Plumbing Help - Plumbing - Contractor Talk
Plumbing Help
Old 10-08-2007, 06:54 PM   #1
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
Plumbing Help
I have a question about pressure testing water lines. During a winterization on a property i need to test the pressure of the system to make sure there are no leaks. Also i need to blow the wtare lines clear. Any suggestions on what i should use beside a standard gas line tester?
XanadooLTD is offline
Old 10-08-2007, 07:39 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,026
Re: Plumbing Help
I use a compressor.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is online now
Old 10-08-2007, 07:41 PM   #3
XanadooLTD's Avatar
Re: Plumbing Help
what kind of attachment do you use to blow lines? Anything special?
Old 10-08-2007, 07:45 PM   #4
The Grand Wazoo
Re: Plumbing Help
You can do it through the laundry tray with a hose fitting adapter and a reducing coupling to get you to the size air fitting you use.
Old 10-08-2007, 07:50 PM   #5
XanadooLTD's Avatar
Re: Plumbing Help
Thanks alot. That helped me out. I thought i could do that, i just wanted to make sure from someone with more knowledge. thanks again
Old 10-08-2007, 07:55 PM   #6
The Grand Wazoo
Re: Plumbing Help
If the property is on well water, make sure to drain the pressure tank too.
Old 10-08-2007, 08:02 PM   #7
XanadooLTD's Avatar
Re: Plumbing Help
Radiant and steam systems are a problem right? I have heard they are a lot of work. Best to bring in a licensed guy for that right?
Old 10-08-2007, 08:05 PM   #8
mdshunk's Avatar
Rewards Points: 2,002
Re: Plumbing Help
With all the forclosures and impending forclosures, I'd bet there's a steady need for winterizing guys now. I think that's a flat fee. No?
mdshunk is offline
Old 10-08-2007, 08:07 PM   #9
The Grand Wazoo
Re: Plumbing Help
When I did service work we charged $150.00 plus RV antifreeze.
Old 10-08-2007, 08:08 PM   #10
The Grand Wazoo
Re: Plumbing Help
Unless you want to replace it.
Old 10-08-2007, 08:11 PM   #11
XanadooLTD's Avatar
Re: Plumbing Help
150? Really. I have been doing it for about 75-100. Killer you have helped me tonight more than you will ever know. Yeah foreclosure business is banging and it is new for us. We do mostly government contracts, banks are tough because they won't spend much money.
Old 10-08-2007, 08:36 PM   #12
XanadooLTD's Avatar
Re: Plumbing Help
good idea.
under-slab plumbing / DIY ruger9 Plumbing 28 03-09-2009 12:31 PM
Plumbing or Electrical? newguy07 General Discussion 21 10-16-2007 08:45 PM
Industrial plumbing vs residental pyroracing85 Plumbing 17 09-28-2007 11:02 PM
boiler plumbing question AustinDB HVAC 2 05-06-2007 07:26 PM
Locating plumbing in an outside wall Mike Finley Plumbing 15 09-09-2006 06:49 AM
