Outside Spigot Question. - Plumbing - Contractor Talk
Old 11-20-2018, 06:21 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,852
I installed 2 new spigots that are attached to an outside shower control.
I couldn't get the one on the right tightened past 3 o'clock and had to back it out in order for it to get to 6 o'clock, where it should be.
I taped and used pipe dope on the threads. Even backed off, nothing leaks but the entire spigot turns when you open and close the handle.
Is there a cure for this...will time solidify things?
Thanks.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is offline
Old 11-20-2018, 07:15 PM   #2
hdavis's Avatar
Rewards Points: 1,310
Re: Outside Spigot Question.
Pipe dope will harden, but teflon tape stays slippery. I think it will keep turning.
hdavis is offline
Old 11-20-2018, 07:23 PM   #3
hdavis's Avatar
Tough to tell, but you may be able to get the extra quarter turn with a tap and die and possibky a file. Otherwise, I think you're looking at a washer and straight pipe dope.
hdavis is offline
Robie (11-20-2018)
Old 11-20-2018, 07:24 PM   #4
Robie's Avatar
Never thought about a washer.
Thanks!
Robie is offline
hdavis (11-20-2018)
Old 11-20-2018, 09:06 PM   #5
rrk's Avatar
Rewards Points: 4,976
use a little less tape forget the washer
rrk is offline
Robie (11-20-2018)
Old 11-20-2018, 09:18 PM   #6
Robie's Avatar
I've had some bad luck in the past with these threaded plumbing fittings. I used to use just tape and tighten hard...leak.
Switched to dope...tighten hard...leak.
I asked around and a few plumbers said they use both. Today was the first time I tried both and it didn't leak...but it didn't line up either.
The one on the left was perfect. Just another little "umph" and it was at 6 o'clock. The right one wouldn't budge past 3.
Robie is offline
Old 11-20-2018, 09:43 PM   #7
MarkJames's Avatar
Rewards Points: 19,035
Chances are decent that if you bought another one, it would not have stopped at 3:00.
..and you might even be curious enough to try, as I was. (it worked for me, but not the same brand)
MarkJames is offline
Robie (11-20-2018)
Old 11-20-2018, 09:43 PM   #8
Tom M's Avatar
Rewards Points: 11,398
Dope softens the plastic so avoid it there unless separated by tephlon.
I guess it's more or less tape. I know anytime I fight black pipe for alignment tightening multiple pieces at together instead of once at a time is much more cooperative. Maybe a nipple in between?
Tom M is offline
Robie (11-20-2018)
Old 11-20-2018, 09:54 PM   #9
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 10,003
Why did you use tape and dope? It's one or the other. I like teflon tape for plumbing. If you don't get the position you like you wrap more tape. Otherwise you use dope, tighten to the position you want and let it dry.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
MarkJames (11-20-2018)
Old 11-20-2018, 10:05 PM   #10
Robie's Avatar
Like I said, I've tried both alone and have leaks. Not all the time but enough to piss me off. Two plumbers at the plumbing supply house I use said they use both...wrap with teflon 3 wraps, then slather on the dope uniformly.
Robie is offline
Old 11-20-2018, 10:07 PM   #11
LRG WoodCrafting
Leo G's Avatar
Thought you needed to let the pipe dope dry overnight before pressurizing. Which is why I use teflon tape. Never heard of using both.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Rio (11-21-2018)
Old 11-20-2018, 10:13 PM   #12
Robie's Avatar
Never heard of letting in dry. It's used to fill air gaps and as a lubricant.
Robie is offline
Old 11-20-2018, 10:18 PM   #13
Robie's Avatar
Just did a little research and apparently, using both is pretty common....on metal parts.
Robie is offline
rrk (11-21-2018)
Old 11-20-2018, 10:24 PM   #14
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 406
https://www.amazon.com/Loctite-442-3...26699239&psc=1
This stuff is the shiz for sealing problem threaded joints.
I had a damaged fitting on my outdoor boiler, where I could only get a couple threads engaged, used this stuff, and it's been holding fine for 10 years.
I also used it on a hydraulic cylinder with a damaged fitting, I'm a big fan.
mrcat is offline
The Following 2 Users Say Thank You to mrcat For This Useful Post:
Rio (11-21-2018), Robie (11-20-2018)
Old 11-20-2018, 10:27 PM   #15
MarkJames's Avatar
Not that it's right. I figure many keep trying stuff until it solves the prblen, then they're locked on it for good.
It's like seeing a guy dope a flare fitting...you can't tell him anything once it worked for him.
Rio (11-21-2018)
Old 11-20-2018, 10:30 PM   #16
Robie's Avatar
A few of these comments were from plumbers.
Robie is offline
Old 11-20-2018, 10:34 PM   #17
MarkJames's Avatar
I used to question plumbers when they deviated from the proper methods. I don't do that anymore, and sometimes it turns out I was probably right..but I keep quiet out of respect.
Old 11-20-2018, 10:41 PM   #18
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,612
It's pretty common to use both, but I only do it on gas fittings. I've never used both for water. Never needed to.
Gas/air molecules are smaller than water molecules, so that is why sometimes a system will not hold test pressure, yet does not leak water. Hence the use of both for gas.
For what it's worth, when both are used, the teflon tape goes on the male threads, and the dope goes on the female.
If it's bottoming out before it's tight, there is most likely something wrong with either the female or male fitting. It's not supposed to do that.
You should not depend on dope hardening to hold a fitting. The best pipe thread compounds are non-hardening. It's not designed to hold loose fittings by hardening up.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Old 11-20-2018, 10:42 PM   #19
diplomat
Golden view's Avatar
Rewards Points: 1,550
Neither pipe dope nor teflon tape is about making the seal. It's only an anti-seize so you can tighten the fitting enough to get the proper thread on thread seal.
Golden view is offline
Robie (11-20-2018)
Old 11-20-2018, 10:43 PM   #20
Fire up the BBQ
griz's Avatar
Rewards Points: 2,006
rector seal....
as it is known on site as....rectum seal...
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Rio (11-21-2018), Robie (11-20-2018), Seven-Delta-FortyOne (11-20-2018), tgeb (11-21-2018)
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
New hot and cold outside spigot... Robie Plumbing 3 05-03-2014 06:17 PM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
