Pvc. Piping Inside Of Cast Iron? - Plumbing - Contractor Talk
Old 07-14-2019, 10:01 PM   #1
woodspike's Avatar
Rewards Points: 726
ever heard of this?
went to bid a gut , and remodel
the married couple were saying their waiting for the insurance company to pay for replacing the cast iron waste lines .( about a year)
i`ve seen where homes are trenched out , old cast iron pipes removed , and new pvc pipes are put in .
they had an advertisement from a company ( well known plumbing company in the area) where they say they slide pvc into the old cast iron lines
again the company that advertised it has been around for many years.
is that possible? done for a while?
new to industry? good ? bad?
woodspike is offline
Old 07-14-2019, 10:13 PM   #2
VinylHanger's Avatar
Rewards Points: 11,676
Re: Pvc. Piping Inside Of Cast Iron?
How do they get the Ys and turns in there.
VinylHanger is offline
Old 07-14-2019, 10:34 PM   #3
TheConstruct's Avatar
Rewards Points: 1,440
I've heard of pipe pulling in underground mains where they run a cable through the pipe and then pull a bulb thing theough it with new pipe. Not really sure how it works but pretty sure it's not done inside of houses.
TheConstruct is online now
Old 07-14-2019, 11:29 PM   #4
hdavis's Avatar
Rewards Points: 2,268
So you have a code required 4" cast waste pipe. Can you slide 3" PVC into it? Heck yeah. Will it meet code? Heck no.
You can have a service come in to replace an underground run of pipe. They'll excavate at the two ends of the run, then a machine is fed through the pipe both splitting it and expanding it so the correct size of flexible piping can be pulled along behind it.
hdavis is online now
Old 07-15-2019, 01:56 PM   #5
woodspike's Avatar
Rewards Points: 726
Ok.ijust called them.
They have a video of it.
Look up coralgables.com
On the site it's called "perma-liner"
She(yes she) explained that it's more like a collapsed tube the pull through it like seen electrician pulls a wire through a pipe.
And then the somehow expand it and it holds in place by the cast iron pipe.
I asked how they get it inspected.
They do a before and after video through the line.
Said it's been around a while now.
Can virtually done in a day!
Perma- liner is just one name brand. Apparently there is other brands
The Following 4 Users Say Thank You to woodspike For This Useful Post:
hdavis (07-15-2019), Rio (07-16-2019), tgeb (07-15-2019), TheConstruct (07-15-2019)
Old 07-15-2019, 02:06 PM   #6
woodspike's Avatar
Rewards Points: 726
Wwwtrenchless-pipelining.com
Old 07-15-2019, 02:59 PM   #7
diplomat
Golden view's Avatar
Rewards Points: 710
I've heard of bursting. Where they pull a 4" line through a 4" line. Generally just from house to sewer main.
Golden view is offline
Old 07-15-2019, 03:07 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 678
it's called "sleeving" and is very common to fix collapsed/degraded main trunk lines from dwelling to street.
griz is offline
Old 07-15-2019, 06:25 PM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
That's the sleeve thing that they pull through then inflate?
Inner10 is offline
Old 07-16-2019, 06:28 AM   #10
woodspike's Avatar
Rewards Points: 726
apparently its legal to do it under the house, not just the main to the street
they said if you can get one of those cameras down there , and check the line ,, and it still has some integrity to it , meaning i guess is still whole , and can support that new lining , they can pull their lines through it .
i`m not a plumber at all , but that's pretty interesting.
saves, homeowners having to relocate , and tearing up the entire interior floor .
Old 09-03-2019, 11:24 AM   #11
rounde683's Avatar
Trade: Electrician
Rewards Points: 32
Id double check the sleeving codes in the area. You can probably find them on the county website.
Removed by staff
rounde683 is offline
