Sewer Line In Old House - Plumbing - Contractor Talk
Old 10-20-2013, 07:05 AM   #1
abacab's Avatar
Rewards Points: 390
I bought an old house built in 1915. The main sewer line is about two feet off the floor at the front of the house in the basement. There is also an addition at the back of the house which has a drain in the floor in the basement. Does anybody have an idea how they got the new drain to empty into the sewer pipe that goes out to the road? I'm only asking because I'm thinking of putting a new bathroom toward the front and I'm thinking the actual sewer line must be lower than the two foot height where is sticks out of the concrete wall. I tried the drain in the floor, and it seems to work. Thanks!
p.s. the new drain was done in the 30's, everything is cast iron.
abacab is offline
Old 10-20-2013, 07:22 AM   #2
rrk's Avatar
Rewards Points: 5,428
Re: Sewer Line In Old House
I bet if it was done long ago it drains to a drywell not the sewer. I had the same thing in an old house I used to have.
Rained for almost a week and water started to come up through the floor drain.
rrk is offline
Old 10-20-2013, 03:10 PM   #3
abacab's Avatar
Rewards Points: 390
It does empty in the city sewer, because just before I bought it, they had it torn up by the road because it had backed up in the house (or so the neighbor tells me).
abacab is offline
Old 10-20-2013, 06:29 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
I'd verify that it isn't a French drain, a bottle of tracing dye and a garden hose is all you need.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
Old 10-24-2013, 08:39 PM   #5
djpafl's Avatar
Trade: Excavation, Utilities, Plumbing,
More than likely it either ties into the main sewer outside or ties into the city sewer individually. Your best option is to hire someone to televise and locate the back sewer. This way you can determine the condition, the route it takes, depths, and where it goes to. That will answer all your questions with near pin point accuracy. Make sure you map it for future reference. I'd also have them do the front sewer - probably won't cost any more (most charge one hr min.) or very little
Good Luck
djpafl is offline
The Following User Says Thank You to djpafl For This Useful Post:
abacab (10-25-2013)
Sewer Line in slab repair cost Belair Plumbing 3 05-10-2013 10:51 AM
Finishing a Barn vs Finishing a House 4 seasons lawn& Construction 3 03-02-2013 06:32 PM
no wires to house...how can this be done... Pennyroyal's Technology 25 11-28-2011 10:28 AM
How NOT to Convert a House from Septic to City Sewer ChrWright Plumbing 27 06-03-2010 08:24 PM
sewer line install rino1494 Excavation & Site Work Picture Post 8 06-14-2008 06:59 PM
