PEX Fittings And Inside Diameter - Plumbing - Contractor Talk
Old 05-31-2015, 11:40 AM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,196
I'm replacing the old supply lines at my house and I'm going with PEX. I've pretty much only worked with copper, so this is a first time for me.
I'm using a standard trunk system, without any of those nice manifolds. My house is 1100 sq ft on one level with two full baths.
The main is 3/4" galvanized steel. I'm planning to run 3/4" PEX trunks and branch off with 1/2 to fixtures.
It's obvious that the barbed fittings choke down the ID to about one trade size smaller.
Should I be using 1" trunk, or will 3/4" be acceptable? Being a small house, there aren't any very long runs.
dielectricunion is online now
Old 06-01-2015, 06:37 AM   #2
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
Re: PEX Fittings And Inside Diameter
I'd be worried about the old 3/4" steel being choked off by all thethe old sediment and glom.
Are you planning to replace any/or all of it?
As long as your main is 1" you should be okay with 3/4" pex.
-Scott
tenon0774 is offline
Old 06-01-2015, 05:11 PM   #3
hack of all trades
Trade: Electrician
The 3/4 steel is my main out of the meter. My meter is all the way at the curb... Meaning that steel runs across my neighbors entire yard. I'd love to be able to replace it but it isn't realistic right now.
Old 06-07-2015, 06:41 AM   #4
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
then you chock it down to less then 3/8 inch at the shut off valve stop wasting time and get the job done
pappagor is offline
