Sharkbite Fittings , Do They Last? - Plumbing - Contractor Talk
Old 11-18-2012, 08:24 AM   #1
Spike7's Avatar
Trade: interior/exterior
Rewards Points: 402
put a screw in a new copper line in a bathroom i`m remodeling .
couldn`t sweat it on , . it was 7 at night , i couldn`t get the pipe dry enough to sweat on a new section
so i ran to the depot and got 2 sharkbite fittings
can these stay in the wall?
do they last , or will they break down , or start to leak
it is the hot water line.
plumber just told me they have used them in walls they close up
maybe i`m just being a dinasaur ,and scared of the new stuff .
but need to know
Spike7 is offline
Old 11-18-2012, 08:42 AM   #2
Working
Cole82's Avatar
Rewards Points: 2,276
Re: Sharkbite Fittings , Do They Last?
They last until the O ring fails.
Cole
The boss of awesome
Cole82 is offline
The Following User Says Thank You to Cole82 For This Useful Post:
skcolo (11-18-2012)
Old 11-18-2012, 09:50 AM   #3
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
I buried a 3/4" sharkbite in concrete 3yrs ago.
I used it to transition from copper to pex.
It was in a utility shed, and so far so good.
But I still worry about it every time I hear the word sharkbite.
Aaron Berk is offline
Old 11-18-2012, 10:46 AM   #4
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Been using sharkbites basically since they came out.....
They are not my go to thing, but have their uses.
I've had no failures so far or call backs......
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
Old 11-18-2012, 11:18 AM   #5
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 154
I've got an old building of apartments. It is 120 ft long with access to a belly crawl space only on one end. When I bought it, everything below the floor was pretty well froze up. It was pretty old copper, some of it maybe was soft copper to. Shark bites worked like a charm because of the accessibility issues. Problem is I since have had two major leaks that I didn't know about until the water bill came. We have terrible water that will wash out the copper, so maybe it's not the shark bites fault? I think there great for temporary fixes, I will be working on getting rid of all of them on this place.
I can't compete with hacks.
donerightwyo is online now
Old 11-18-2012, 12:37 PM   #6
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Lived in a municipality where the water was hard on copper. My supply line was laid in soft copper and there was a bend in the line where it cane up into the house under the slab. The water ate through the copper in the area of the bend. Caused a small leak which went undetected for (however?) long. When the ground was finally saturated, (which just happened to be while we were away for 3 weeks), we returned home and found the finished basement full of water....
.......$64,000 in renovations / repairs later.....
Wasn't a sharkbite in the system.
Old 11-24-2012, 10:06 PM   #7
jnaas2's Avatar
Trade: licensed Residential, Commercial, Plumb ,Elect
Ive replaced galvinized line that developed holes in the 90 because of to high of a velocity flow water ate thru the fitting
jnaas2 is offline
Old 11-24-2012, 10:13 PM   #8
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Over time, galvanized rusts from the inside out. Have had that happen in a couple of my customer's homes that were plumbed back in the 30's.
Old 11-24-2012, 11:50 PM   #9
jnaas2's Avatar
It was 2 years old, you could look inside the fitting and see the grove that the water cut in the fitting
jnaas2 is offline
Old 11-25-2012, 07:39 AM   #10
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,468
Sharkbites can be concealed in the wall, although I don't think that's smart.
I like them for temporary stuff until my plumber can get there. For instance, I was installing a kitchen sink base this week and rather than cut oversized holes out around the shut off valves for the water lines that came up through the bottom of the cabinet, I shut off the water to the house, cut them off, and installed sharkbite caps until my plumber gets there to install the sink.
J L is offline
Old 11-25-2012, 08:23 AM   #11
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
That's why I don't drink water...just look what it does to pipes.
Inner10 is offline
I Mester (11-25-2012)
Old 11-25-2012, 09:55 AM   #12
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
My philosophy:
If they sell it in Home Depot, it must be OK to install.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 11-25-2012, 12:59 PM   #13
jnaas2's Avatar
Tedanderson
I hope that was a joke, just because the sell it doesnt mean its legal. I normally keep My mouth shut when I am at big box stores, but I was there one day and the so called pro in the electrical department told a customer to use a octagon blue box to install a cieling fan. I had to chime in and explain to both of them that the box wasnt rated for a ceiling fan and what could happen if it was used
jnaas2 is offline
Old 11-25-2012, 01:06 PM   #14
I'm sorry. Let me re-phrase that.
If they sell it in Home Depot AND the guy behind the demonstration counter recommends it, then it must be OK to install.
The Following User Says Thank You to tedanderson For This Useful Post:
J L (11-25-2012)
Old 11-25-2012, 01:23 PM   #15
jnaas2's Avatar
I could go with that if he or she knows what they are talking about, I know some guys that are licensed in the trades that work part time at the big box stores that know the codes. So I would ask for there qualifications before following there advice
jnaas2 is offline
Old 11-25-2012, 01:59 PM   #16
Working
Cole82's Avatar
Tedanderson
Your talking about a nail up box and retro fit wing box correct?
They do make blue plastic boxes for ceiling fans.
The boss of awesome
Cole82 is offline
Old 11-25-2012, 02:30 PM   #17
jnaas2's Avatar
I know they make blue boxes for fans, the box he was showing him just had the 2 nails
jnaas2 is offline
The Following User Says Thank You to jnaas2 For This Useful Post:
Cole82 (11-25-2012)
Old 11-25-2012, 05:05 PM   #18
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,038
The Home Despair by me sells PEX pipe and fittings and romex, neither of which are code approved in this area.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 11-26-2012, 09:35 PM   #19
schaefercs's Avatar
Rewards Points: 520
I carry two sharkbite 1/2" caps in my bucket at all times along with the removal tool. They work great in kitchens and bathrooms until we can get the cabinets in and install new shutoffs. I've used them probably 30+ times and haven't had a problem with leaks.
schaefercs is offline
The Following User Says Thank You to schaefercs For This Useful Post:
icerock drywall (11-30-2012)
Old 12-01-2012, 03:52 PM   #20
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
I only use sharkbites when i cant get the line dry enough to solder due to a leaking valve. But there has to be access to the fitting, like in a basement or in a drop ceiling.
My philosophy is that there the same as viega pro press fittings. And everyone loves them, no?
Same o-ring.
Sharkbites are impossible to get off in reality without the tool. Only thing that will fail is the o-ring. Try not to use them on hot water lines, it will dry out the o-ring
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Question about the difference in FIP and Compression fittings... sy85 Plumbing 1 10-18-2011 12:28 PM
Pex, brass fittings and mineral buildup Anti-wingnut Plumbing 1 03-18-2010 10:56 PM
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
Sharkbite fittings... The truth? Nick1123 Plumbing 55 09-07-2008 06:59 PM
