and prevent any future problems with the copper.
Does this seem like a viable solution?
eastend is offline
Old 08-11-2014, 02:52 PM   #7
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,444
Re: Slab Leak
Sounds cool. Im skeptical that he could get it to go through corner and bends, but Im no plumber. If it works that would be an awesome solution.
Metro M & L is offline
Old 08-11-2014, 05:13 PM   #8
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: Slab Leak
I share the skepticism. I'd probably stand there and make sure he poked the pex in one end and it came out the other.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Metro M & L (08-11-2014)
Old 08-11-2014, 10:00 PM   #9
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,984
Re: Slab Leak
Only if it is a straight shot with no changes in direction.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 08-13-2014, 12:14 PM   #10
New York City
eastend's Avatar
Rewards Points: 396
Re: Slab Leak
update: turns out the run was pretty straight and the plumber was successful in getting the PEX through the copper.
So- we are back to being fully functional with no leak. Did not have to break up the floor or reroute. Actually a pretty nice solution.
Thanks to all who commented.
eastend is offline
The Following 2 Users Say Thank You to eastend For This Useful Post:
CarpenterSFO (03-31-2015), mrcharles (08-13-2014)
Old 12-18-2014, 12:16 PM   #11
Rojo68's Avatar
Trade: Plumbing
Rewards Points: 2
Re: Slab Leak
Glad the PEX worked. In the future there's always the epoxy route:
http://www.aceduraflo.com/epipe/process
Rojo68 is offline
Old 12-18-2014, 06:46 PM   #12
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Slab Leak
buy a lottery ticket
You got REAL luck on your side
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Ply on Slab ....yeah I know InterCounty Flooring 1 02-05-2013 10:34 PM
Under slab leak?? 220/221 Plumbing 9 03-20-2010 11:45 AM
Help,under slab hot water leak BE001 Plumbing Picture Post 8 02-20-2010 10:26 PM
HELP!!! Leak under exterior wall on slab jrcuts General Discussion 4 01-09-2009 07:21 PM
leak under sunroom exterior wall on slab jrcuts Framing 7 01-09-2009 06:17 PM
