Melted Wax Ring? - Plumbing - Contractor Talk
Melted Wax Ring?
Old 12-08-2010, 12:18 PM   #1
Life-Long-Learner
mc handyman's Avatar
Trade: Home Repair & Remodeling
Rewards Points: 150
Exclamation
Melted Wax Ring?
We got a call from one of our ragular customers. It is a resort/lodge. They recently had an issue with "Bed Bugs" and had the pest control company come in and exterminate the nasties.
They called and asked if I would look at their toilet as the said it was leaking. I figured it may have been a supply line that lost its seal but it wasn't. It is leaking from the base.
The toilet is located on a heated slab. When the exterminators came in they turned the in-slab heat up to the max and set up two portable jet heaters to burn out the bugs. Is it possible for the wax ring to melt from the increase temperature or could it be another issue?
I won't touch it simply because I am not a licensed plumber but I do want to ensure they find the source of the problem.
If you are afraid of criticism, you will die doing nothing.
mc handyman is offline
Old 12-09-2010, 08:00 PM   #2
bob14-0's Avatar
Trade: home construction
Rewards Points: 75
Re: Melted Wax Ring?
I've heard that wax rings are replaced with plastic ring whenever radiant floor is installed for the reasons you site. Not a plumber either but your theory is quite plausible.
Bob
bob14-0 is offline
Old 12-09-2010, 08:21 PM   #3
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Pull that toilet and tell us if there is a pool of wax underneath. I don't care if you are a plumber or not. Your father wasn't Casanova and he managed to reproduce.
I like the melting of wax rings by the exterminators. I like it a lot.
cleveman is offline
The Following 3 Users Say Thank You to cleveman For This Useful Post:
mrmike (12-10-2010), stp57 (12-12-2010), WarnerConstInc. (12-09-2010)
Old 12-09-2010, 08:48 PM   #4
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
Dude, it's a toilet....you can do it man...I believe in you brother...take the plunge and loosen the 2 bolts.
Use plumbers putty
Mike
see ya!
Mike's Plumbing is offline
The Following 2 Users Say Thank You to Mike's Plumbing For This Useful Post:
MALCO.New.York (12-13-2010), pinwheel (12-10-2010)
Old 12-09-2010, 11:15 PM   #5
Life-Long-Learner
Rewards Points: 150
Okay!!! That is the last time I take advice from a PLUMBER!!! So swung out to the resort this morning and removed the toilet. Sure enough- the ring was all slumped down and deformed.
Ohh and another surprise... there was a massive terd that fell out of the toilet! How do you guys sleep at night? I have seen some nasty stuff but this terd had corn and peas in it! The smell... ohh
OUt of all the tradesman I bow to you guys! You guys are the ones that battle in the trenches everyday! Thumbs up to you!
Have you guys ever heard of this happening before? The whoel melting of the wax?
The Following 2 Users Say Thank You to mc handyman For This Useful Post:
Docwhitley (12-18-2010), UALocal1Plumber (12-12-2010)
Old 12-09-2010, 11:23 PM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,288
Yeah I've heard of turds falling out of toilets from time to time.
I know when they exterminate bed bugs they install as many electric heaters as your circuitry can handle to cook the buggers...and wax is well.....wax.
Inner10 is offline
Old 12-09-2010, 11:25 PM   #7
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
I will check with my Radiant floor guy in the morning but if they cranked it up all the way up and usally in the slab is set to run at around 120-140 so the theory is sound.
wyoming 1 is offline
Old 12-09-2010, 11:35 PM   #8
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
melted ring?
get ready for it
some one must of taken a hot dump
world llc is offline
Old 12-10-2010, 06:51 AM   #9
bob14-0's Avatar
Rewards Points: 75
Let's not get carried away - When I started out in a plumbing warehouse back in '73, I was once called to the job from a plumber who told the boss he had an emergency and needed help. The emergency was a another trade took a crap in one of the tubs and the warehouse guy had to clean it up. On that day, I may not have possessed the skills to pour a lead joint, but I had more oakum than the plumber!
**** runs down hill, who needs a level?
Bob
bob14-0 is offline
Old 12-10-2010, 02:58 PM   #10
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Hah!
I just had to put a torch to one to get the water closet to set.
Turns out wax gets hard when you leave it out in the van in 15 degree weather.
Thought about throwing it in the customers microwave for a quick minute but decided to pull the torch out instead.
Paulie is offline
Old 12-10-2010, 04:19 PM   #11
katoman's Avatar
Trade: carpenter
So, what is the proper ring to install when there is a heated floor?
katoman is offline
Old 12-10-2010, 04:46 PM   #12
Timber Jockey's Avatar
Trade: Renovations cabinetry
Rewards Points: 75
There is a composite, or "plastic" toilet seal, meant to be used with radiant heated floors. It works great!
Timber Jockey is offline
The Following User Says Thank You to Timber Jockey For This Useful Post:
katoman (12-10-2010)
Old 12-10-2010, 04:55 PM   #13
Life-Long-Learner
Rewards Points: 150
That is what I thought. The local supply house out in the woods there didn't have one though. That is actually becoming standard in new construction regardless if there is in-floor heat isn't it?
Old 12-10-2010, 04:57 PM   #14
Life-Long-Learner
Rewards Points: 150
Originally Posted by paulie View Post
Hah!
Haha I could only imagine what your client would think if they saw you looking at the wax ring bubbling up in the nuker. Did the torch work well?
Old 12-10-2010, 05:01 PM   #15
Rewards Points: 75
I still use the wax rings with extensions when working on toilets, if there is NO heated floor. As soon as the client has any style of heated floor installed in the bathroom area, I switch to the "plastic" ring. In MY opinion..the tried and true wax seal does a perfectly good job..that is until you introduce heated floors. Don't know if it's better in ALL cases. JEEZ...what would the bees do if we stop using was rings???
Old 12-10-2010, 05:42 PM   #16
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,946
I don't use wax rings, nor do I use anything made of plastic designed to replace them.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 12-10-2010, 06:47 PM   #17
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,150
OK ill bite, What do you use to seal it??
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is offline
Old 12-10-2010, 07:11 PM   #18
Trade: ooo
A lot of plumbers use plumbers putty, it's kinda old school. I've used it and it does work but I prefer wax of course.
Mike
see ya!
Old 12-10-2010, 07:44 PM   #19
wyoming 1's Avatar
Rewards Points: 520
My radiant floorguy said yes they will melt and sag, he recommended a neoprene gasket
Old 12-10-2010, 07:58 PM   #20
Trade: ooo
Ask your radiant floor guy why he feels he needs to run the heat 1/8" from the flange.
I've done a ton of in floor heat and it's very rare to have a ring melt. People who wrap tubes around a toilet flange are morons.
Mike
see ya!
The Following User Says Thank You to Mike's Plumbing For This Useful Post:
Screw or Ring Shank ? We Fix Houses Decks & Fencing 8 05-20-2009 11:46 PM
Can YOU ring the bell? CrpntrFrk Off Topic (Non Trade) 6 03-08-2009 12:00 AM
ring shank nails with fiber cement siding? Jer Windows, Siding and Doors 16 01-18-2009 12:58 PM
Most professional cell phone 'ring'? mdshunk General Discussion 41 05-05-2007 08:29 PM
Ring .... Ring ... Ring .... Peladu Off Topic (Non Trade) 24 09-19-2006 06:36 PM
