Shower Valve Rough In - Sweat It Or Female Adapters? - Plumbing - Contractor Talk
Old 03-14-2015, 08:30 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
I've been sweating on pex adapters to my r10000 rough in valve bodies. My plumber used female 1/2 npt adapter with teflon tape and pipe dope.
Its a whole lot faster and simpler for me to use the female adapters.
What is your standard operating procedure?
Also, are you using 3/4 pex when you install onto an existing copper system to keep the same inside diameter. I know you have to have copper from the valve to tub spout but didn't know about the supply lines and line to shower head???
Spencer is offline
Old 03-14-2015, 08:45 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,106
Re: Shower Valve Rough In - Sweat It Or Female Adapters?
Copper from valve to tub spout. Usually sweat in a 90 degree crimp adapter.
overanalyze is offline
Old 03-15-2015, 06:55 AM   #3
dan-the-man's Avatar
Trade: Apprentice Plumber
Rewards Points: 195
Every time we would rough in a shower value if there was PEX ran to it the line going from the value to the shower head would be copper just to give it that added strength. If it were me I would sweat my fittings into the value just because then it is one less fitting on the value that could leak.
dan-the-man is offline
The Following User Says Thank You to dan-the-man For This Useful Post:
mikeswoods (03-15-2015)
Old 03-15-2015, 08:05 AM   #4
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Always use copper for the tub spout or the shower head might dribble when filling the tub.
mikeswoods is offline
Old 03-15-2015, 12:33 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,990
I'd use copper because PEX isn't code approved here.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 03-15-2015, 03:01 PM   #6
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
that is a new one that i have not heard yet
pappagor is offline
The Following User Says Thank You to pappagor For This Useful Post:
illbuildit.dd (04-21-2015)
Old 03-15-2015, 03:19 PM   #7
90%-er
onmywayup's Avatar
Rewards Points: 2,218
I've been using the female to pex adapters for years. Teflon tape and pipe dope, wrench em on there good. Haven't had a problem yet.
I usually drop down galvanized for the spigot.
onmywayup is offline
Old 03-15-2015, 03:32 PM   #8
Dan_Watson's Avatar
Rewards Points: 2,746
I learned this one the hard way awhile ago. Luckily I was able to change it out from the access panel.
Dan_Watson is offline
Old 03-15-2015, 08:22 PM   #9
Livin the dream...
Spencer's Avatar
Yep. I learned the hard way too. First shower I changed out on my own I screwed up on this and it cost me big time.
Spencer is offline
Old 04-20-2015, 10:27 PM   #10
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
Can you explain this? I always run copper for the spout and shower head, but how does pex make the shower dribble? More importantly, how would one stabilize a spout connected with pex?
philcav7 is offline
Old 04-21-2015, 09:04 AM   #11
Livin the dream...
Spencer's Avatar
Inside diameter of pex is less. Creates a back pressure that causes the shower head to dribble when you run the tub spout solo. I've seen guys solve this by using 3/4 pex. Its about the same inside diameter as 1/2" copper.
You stabilize the pex by using a drop ear elbow and screwing it to blocking. Obviously the piece from the drop ear to the tub spout is not pex.
Spencer is offline
The Following User Says Thank You to Spencer For This Useful Post:
aptpupil (04-25-2015)
Old 04-21-2015, 11:33 AM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Aka stacking. It's in the instructions of the shower valve.
Inner10 is offline
Old 04-21-2015, 11:34 AM   #13
Livin the dream...
Spencer's Avatar
Yep. It's very clear after you go back and read them when you screw it up for the first time and have the insert installed and mudded...
Lewis Carpentry
Spencer is offline
shower valve not getting hot water AustinDB Plumbing 13 03-03-2015 02:24 AM
Barrier free shower Charles_cz Remodeling 62 09-18-2012 10:14 PM
Shower valve location Morning Wood Tiling 19 11-28-2011 09:30 AM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
tub spout to shower wand lshomesolutions Plumbing 1 06-08-2010 08:42 PM
