Plumbing Dilemma - Plumbing - Contractor Talk
Plumbing Dilemma
Old 09-12-2018, 10:44 AM   #1
jtomm's Avatar
Trade: Handyman
Rewards Points: 38
Plumbing Dilemma
I just hooked up my washer and dryer. I tapped into the showers hot and cold lines. Iím getting less pressure out of my shower than before even though my washer isnít running. I have turned the valves off to the washer and still the pressure is low. Anything I can do about this?
jtomm is offline
Old 09-12-2018, 11:03 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,801
Re: Plumbing Dilemma
You might have crud in the shower head..or the valves. Try removing the shower head first, turn it on and see how it flows.
MarkJames is online now
Old 09-12-2018, 11:05 AM   #3
jtomm's Avatar
Trade: Handyman
Rewards Points: 38
Ok I will try that. Possible that wood chipping or drywall dust got in the pipes and fittings while I was working. If that doesnít work what should I look for next?
jtomm is offline
Old 09-12-2018, 11:13 AM   #4
MarkJames's Avatar
Remove the valve cartridges and inspect.
Old 09-12-2018, 12:18 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 1,616
if you have a low flow shower head take it apart and clean the restrictor.
griz is online now
Old 09-12-2018, 12:56 PM   #6
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,221
Even though I am in a water conservation state (CA), I always pull them out and throw them away. Something my plumber taught me
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
tgeb (09-13-2018)
Old 09-12-2018, 04:53 PM   #7
avenge's Avatar
Rewards Points: 540
Anytime you shutoff a water supply there's a chance of getting crap in the lines especially with age.
avenge is online now
Old 09-12-2018, 09:21 PM   #8
tjbnwi's Avatar
Rewards Points: 2,686
Cartridge is plugged.
tjbnwi is offline
Old 09-12-2018, 09:53 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 15,354
Then throw the restrictor in the trash. Makes it easier to rinse the shampoo outta your hair.
Mike.
_______________
Calidecks is offline
onmywayup (09-13-2018), ScipioAfricanus (09-18-2018), tgeb (09-13-2018)
Old 09-13-2018, 07:47 AM   #10
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 710
First thing I do when I buy a new shower head is find and remove the restrictor.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Calidecks (09-13-2018)
Old 09-13-2018, 10:26 PM   #11
90%-er
onmywayup's Avatar
Rewards Points: 2,036
I hate those damn things. Right along with low flow toilets
onmywayup is online now
The Following 2 Users Say Thank You to onmywayup For This Useful Post:
Calidecks (09-13-2018), Fouthgeneration (09-17-2018)
Old 09-17-2018, 04:34 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,925
Replace the "tees" with one size larger Tees with bushings....?
Check for kinks WHEN THE WATER IS RUNNING if using "Soft" piping. I.e. Pex line kinking partially closed when pressure drops. Non "linear" action as you shut slowly the shower valves.
Install a Pressure gauge on the washer lines
Dirty whole house filter? Dirty water softener.... Partially closed main valve/ stop box....
Line(s) TOO small for length and fittings installed, the tees "broke" the camel's back in regards to GPMs.
Foot valve in tub spout needs replaced/serviced.....
Fouthgeneration is online now
Old 09-18-2018, 04:33 PM   #13
Trade: Masonry
loose solder in shower-head flow restrictor?
Faceframe Dilemma Vinson Finish Carpentry 7 04-11-2015 11:43 PM
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Seeking C-36 Plumbing RMO designbymind New Member Introductions 0 01-29-2013 12:47 AM
DIYers in the Plumbing Forum 22rifle Plumbing 49 06-22-2008 11:42 PM
