Pressure Switch Sticking - Plumbing - Contractor Talk
Old 08-08-2011, 09:18 PM   #1
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
I went downstairs tonight saw water dripping from my expansion tank. looked at the gauge it was at 98 psi. Made for a real holy chit moment as the pump was still running. Turned breaker off bled pressure off to 20 and turned breaker back on. The switch made the kick off click at 50 psi but the pump was still running. So after a wtf moment i realized the switch opened but the contacts were stuck. Turned breaker off pried them apart with a screwdriver and everything seems fine now. Should i just change the switch out? Never had to deal with a well much....
jkfox624 is offline
Old 08-08-2011, 10:08 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,351
Re: Pressure Switch Sticking
Over time, a gazillion make/break contacts with associated arcing can make the relay contacts get ragged enough to hang up and not pull apart when the coil is de-energized.
A quick & dirty temporary solution is to polish and/or burnish the contacts. If they're not too bad, rubbing them with some low-grade (coarse surface) paper can be enough to take care of it for a bit; worse means actually rubbing with a piece of steel.
But yes, by the sound of it you should replace it ASAP.
Tinstaafl is online now
mrmike (08-09-2011)
Old 08-08-2011, 10:10 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,338
You can try a little Emery Cloth to dress the points & maybe get lucky.
However...Keep a close eye on the switch and I have a new standing by.
griz is online now
Old 08-08-2011, 10:12 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Emery cloth will take off what little plating is left. I'd use that only as a last resort.
Old 08-08-2011, 10:34 PM   #5
Fire up the BBQ
griz's Avatar
Never used anything but Emery Cloth on points of any kind.
griz is online now
Old 08-09-2011, 02:21 PM   #6
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
just jam a screw driver in there while its still hot wiggle it around and it will fix it till you get a new switch..
rex is offline
Old 08-09-2011, 03:48 PM   #7
Jeff
jkfox624's Avatar
Rewards Points: 502
Haha as tempting as that sounds and im hoping your being sarcastic once i got it loosened up last night with the power off it seems to be working for the time being. Electricity doesnt scare me but 220 while im standing in a puddle of water on my basement floor makes me think twice.
jkfox624 is offline
Old 08-09-2011, 04:56 PM   #8
rex's Avatar
Trade: Nothing
no i wasnt joking...
either way you have water now
rex is offline
Old 08-09-2011, 05:09 PM   #9
GettingBy's Avatar
Rewards Points: 6,486
Good contacts have less than 30 mV across them at rated current, bad have more than 100 mV.
If pressure switch contact welding is a catastrophic event and depending on the price of pressure switches, put two in series.
If one switch has a 1% [.01] chance of failing over 'mission duration' then the chance of both switches failing over system lifetime is 0.01% [.01^2 = .0001].
GettingBy is offline
Old 08-13-2011, 05:12 PM   #10
13 Licenses & Counting
piercekiltoff's Avatar
Trade: Water well drilling & pumps
Rewards Points: 168
Welcome to my life
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook
Monroe, Washington, (360)-794-7300
Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA
piercekiltoff is offline
Old 08-18-2011, 04:55 PM   #11
Naperville Plumber
Marquise's Avatar
Trade: Plumbing and Backflow
Change the switch and sleep well
Marquise is offline
Old 08-18-2011, 05:15 PM   #12
GettingBy's Avatar
And once/year measure the voltage across the closed switch contacts.
Lennox Pressure Switch Trouble? Glock23 HVAC 3 11-18-2012 11:11 AM
SW Florida Pressure Washing Chuck Bergman Charlotte and Sarasota County-Roof Cleaning 5282jt Pressure Washing 0 05-05-2011 08:35 AM
air pressure switch mistermcfrug HVAC 2 07-28-2010 06:40 PM
How to Safely Pressure Wash Your Home. PressureWashE Pressure Washing 1 07-02-2010 05:50 AM
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 03:15 PM
