Old Froze Up Reservoir Gate Valve - Plumbing - Contractor Talk
Old 06-09-2015, 06:21 PM   #1
Bob
Sand Pot's Avatar
Trade: Abrasive blasting
Rewards Points: 886
Hey guys, out of my usual forum here, hope someone in plumbing has some advice on this:
Our neighborhood's reservoir has a stuck 4" gate valve, its been open and not exercised for many years. There are no valves upstream from this or downstream that we can find so if anything happens in the neighborhood down below we can't shut off 25k gallons.
Any ideas how to rectify this problem? Can this one be taken apart and serviced? I was wondering if a block-off plate could be quickly installed when the valve mechanism is removed? The res is in-ground, the valve is adjacent to the res, the res is about 6 ft deep.
old froze up reservoir gate valve-img_2577.jpg   old froze up reservoir gate valve-img_2576.jpg
Sand Pot is offline
Old 06-09-2015, 07:26 PM   #2
MarkJames's Avatar
Rewards Points: 19,531
Re: Old Froze Up Reservoir Gate Valve
I'll bet some leverage would get that thing loose. Clamp two four foot 2x4's onto the wheel (opposite each other) and give it a turn with two folks. Something like that.
( I know nothing about those valves....only the laws of physics)
MarkJames is offline
Old 06-09-2015, 07:53 PM   #3
Bob
Sand Pot's Avatar
Rewards Points: 886
I've put some leveraged muscle to it and it moves a tiny bit but after several sessions of hearty back-and-forth it shows no signs of turning any more than just that.
Sand Pot is offline
Old 06-09-2015, 07:58 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,484
Try a little heat on the valve body while trying to turn it back & forth.
griz is offline
Old 06-09-2015, 08:52 PM   #5
GettingBy's Avatar
Rewards Points: 6,486
Can you block the pipe intake opening under the water so in effect you have a valve upstream of this valve?
Tape half foot long wire pointers 1" apart vertically on the valve stem and wheel so you can tell if the stem itself is being twisted/deformed, rather than the stem just rotating, or the handwheel rotating relative to the stem.
With the 50 PSI pressure I have no idea how safe this is, but,
loosen the 8 fasteners on the bonnet in a diagonal pattern by 1/4 turn or 1/2 turn or until the valve starts to leak, then try to work the valve, maybe while whacking the thing all over with a 3 lb hammer.
With this method it shouldn't matter exactly where in the valve the holdup is.
Do this job behind some kind of shield.
Of course, if retightening the bolts does not stop leaks then you are in deep ca-ca.
GettingBy is offline
Old 06-09-2015, 08:59 PM   #6
CarpenterSFO's Avatar
Rewards Points: 2,044
The pressure on a plate - around 35 pounds total with a 6 foot head - would be manageable, but getting the plate on while a couple hundred gallons of water per minute is going through the pipe would at least require a little planning.
Some reservoirs have a way to stop water flowing into the intake - an overflow that can be raised or the like. What is the intake to the outflow pipe like?
- Bob
CarpenterSFO is offline
Old 06-09-2015, 09:05 PM   #7
Originally Posted by GettingBy View Post
With the 50 PSI pressure I have no idea how safe this is,.....
I don't understand the 50 psi pressure. A 6 foot head adds about 3 psi to atmospheric pressure. With atmospheric pressure out in the room, the head through the pipe would be that 3 psi, times about 2^2*pi, or about 35 pounds total pressure across the diameter of a 4 inch pipe. Nothing to be careless about, certainly.
- Bob
Old 06-09-2015, 09:16 PM   #8
Can you block the pipe intake opening under the water so in effect you have a valve upstream of this valve? .....
That is something to be very careful about. If it's a 4" hole in the bottom of the reservoir, it might be simple and safe. If it's a 2-foot exit or overflow gate, choked down to the 4" pipe, you could have a trickier situation - enough water flow to hold a man down, and a considerably larger surface under that 3 psi, when re-opening the valve or trying to pull a drowning man out.
- Bob
Old 06-09-2015, 09:16 PM   #9
Bob
Sand Pot's Avatar
Rewards Points: 886
loosen the 8 fasteners on the bonnet in a diagonal pattern by 1/4 turn or 1/2 turn or until the valve starts to leak, then try to work the valve.
The reservoir is a six sided concrete box 2/3 buried. The outflow is simply a stub of the pipe rising about 12" above the floor as I recall. The rise is likely there to keep sediments from seeking the intake. One of my thoughts was to have a diver cap the outflow during the repair (access is through a small steel hatch off to the side on the top so its like a cave dive).
The deep do-do part is what I'd like to avoid
Sand Pot is offline
Old 06-09-2015, 09:19 PM   #10
Bob
Sand Pot's Avatar
Rewards Points: 886
Yes, getting the plate on in a timely fashion is what I was wondering about. I know its going to be a gusher.
Sand Pot is offline
Old 06-09-2015, 09:24 PM   #11
Bob
Sand Pot's Avatar
Rewards Points: 886
The thing about the valve is that it is open which I'm assuming means that the tapered disc that normally seals the valve closed is retracted all the way up so the bind is not on the disc, correct assumption? If yes then where would the bind be, in the threads of the stem? or maybe the packing gland?
Perhaps I should loosen up the gland first and see if I can get some movement
Sand Pot is offline
Old 06-09-2015, 09:36 PM   #12
Fire up the BBQ
griz's Avatar
The bind could be from corrosion built up inside the valve below the disc.
griz is offline
Old 06-09-2015, 10:26 PM   #13
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
Freeze the line on the inlet side and replace the valve, I would recommend an OS&Y style valve as opposed to a simple gate.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 06-09-2015, 10:32 PM   #14
Bob
Sand Pot's Avatar
Rewards Points: 886
Really? Freeze it? That sounds awesome, is there a specific piece of equipment to do that or do I hire it done? I suppose one could pack dry ice around the pipes to accomplish that?
On total valve replacement, is it possible that dimensions and bolt patterns have remained constant over the years that would allow slipping in an entire new valve without modifying the pipes and flanges?
Sand Pot is offline
Old 06-10-2015, 02:22 AM   #15
The Grand Wazoo
You use liquid nitrogen, hire it done, and check dimensions on the existing valve and what you are buying to replace it, though Stockham should be fairly consistent in flange to flange size.
Old 06-10-2015, 05:04 AM   #16
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
what about using a test plug to plug the pipe at the tank.
i do like the killers way
pappagor is offline
Old 06-10-2015, 08:31 AM   #17
Bob
Sand Pot's Avatar
Rewards Points: 886
Yeah, that is an option but it would require two trips into the tank by a reservoir diver.
I am definitely going to look into hiring a pipe freeze contractor
Sand Pot is offline
Old 06-10-2015, 10:11 AM   #18
GettingBy's Avatar
I assumed a valve that hefty holds back some force.
Old 06-10-2015, 10:13 AM   #19
GettingBy's Avatar
"Minimax (sometimes MinMax or MM[1]) is a decision rule used in decision theory, game theory, statistics and philosophy for minimizing the possible loss for a worst case (maximum loss) scenario. "
By now there seems to be several suggested ways to do this.
Old 06-10-2015, 12:08 PM   #20
Bob
Sand Pot's Avatar
Rewards Points: 886
and the K.I.S.S. theory, simply let the neighborhood demand drain the reservoir to the point that head pressure is minimal (leave the well pumps off until the repair is done)
Sand Pot is offline
w.c flush valve mohdmaruf Plumbing 1 02-23-2013 09:19 AM
Moen stop check valve....? PrestigeR&D Plumbing 8 11-27-2012 03:03 PM
Check Valve fireguy Plumbing 2 11-04-2010 06:53 PM
bryant gas valve heavyduty73 HVAC 1 12-16-2009 07:20 PM
gate valve compaction tool dayexco Excavation & Site Work 4 04-19-2006 06:46 PM
