Pex... Best Thing Since Sliced Bread? - Page 5 - Plumbing - Contractor Talk
Old 01-14-2011, 05:52 PM   #81
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Pex... Best Thing Since Sliced Bread?
Originally Posted by loneframer View Post
Yo, those labels were temps, until the HO made his own labels. The labels are not my handiwork anyway.
His own labels.
HO sounds serious.
Inner10 is offline
Old 01-14-2011, 06:05 PM   #82
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Originally Posted by Inner10 View Post
His own labels.
HO sounds serious.
He didn't like the cheesy-azz labels supplied with the Mana-Blocks, so he decided to do his own.
Everything in this house is over the top. He built manifolds for the showers and tubs, so that he could run 2 half inch supplies to each side of each diverter. Hots have a circ. loop to each manifold, but there are still a few long runs from the manifold to the fixture. I doubt the HOs are worried about waiting a few seconds for hot water, or wasting it for that matter.
Theres about 9000 sq. ft. of heated floor, not counting the loops in the exterior stairs and walkways.
There's 5 Unico systems circulating chilled water for the AC.
loneframer is offline
Old 01-14-2011, 06:15 PM   #83
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
One problem does exist with PEX.
One time a mouse chewed through it on an old farmhouse, ya know the type.......massive wood beams and such. The water line were pex and it was drilled through a beam in the kitchen partition wall.....almost impossible to work on and get to, the pex was fed right through it.
Of course the dam mouse had to chew right near the edge so it all had to be ripped out. The 90 year old lady said "Why would anybody make plastic water lines?"
I ended up running soft copper to repair it.
It's very rare but the darndest things happen in the plumbing world.
Mike
see ya!
Mike's Plumbing is offline
Old 01-14-2011, 06:16 PM   #84
Professional Instigator
rbsremodeling's Avatar
If a plumber showed up on my jobsite ready to install pex, I would strangle him to death or beat him unconscious with it.
rbsremodeling is offline
Old 01-14-2011, 06:20 PM   #85
Trade: ooo
Would you do that if the customer demanded it? Plumbers don't do it by choice....I don't at least. If they want to pay for copper I will order a semi-load from the factory if need be.
Mike
see ya!
The Following User Says Thank You to Mike's Plumbing For This Useful Post:
rex (01-14-2011)
Old 01-14-2011, 06:37 PM   #86
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Tell the customer that the product is not code approved in northern IL and if they want it installed they have to pull their own permit and install it themselves.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 01-14-2011, 06:52 PM   #87
Mike
Copper is what we typically install.. I will and do install CPVC as well any day over that pex crap.
Old 01-14-2011, 07:50 PM   #88
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
Have you ever even used pex? I once thought that pex would suck because of the reported Zurn fitting failures and it's notoriously failure prone cousin CPVC, however after using pex I've realized one thing: pex is the future and the longer we deny it, the more money we will throw away on copper.
Copper is proven to last over the years, but outside of that, it is heavier, it is 10 times the cost of pex per foot and takes 5-10 times as long to install. On top of that, pex will usually survive freezing with water in the line and is more corrosion resistant than copper. To attach a fitting you just use a pair of crimps to tighten a band in place and you're done. No messy flux or glue. No cleaning of fittings. No torches. If a joint fails on your pressure test, you simply replace the fitting which takes about a minute. Now what happens when a copper joint fails? We all know that it's an absolute nightmare. You have to drain the lines, heat the joint and pull it apart, clean it, heat the lines to remove moisture, re-solder the joint, etc.
Pex has little if any drawbacks when compared with copper, and CPVC is the crap product of the bunch if you ask me.
Remodelor is offline
Old 01-14-2011, 07:54 PM   #89
The Grand Wazoo
Well, the trick is to know how to do it well enough to not have a leak, the second trick is to know how to repair a leak without going through what you just described, and yes it can be done.
Old 01-14-2011, 07:59 PM   #90
Remodelor's Avatar
Rewards Points: 250
I'm not saying pex lets you do shoddy work. I personally haven't had a joint fail in the last 6 years, granted I only solder stuff about 3-4 times a year. If you know a better way to fix a faulty joint without pulling that connection apart, cleaning, fluxing and resoldering, I'm all ears.
Old 01-14-2011, 08:16 PM   #91
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
I think this thread just took a major turn in the wrong direction.
Get Angus over here to put this out before it gets out of control.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 01-14-2011, 08:46 PM   #92
Life Apprentice
mehtwo's Avatar
Trade: Plumbing & Carpentry
Rewards Points: 558
Mike
Maybe the mouse was thirsty.
mehtwo is offline
The Following User Says Thank You to mehtwo For This Useful Post:
Mike's Plumbing (01-14-2011)
Old 01-14-2011, 08:58 PM   #93
The Grand Wazoo
They teach these tricks when you serve your trade apprenticeship.
Old 01-14-2011, 09:12 PM   #94
Remodelor's Avatar
Rewards Points: 250
Sigh...
Bottom line of my original on-topic point: pex is wonderful, and barring any major long-term problems, it is revolutionary and will become the new standard.
Old 01-16-2011, 12:12 PM   #95
Hmedic's Avatar
Trade: general contractor
Rewards Points: 14
Brand new to this site and a total thumbs up!....
Pex....the best thing ever...well for our industry!
As a remodeling contractor it is faster easier and allows me to sleep much better at night!
The tools of the trade have came way down...and short of forgetting to crime a fitting it is really fault proof. CPVC...some swear by it...copper..to timely and costly and the risk some idiot will burn a house down!
Again...great site!
Hmedic is offline
Old 01-16-2011, 12:17 PM   #96
Very few plumbers in my area use Pex.. I don't know any personally that do but I have heard my plumbers say they have seen it installed..
The only people who use or talk about Pex here, are Remodelers and GC's trying to do plumbing without using a licensed plumber to do their work.
The exception being Pex used for radiant floors..
Old 01-16-2011, 12:38 PM   #97
KemoSabe
loneframer's Avatar
All these homes are plumbed with Pex and Mana-Blocs.
Pex... best thing since sliced bread?-003-2.jpg   Pex... best thing since sliced bread?-009-3.jpg   Pex... best thing since sliced bread?-036-1.jpg   Pex... best thing since sliced bread?-040.jpg   Pex... best thing since sliced bread?-013.jpg
Old 01-16-2011, 12:42 PM   #98
I am sure it works for some.. I have no doubt plumbers use it day in day out, its just not for me.
I am not convinced it is something I would install in my customers home.
As time goes by I might change my mine, but for right now its a no go..
Old 01-16-2011, 12:51 PM   #99
KemoSabe
loneframer's Avatar
I had my doubts as well.
I've seen more failures with copper in new construction than Pex. The truth of the matter is, a licensed plumber employs less skilled labor than a career carpenter with limited plumbing skills , in many cases.
Water quality has caused many failures in copper in my area as well.
Pex isn't for everybody or every situation, but I'd use it in my house, just like OSB and #30 felt for a WRB.
I remember when guys were bitching about plastic waste lines as well. No way a glued fitting is better than lead and oakum....
The Following 3 Users Say Thank You to loneframer For This Useful Post:
Multi-Tasker (01-17-2011), rbsremodeling (01-16-2011), Remodelor (01-17-2011)
Old 01-16-2011, 12:59 PM   #100
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
Crazy how many areas dont use pex. I havent seen a copper run house in over 10 years. The only copper is the wall stubs for toilet and sinks, and sometimes there pex to. I think the stuff is gold.
Chris@Sunrise is offline
Another thing about Craigslist. ChainsawCharlie Off Topic (Non Trade) 6 09-11-2010 06:38 PM
what is the new "related search" thing at the bottom of google search pages? will575 Marketing & Sales 4 05-31-2009 04:57 PM
Thing will get better... my psychic said so. HSConstruction General Discussion 11 03-30-2009 10:35 PM
The best thing about deer season... mdshunk Off Topic (Non Trade) 10 12-09-2008 04:49 AM
Such A Thing As?...... neolitic Plumbing 5 12-07-2008 07:58 PM
