Painting Black Gas Pipe - Plumbing - Contractor Talk
Old 10-23-2010, 01:02 AM   #1
rmsowell's Avatar
Trade: Engineer
I have a short lenght of black gas pipe that was exposed to a water leaking in my ceiling that has the elbows rusted. I bought some rust remover that removed most of the rust. My concern is the painting. Does it matter if I paint over the theads and joints with the paint? This is a oil based, Rustoleum type paint. Did not know if the oil in the paint will break down the pipe dope?
rmsowell
rmsowell is offline
Old 10-24-2010, 04:58 PM   #2
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Re: Painting Black Gas Pipe
o ic your a engineer thats means you over analyze everything...just paint the damn gas line and move on to something else......
rex is offline
Old 10-24-2010, 10:57 PM   #3
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Rewards Points: 324
Wait, you forget to tell him whether to use primer, oil or latex, brush or roller or spray.
fireguy is offline
Old 10-24-2010, 11:02 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,708
Never seen it be a problem.
Maybe on the Space Station.
griz is online now
Old 10-25-2010, 12:00 AM   #5
rmsowell's Avatar
Trade: Engineer
I guess some engineer must have rubbed you the wrong way recently. Or maybe you are the type that OSHA has to investigate how their got their balls caught in the pipe threader or toasted in the high voltage switch gear because they did not listen to the engineers during their training class. We do tend to over analyze things when it comes to safety. After checking several sources, the paint may soften the exposed pipe dope due to its solvent content, but should not effect the pipe dope deep in the joint threads enough to compromise the seal.
I painted the pipe!!
rmsowell is offline
Old 10-25-2010, 04:34 PM   #6
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Use acrylic paint.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 10-25-2010, 05:16 PM   #7
Thom
thom's Avatar
Rewards Points: 4,748
Do it right...
... Have it sandblasted to get it clean, sand, fill, then sand any pits or scratches, then have it powder coated. A couple coats clear coat on top of that should do it. Make sure you do the entire piping system before you cover it up with sheetrock.
thom is offline
Old 10-25-2010, 07:11 PM   #8
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Thumbs up
Originally Posted by rmsowell View Post
i guess some engineer must have rubbed you the wrong way recently. Or maybe you are the type that osha has to investigate how their got their balls caught in the pipe threader or toasted in the high voltage switch gear because they did not listen to the engineers during their training class. We do tend to over analyze things when it comes to safety. After checking several sources, the paint may soften the exposed pipe dope due to its solvent content, but should not effect the pipe dope deep in the joint threads enough to compromise the seal.
well done
Driftwood is offline
Old 10-29-2010, 07:23 PM   #9
Flex'n Nuts's Avatar
Trade: Bling'n Cribs
Did you fix the ceiling leak?
Flex'n Nuts is offline
The Following User Says Thank You to Flex'n Nuts For This Useful Post:
UALocal1Plumber (10-29-2010)
Tags
black pipe , gas pipe , paint pipe , pipe rust
Black & Decker Recalls Random Orbit Sanders Snobnd General Discussion 1 09-11-2010 06:55 AM
Considering a Gas Range, need advice on pipe sizing/service size xmptsunami HVAC 4 09-01-2010 06:09 AM
Waste Pipe Outlet Beneath Damp? tileman_17 Construction 3 09-15-2009 03:31 PM
condesating steam pipe Platinum8 Plumbing 6 04-27-2009 07:29 PM
chimney pipe extension trade HVAC 5 04-02-2009 11:47 AM
