Pex Fail - Page 2 - Plumbing - Contractor Talk
Pex Fail
Old 06-26-2019, 10:25 AM   #21
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,657
Re: Pex Fail
Could the scoring on the PEX come from feeding it through a wall, etc?
Maybe a sharp edge/nail?
rescraft is offline
Old 07-06-2019, 12:18 AM   #22
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,332
Re: Pex Fail
I have Sharkbite fittings that are at least 10 years old without issue on my home. I have no problem trusting them. They are approved.
Mike.
_______________
Calidecks is online now
BlueRidgeGreen (07-06-2019), EricBrancard (07-06-2019), Idothat (07-07-2019)
Old 07-06-2019, 09:20 AM   #23
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,822
Re: Pex Fail
Lead pipes, cast iron, and cpvc were all approved as well...
Home Designer Series Software
B.Johnson is offline
Old 07-06-2019, 01:35 PM   #24
GC/carpenter
Calidecks's Avatar
Re: Pex Fail
So those things failed that means Sharkebites will fail. How do you square that circle.
Makes no sense.
Mike.
_______________
Old 07-06-2019, 06:12 PM   #25
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Pex Fail
So tell me what's wrong with lead, cast iron and cpvc?
Inner10 is offline
Seven-Delta-FortyOne (07-13-2019)
Old 07-06-2019, 07:15 PM   #26
rrk's Avatar
Rewards Points: 3,516
Re: Pex Fail
I was wondering the same thing
Cast iron lasts for 75-100 years
lead pipe lasts for 100 years, quickly gets a coating on the inside which stops lead contaminating the water in most instances. If it did not virtually all of the people in the older towns of northeast in the last 100 years would have already had lead poisoning
cpvc lasts for 50 years but does get brittle in some locations, not my favorite where it gets cold
as a test several years ago my plumber tested an old lead water supply line that was removed. He folded and pinched one end filled it with water and put a fernco cap on the other end, 2 years later he tested it for lead. Came up near zero ppm.
rrk is offline
Old 07-06-2019, 07:34 PM   #27
Inner10's Avatar
Re: Pex Fail
My house has a lead service until a few years ago....I didn't die.
Inner10 is offline
Old 07-06-2019, 08:30 PM   #28
B.Johnson's Avatar
Trade: Builder
Re: Pex Fail
More like 50 years.
That's not what the people in Flint, MI told me.
It does tend to get chilly here at times.
That wasn't really my point. Materials that have been approved in the past sometimes can't survive the long term. I'm a big fan of sharkbite fittings, especially to transition to PEX from other materials. However, just because it's approved doesn't mean that there won't be failures in the future.
Old 07-07-2019, 12:49 AM   #29
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,028
Re: Pex Fail
Not exactly, but not exactly wrong either. The coating that develops does keep the lead level down but not zero. It's also fragile and inconsistent. Not a good system to have faith in. I wouldn't have it in my house and have my kids drinking from lead pipes.
BTW, A lot of people in the NE do have elevated lead levels. How else do you explain Eagles and Patriots fans?
SPG is offline
Old 07-07-2019, 06:18 AM   #30
rrk's Avatar
Re: Pex Fail
lead pipe is not fragile at all, you can hit it with a hammer and it just bends. lasts for 50 or so years
rrk is offline
Old 07-07-2019, 06:25 AM   #31
rrk's Avatar
Re: Pex Fail
cast iron lasts way more than 50 years. Again if that were the case every house here built before 1970 would be having all their waste lines replaced, which is not the case at all. My plumber is just replacing a few sections from houses built in the late 40s and earlier.
rrk is offline
Old 07-07-2019, 06:54 AM   #32
Tom M's Avatar
Rewards Points: 8,330
Re: Pex Fail
Plumber says the water main. Hi they just shatter. All very old but lead.
We change all galvanized pipe but leave cast for waste. The plumber likes PEX and tries to convince me all the time. Showed me pictures of one expanded like a balloon and didn't bust. He uses expansion fittings.
I still don't like them.
Could this be a recycled shark bite fittings that list a tooth or two and the score is just a mark from gripping the pipe taking it in and off?
Tom M is online now
Old 07-07-2019, 07:04 AM   #33
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Pex Fail
Lead poisoning doesn't kill. It just reduces the IQ of kids to that of an average Canadian.
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
avenge (07-07-2019), Tom M (07-07-2019)
Old 07-07-2019, 07:11 AM   #34
SPG's Avatar
Re: Pex Fail
I was talking about the magic film that instantly makes lead 100% safe. If a change in the water can wipe it away I'd say it's pretty fragile.
SPG is offline
Old 07-07-2019, 07:38 AM   #35
tjbnwi's Avatar
Rewards Points: 2,054
Re: Pex Fail
Some claim all heavy metals cause this....
tjbnwi is online now
SmallTownGuy (07-07-2019)
Old 07-07-2019, 10:04 AM   #36
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 940
Re: Pex Fail
Mike.
_______________
I have sharkbites in my home as well , used to replace crimped fittings that failed .
I still would not trust them in a cutomerís home for more than a temporary fix , just because.
The end caps are very useful for remodeling, and easily removed without having to cut the pipe
Idothat is online now
The Following User Says Thank You to Idothat For This Useful Post:
Tom M (07-07-2019)
Old 07-07-2019, 11:46 AM   #37
Radical Basement Dweller
Robie's Avatar
Rewards Points: 8,462
Re: Pex Fail
I used a short 8" piece of pex and two sharkbite fittings on my oil-fired boiler a few days ago to repair a pinhole leak that are always developing. It's close to the boiler but is the cold water supply and I checked the temp several times and the pex and fittings haven't gotten past 105*.
It's not meant as a permanent fix but is working fine until I get down there to sweat over sweating more copper.
"The trouble with Socialism is that eventually you run out of other people's money."
.....Margaret Thatcher
Robie is online now
Old 07-07-2019, 12:02 PM   #38
GC/carpenter
Calidecks's Avatar
Re: Pex Fail
They are even approved for burial.
Mike.
_______________
