Shower Drain Help - Plumbing - Contractor Talk
Shower Drain Help
Old 07-01-2010, 09:31 PM   #1
Mike song's Avatar
Trade: General contractor
Shower Drain Help
the customer have a 2nd floor bath shower,it is customer build not shower kit, and there is leaking on the firs floor ceiling under the shower base,
they call me ,i went to check and found the shower drain is just a piece of 1.5" abs pipe go through the concrete base with a metal cover on top,
i don't know who did this job ,but anyway the coustomer want to fix it .
there is 1 way i think about is dig a big hole to the rubber sheet,cut 1.5" abs pipe and connet a new shower drain,put back cerment,tile.
where i never have this situation before, do u guys have any idea
Mike song is offline
Old 07-01-2010, 09:41 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 736
Re: Shower Drain Help
Go to the intro section and tell us something about yourself.
If you don't tear out the whole mess & do it right your next post will be "Home owner won't pay what do I do now?"
Maybe Angus can jump in here and explain how. He's one of the resident shower/tile pros.
griz is online now
Old 07-01-2010, 09:48 PM   #3
Remodeling GC
kevjob's Avatar
Rewards Points: 396
Never touch any one eles pan unless you will be tearing everyhting out with a total redo and a minimum 2 rows of tile which will be over drywall so now you will tear it all out, cutomer can't afford let someone else own that piece of crap. you will be sorry if you just try to patch it.
kevjob is offline
Old 07-01-2010, 10:20 PM   #4
Mike song's Avatar
thanks so much guys.
i know what i should do,
either quote for redo everything or just don't touch this crab.
Old 07-01-2010, 10:39 PM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Crabs What did I miss?
Angus
angus242 is offline
Kerdi Drain - before or after shower pan mud? bob_cntrctr Tiling 42 08-16-2012 12:01 PM
new tub over a shower drain swill88 Plumbing 22 04-20-2010 11:38 AM
Offset drain in shower??? narlyman Flooring 4 04-13-2010 10:34 PM
rubber gasket for shower drain....HELP bergdesign Plumbing 26 04-09-2009 06:11 PM
