Screw-in Or Compression Valve For Toilet? - Plumbing - Contractor Talk
Old 05-28-2020, 04:41 PM   #1
Kilgore_Trout's Avatar
Trade: Construction
Rewards Points: 30
Does anybody know if there is a code (california) for the type of fitting one can use when installing supply valves? I've only used compression fittings. But I was curious if screw-in fittings were allowed.
Thanks
Kilgore_Trout is offline
Old 05-28-2020, 04:42 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,856
Re: Screw-in Or Compression Valve For Toilet?
You talking about the angle stop that hooks to the incoming water line?
Old 05-28-2020, 05:01 PM   #3
Trade: Construction
Rewards Points: 30
yes, thank you. My terminology is off.
Old 05-28-2020, 05:21 PM   #4
Trade: Highwayman
Nothing wrong with them.
Used all the time.
Old 05-29-2020, 08:26 AM   #5
Trade: Construction
Rewards Points: 30
Used all the time.
Ok. Thank you
