Outside Spigot Question. - Page 3 - Plumbing - Contractor Talk
Old 11-21-2018, 09:13 AM   #41
tjbnwi's Avatar
Rewards Points: 4,170
Re: Outside Spigot Question.
Originally Posted by MarkJames View Post
I would call that ratio "feel", so it makes sense if the feel of snugness is different for different materials. But maybe it's a plumbing myth afterall.
"Snuggness" also changes by diameter of the fitting (probably more so than the material).
Biggest thing is don't over tighten, failure due to stress on the assembly can happen down the road and cause a real mess.
A myth to keep you from doing plumbing---keep having leaks and you'll stay away from plumbing.
tjbnwi is online now
Old 11-21-2018, 09:19 AM   #42
MarkJames's Avatar
Rewards Points: 19,035
Check this out, per Lasco Fittings:
Here are some of the Do's and Don'ts of PVC joint assembly:
Don't over-tighten joints by giving them "one more turn to be sure."
Do finger tighten plus one or two turns - No More.
Don't wrap Teflon tape or Teflon paste or pipe dope to add bulk to or to lubricate the joint. (my highlight)
Do use a sealant for threaded joints.
Don't use "stronger" Schedule 80 threaded fittings on the assumption that they may solve the problem of splitting through over-tightening.
Do use only Schedule 40 threaded fittings with Schedule 40 pipe and fittings.
Don't over-tighten.
Do finger tighten plus one or two turns.
Teflon tape, Teflon paste and pipe dope is intended for metal pipe and fittings. Metal to metal fitting joints are more difficult to tighten than plastic; the surfaces tend to gall without the aid of such lubricants as Teflon or pipe dope. Plastic fittings do not need this lubrication.
http://www.lascofittings.com/threads
MarkJames is offline
Rio (11-21-2018)
Old 11-21-2018, 09:26 AM   #43
tjbnwi's Avatar
Don't over-tighten.
Then explain my highlight----one contradicts the other. Can't have it both ways.
I'm not using the product to lubricate, I'm using it to seal.
PVC can gall also.
Old 11-21-2018, 09:31 AM   #44
MarkJames's Avatar
PVC can gall also.
Yup, I saw that myself.
Old 11-21-2018, 09:39 AM   #45
MarkJames's Avatar
On the other hand....
Charlotte Pipe says to use only Teflon tape on threaded PVC, not any pastes since they may contain chemicals that break down the plastic.
http://www.charlottepipe.com/Documen...ures/BR-PK.pdf
Old 11-21-2018, 09:53 AM   #46
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,612
I use Teflon tape on threaded PVC all the time.
In fact, the only time I sometimes have trouble with cracking is due to binding, when I've NOT used Teflon.
I don't use dope on PVC, however. Like you said, some of the chemicals can react adversely with PVC.
Or so they say.
MarkJames (11-21-2018)
Old 11-21-2018, 10:51 AM   #47
Designer/Contractor
Rio's Avatar
Rewards Points: 1,124
Originally Posted by griz View Post
rector seal....
as it is known on site as....rectum seal...
Ohh, the memories of using rectum seal, sticky, goopy, hard to get off the hands and clothing if one's a little messy but man does it work.
Rio is online now
Old 11-21-2018, 07:27 PM   #48
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Here read this .................
https://www.linkedin.com/pulse/what-...-larry-workman
Also NPT threads with plastic and metal are always a problem. Plastic threads tend to grind, shear, or even break
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
MarkJames (11-24-2018)
Old 11-21-2018, 07:30 PM   #49
Irishslave's Avatar
Some threads aren't NPT and are straight that will cause problems too
Old 11-21-2018, 09:43 PM   #50
tjbnwi's Avatar
They would be called out as NPS. electrical fittings for EMT are NPS.
Old 11-23-2018, 07:12 PM   #51
TimNJ's Avatar
Rewards Points: 6,838
Pipe dope I use is Bloc, blue stuff. Used it on boiler fittings and always held.
TimNJ is offline
Old 12-06-2018, 11:33 PM   #52
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,852
Cleaned off everything on the one spigot...wrapped 6 wraps of tape and tightened it up. Not quite as tight as I would have liked it but tight enough it doesn't leak and at 6 o'clock.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 12-07-2018, 08:44 AM   #53
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 10,003
Good job!
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-07-2018, 09:00 AM   #54
MarkJames's Avatar
Just wondering...
I have this rule to not take on a plumbing repair or modification on Friday afternoon (certain ones, anyway). Bad karma tends to visit, especially in the older homes. Anybody else have this rule? If you have dinner plans, forget it.
rescraft (12-07-2018)
Old 12-07-2018, 11:43 AM   #55
Robie's Avatar
Originally Posted by Leo G View Post
Good job!
No big deal. I just like to post an outcome when people take the time to reply to a question.
Robie is online now
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
New hot and cold outside spigot... Robie Plumbing 3 05-03-2014 06:17 PM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
