Outside Spigot Question. - Page 2 - Plumbing - Contractor Talk
Old 11-20-2018, 10:45 PM   #21
MarkJames's Avatar
Rewards Points: 19,035
Re: Outside Spigot Question.
Originally Posted by Golden view View Post
Neither pipe dope nor teflon tape is about making the seal. It's only an anti-seize so you can tighten the fitting enough to get the proper thread on thread seal.
I'm a bit skeptical on that claim. "True fact"?
MarkJames is offline
Old 11-20-2018, 10:50 PM   #22
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,852
Not being smart here...why not just use Vaseline then?
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
dayexco (11-23-2018)
Old 11-20-2018, 10:51 PM   #23
diplomat
Golden view's Avatar
Rewards Points: 1,550
Well I've been wrong many times before. But my understanding is npt is an interference fit. Not to say pipe dope or teflon tape doesn't help fill in minute voids.
Golden view is offline
Old 11-20-2018, 10:53 PM   #24
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,612
Originally Posted by griz View Post
rector seal....
as it is known on site as....rectum seal...
My favorite.
And all this time I thought I invented "rectum seal".
Guess not.
griz (11-20-2018)
Old 11-20-2018, 10:54 PM   #25
MarkJames's Avatar
Apparently you are right. Also, I just learned to never use teflon tape on pvc threads...it can lead to over-tightening and stripping the threads...not necessary.
Golden view (11-20-2018)
Old 11-20-2018, 10:56 PM   #26
diplomat
No idea, squeezes out too much compared to whatever's in pipe dope? I know that a 1/2" bolt can have something like 12,000 pounds of clamp force, so a 1/2" pipe thread can probably have some pretty strong squeeze between those threads.
Robie (11-20-2018)
Old 11-20-2018, 10:57 PM   #27
diplomat
That I definitely did not know.
Old 11-20-2018, 11:08 PM   #28
tjbnwi's Avatar
Rewards Points: 4,170
It is a tapered (NPT) interference fit. The pipe dope or teflon tape does seal and lubricate the joint.
Think of the threads as a continuous trough, it nothing more than a circular continous line. The dope/tape interrupts the ability for fluid to flow through the trough.
Assemble some air fittings without sealant, even with the tapered fittings made up tight, you'll have a leak. In this case air is the fluid. Better yet, try not using sealant on a vacuum system---good times.
My favorite dope is Leak Lock.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
Golden view (11-20-2018), Robie (11-20-2018), tgeb (11-21-2018)
Old 11-20-2018, 11:15 PM   #29
Robie's Avatar
That's what I thought it was for...plus lubrication.
Robie is online now
Old 11-20-2018, 11:29 PM   #30
tjbnwi's Avatar
I use teflon tape on PVC NPT treads all the time. Never had an issue with stripping the threads. Do not use petroleum based dope on PVC.
Don't forget when working on building gas lines---yellow teflon tape.
griz (11-20-2018), hdavis (11-21-2018), Robie (11-20-2018)
Old 11-20-2018, 11:34 PM   #31
Fire up the BBQ
griz's Avatar
Rewards Points: 2,006
X2 on teflon tape over PVC threads.
Most plumbers I see use it also.
griz is online now
Old 11-21-2018, 12:29 AM   #32
hdavis's Avatar
Rewards Points: 1,310
I stripped one. I'm sure I could strip PVC threads without the tape, though.
hdavis is offline
griz (11-21-2018)
Old 11-21-2018, 12:41 AM   #33
Fire up the BBQ
griz's Avatar
thread sealant is intended to fill the tiny void at the "v" shape at the bottom of a thread called the "root"....
down to earth ME explained this to me one day.....
sometimes you just gotta go with the flow.....
griz is online now
Old 11-21-2018, 05:06 AM   #34
MarkJames's Avatar
I've used tape on pvc threads without issue, as well (and probably will continue). That comment was a just a "share" from a plumbing mod on another thread, and I guess it makes sense.
Old 11-21-2018, 05:07 AM   #35
MarkJames's Avatar
Nicely worded, there.
Old 11-21-2018, 05:12 AM   #36
MarkJames's Avatar
Do you guys "grease dab" the threads (only the threads, not the ends) on compression fittings? I read somewhere that it was done to reduce the chance of feeling you snugged the nut down enough...when you haven't.
Old 11-21-2018, 07:06 AM   #37
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,250
I’d just swap out the offending parts with new. I’ve Never had this happen, always been able to get that extra 1/4, 1/2, 3/4 turn if needed. I’ve done quite a bit of black pipe.
Big Johnson is online now
hdavis (11-21-2018)
Old 11-21-2018, 08:40 AM   #38
tjbnwi's Avatar
No, it does not make sense.
All threaded fasteners have a torque to yield ratio, don't exceed it and life is good.
rrk (11-21-2018)
Old 11-21-2018, 08:43 AM   #39
tjbnwi's Avatar
I use PTFE on the threads. Again, because you've changed the friction coefficient it is easy to over torque the assembly.
Old 11-21-2018, 09:07 AM   #40
MarkJames's Avatar
I would call that ratio "feel", so it makes sense if the feel of snugness is different for different materials. But maybe it's a plumbing myth afterall.
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
New hot and cold outside spigot... Robie Plumbing 3 05-03-2014 06:17 PM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
