Plastic PEX Fittings Good Or Bad? - Plumbing - Contractor Talk
Old 03-25-2015, 10:42 PM   #1
Shouldz14's Avatar
Rewards Points: 104
I've done plenty of work with PEX pipe over the past couple of years. I am now getting into renovating homes and some have to be fully gutted. My question is from simple a cost savings/quality stand point are the plastic fittings just as good as the brass ones? I will be purchasing these in large quantities so small savings like this adds up, and the fact the even at HD or lowes they are half the price of the brass make appealing to use. I just don't want to use them and the person who purchases the home have a problem shortly after purchase. If they are just as good then I'll most likely use them. But if anyone has had experience with them and the quality just isn't there then the savings won't be worth it.
Shouldz14 is offline
Old 04-25-2015, 07:08 AM   #2
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: Plastic PEX Fittings Good Or Bad?
i use them a lot of the time and have had good luck with them
pappagor is offline
Old 04-30-2015, 07:22 PM   #3
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
HD & Lowes are the most expensive places in my area. If you do volume, you should get better pricing at a supplier...better quality as well. There's some good online options as well. I used to waste a lot of my time trying to find the best deal, but soon realized it was a waste of time. If the fittings are $0.20 more and I used 100 of them on a job, it's only a $20 difference in material cost. Sometimes there's better ways to increase profits.
Except the $90 toilets I used in bank jobs, I won't enter the plumbing aisle of HD.
I used plastic fittings with Uphonor, but no longer have the expander. All other fittings I get brass in bulk.
philcav7 is offline
Old 04-30-2015, 10:04 PM   #4
diplomat
Golden view's Avatar
Rewards Points: 674
you can tow a truck with propex ep (engineered plastic) fittings stringing together a bunch of pieces of pex.
Or so claims my plumber...
Golden view is online now
Old 04-30-2015, 10:15 PM   #5
Quality_PTG's Avatar
Trade: Painting and Decorating
Rewards Points: 258
I've heard the grey pex pipe isn't any good. Any truth to that?
Quality_PTG is offline
Old 04-30-2015, 11:49 PM   #6
CarpenterSFO's Avatar
Rewards Points: 2,044
Get out of HD and Lowes and over to a decent plumbing supplier. I am using and plan to use the Uponor propex fittings and aquapex pipe as much as possible going forward, using the Milwaukee expansion tool. Still some use for copper.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
philcav7 (05-01-2015)
Old 05-01-2015, 12:20 AM   #7
diplomat
Rewards Points: 674
Yes. Use only Uponor or Rehau pex.
Quality_PTG (05-01-2015)
Old 05-01-2015, 12:33 AM   #8
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I wouldn't trust the plastic fittings from homedepot, they'll probably get brittle and crack.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 05-01-2015, 06:19 AM   #9
TimNJ's Avatar
Rewards Points: 5,666
When I think of plastic pex fittings I think of RV construction.
TimNJ is offline
Old 05-15-2015, 08:32 AM   #10
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
The grey in RVs I don't think is pex as it cannot withstand freezing.
So the sharkbite at home depot is junk?
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 05-15-2015, 11:18 AM   #11
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
The price difference between my local building supply and a plumbing supply i now use...
2.99/.79
Cant remember the part but that's it. Crazy
illbuildit.dd is offline
Old 05-15-2015, 06:09 PM   #12
CO762's Avatar
Our local place sells pex clamps individually, which was good because I was one short....so I bought 20. They are overpriced on everything--but that's to be expected as the city is a half an hour away, so we pay for convenience.
CO762 is offline
Old 06-13-2015, 05:54 PM   #13
jayweitekamp's Avatar
Rewards Points: 42
Bob... Does SF allow you to use PEX? I was under the assumption that they only allowed copper.. Thanks
jayweitekamp is offline
Old 06-13-2015, 08:31 PM   #14
It used to be that way, but PEX has been legal for a few years now in SF. I have been told that all the new big construction is 100% Uponor/Propex.
I know of 2 big houses that were plumbed by subs from outside of the city, prior to the change. All PEX, all had to be cut out and re-done.
- Bob
Old 06-15-2015, 06:19 PM   #15
Rewards Points: 42
Good to know I guess I should of asked the inspector on the last job. I'm just so used to copper pipes and cast iron for DWV.
The Following User Says Thank You to jayweitekamp For This Useful Post:
CarpenterSFO (06-15-2015)
1927 Oliver 117-A Bandsaw Restoration..... PrestigeR&D Tools & Equipment 49 01-12-2014 11:35 AM
how should i approach this issue with my worker? welterweight General Discussion 103 02-19-2013 12:20 AM
Fist fight with owners son...not good davinci Off Topic (Non Trade) 65 06-22-2012 07:49 PM
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 02:50 PM
Pex, brass fittings and mineral buildup Anti-wingnut Plumbing 1 03-18-2010 10:56 PM
